Question about Logitech Cordless Mouse
The on-screen mouse pointer seems to disconnected from the mouse--when I move the mouse the pointer goes in weird directions or doesn't move at all. when I get the pointer in position and left click to select it may or may not work. The batteries are new. Is it time for a new mouse?
    Genius:
  • 1,456 Answers
Hi there
Please disconnect the mouse,restart your system and re-connect the mouse ..
Posted on Jul 08, 2010
Mouse pointer jumps when moving it on screen.
If you are not using a mouse pad, try that. Using the mouse on reflective or glass surfaces. Try another mouse to see if it has the same issues. Check your mouse settings in control panel to make sure everything seems ok. Update mouse drivers. Finally, you can try to uninstall / reinstall the mouse.
Nov 13, 2013 | Gateway Computers & Internet
Samsung laptop cursor tweeking
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 10, 2012 | Samsung SENS R460 LAPTOP LCD SCREEN 14.1"...
The cursor jumps around on my ASUS K501J notebook.
Step 1
Step 2
2. Select the "
Apply."
4. Pick the "
Step 3
Oct 08, 2012 | ASUS K50IJ Notebook
I put new batteries in and everthing lights up. The mouse worked at one time but I haven't used it in a few years. I've pushed both buttons (1) on the mouse and (2) on the USB adapter, the adapter blinks...
disconnect the usb adapter from the system connect it again mean while remove the mouse batteries re insert or better change batteries then perform the step that you ahve already tried
Oct 17, 2010 | Kensington 72219 Mouse
Pointer on track pad moves on its own. it does not move along with finger and goes in jerky direction elsewhere.
did water get on the track pad? Try connecting an external mouse to get control over your pointer, and navigate to system preferences/track pad. See if you can play around with the settings, but if the external mouse works ok, it sounds like water may have come in contact with your track pad.
Sep 12, 2010 | Apple MacBook Pro Notebook
Pointer moves when clicking even is mouse is not moving
just open ur mouse
and clean it with cotten
and u will never got thsame problem.....
Jun 26, 2009 | Logitech Gaming-Grade MX518 (9313520914)...
Mouse pointer seems to randomly move around the screen
The problem is in the trackpoint itself, it is defective. The fix is to either disable the function of the trackpoint through software or by physically disconnecting it.
Disabling through software can be done usually through the BIOS or in the Control Panel in windows. If there is no way for you to disable it then you have to remove the keyboard and cut the connector that is coming from the trackpoint control board. Make sure that you do not cut the keyboard cable. The trackpoint cable is usually about 4 wires thick and is seperated from the thicker keyboard cable. The only other thing to do is to replace the keyboard.
Apr 03, 2009 | Dell Latitude D410 Notebook
MS Wireless IntelliMouse 2.0 pointer direction reversed (up/down)
Go into the control panel and click on the mouse icon and see if you can change to settings back to normal.
If not then check under your start menu and see if the intellimouse software is installed there and go into it to change the settings from there.
Feb 14, 2009 | Microsoft Wireless IntelliMouse Explorer
MY GE WIRELESS OPTICAL MINI MOUSE POINTER MOVES ON ITS OWN
I get the same thing from a optical with cord.
Change the pointer speed. Look in Start > Control Panel > Mouse > Pointer Options.
Nov 24, 2008 | GE Wireless Optical Mini Mouse 3087897985
Monitor
Ctrl,Alt and the arrow up, down key should fix it. Check your pc because some use a different key code. If no right click on desktop, go to properties, display settings and adjust the screen.
Jul 06, 2008 | Dell Dimension 3100 PC Desktop
Logitech Cordless Mouse Logo
249 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
