Question about Refrigerators
Deep Freezer aeg Arctis shows code F5 and doesn't do a good job in cooling down and keep the temperature
SOURCE: What is AEG OKO-Arctis error
AEG ServiceForce tell me that F7 is a reduced pressure error possibly caused by a leak. There is no evidence of a leak and the error no longer shows on the display. Will just have to wait and see if it reoccurs.
Posted on Jun 02, 2008
  • 531 Answers
SOURCE: fridge not cold - freezer cuts out at minus 10 degrees.
check damper control
Posted on Apr 03, 2009
buddymcl777
  • 67 Answers
SOURCE: Upright freezer not cooling adequately
Go to there website and see if you can find your model. You can also contact them from there.
http://www.aeg-electrolux.co.uk/node145.asp?CategoryID=2595
Also get yourself a stand alone fridge and freezer thermometer - leave it in for an hour -that will establish what the temperature really is which will help in diagnosing the cause.
Also trying unplugging it for 15 minutes so the display board loses power - then plug it back in - sometimes that will reset it.
Posted on May 04, 2009
SOURCE: aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Posted on Aug 05, 2009
SOURCE: My AEG Arctis freezer is not freezing at the
The freezer is probably in need of defrosting. This usually occurs when the freezer has been over packed. It needs to be able to ahve air flow through it, there are holes in the back of the freezer and a defrosting element at the top and they need to be clear in order to keep it frost free. It happend to me and we called an engineer out. solved it by using hair dryer to defrost it.
Posted on Apr 21, 2010
Having restarted my upright Freezer how long will it take for the flashing red light to stop flashing
what was the reason for the trouble code --if problem not fixed trouble light will keep flashing if light flashing due to temp when setting is reached will stop
Jul 17, 2016 | AEG 10.35 cu. ft. / 293 liter Upright...
Freezer losing temperature
Hi Julie. I'm Roger. It sounds like the operating thermostat is not working When not in the fast freeze mode. Can you here a click sound from the thermostat when turning the temperature up and down short of fast freeze? We normally charge them to operate at -10 to -20 degrees. The inside temperature will normally only reach a temperature around 18 degrees warmer. The operating thermostat should allow you to regulate its temperature any where from that capability up to where you want it. See if your thermostat makes a clicking sound when adjusted. The warning light comes on because it knows the box temperature is higher than it is set for and is warning you of that. If it uses a printed circuit (PC) board, the click will dot be very loud. listen closely. Let us know how this turns out for you. We have very good refrigeration techs. here. Someone else here may have an idea too.
Jan 23, 2014 | AEG Freezers
Aeg arctis freezer
Check that the cooling pipes at the back of the freezer are not clogged with dust etc. and that there is sufficient space for air to circulate around them. If they are ok check that the freezer door seals are all intact and seal the freezer cabinet completely when the door is closed. Any gaps here will cause the compressor to over work in an attempt to keep the temperature low. If none of these suggestions then it could be a slow leak of the refridgent gas. A clue that this is the case is the freezer being a lot cooler at the top than the bottom of the cabinet.
Jan 06, 2014 | Freezers
Orange light is on instead of green in the freezer does this mean anything?
no. the orange light is the temperature light and the green light is the mains light.
Apr 06, 2010 | AEG 10.35 cu. ft. / 293 liter Upright...
Hi Arctis frost free freezer,almost 4 years old. Yesterday morning I noticed that the temperature had risen to 15 and today it is at 12. The motor is still running. Any advice would be appreciated. Thanks...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Mar 09, 2010 | AEG 10.35 cu. ft. / 293 liter Upright...
My AEG Arctis freezer is not freezing at the correct temperature and seems to stick on -11 even if I put the fast freeze on.I have turned it off for 24 hours and on again but it still does not hold the...
Oct 05, 2009 | AEG 10.35 cu. ft. / 293 liter Upright...
May 04, 2009 | AEG 7.59 cu. ft. / 215 liter Upright...
Aeg fault codes
Apr 13, 2008 | AEG 10.35 cu. ft. / 293 liter Upright...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
