Question about Dometic Rooftop RV Air Conditioner
Needs r-12, how to install - Dometic Rooftop RV Air Conditioner
  • 455 Answers
You found R-12?
Posted on Jul 08, 2010
Free download norcold n611 rv refrigerator manual
DOWNLOADS
Parts List-06-08-12Reference6/13/2012669.77 Owner's Instructions - Cooling Unit InstructionsTechnical7/12/200728.17 Installation Manual - 3/23/06 - 2/19/07User Manual7/12/2007872.04 Installation Manual - 8/2/04 - 3/23/06User Manual7/12/2007791.81 Installation Manual - CurrentUser Manual6/16/20091,239.84 Installation Manual - Through 8/2/04User Manual7/12/2007508.79 Owner's Manual - 3/23/06 - 2/19/07User Manual7/12/2007370.63 Owner's Manual - CurrentUser Manual1/20/2010630.82 Owner's Manual - Through 3/23/06User Manual7/12/2007394.09
I believe you can find the fault codes above. Here is a link to the Norcold N611 Information and Contact Page
Thanks Sea Breeze
Jun 12, 2013 | Refrigerators
My skype certificate is expired what can i do
I just revered my mobile phone clock and skype installed. Thanks a lot
Apr 24, 2013 | Nokia E5 Cell Phone
Wiring 12/2 or 12/3
12/2 cable (Romex, UF, etc) consists of two insulated #12 and one uninsulated #12 conductor or wire. The two insulated wires have a black and a white colored insulation. Number 12 copper is rated for 20 amps. This cable can carry a single circuit with ground.
12/3 cable is identical to 12/2 with the exception being that it has a third insulated conductor that is colored red. This third wire allows one cable to supply 2 circuits (one on black and one on red with both sharing the white and ground wires) with one cable run. It is much cheaper to buy and install a single 12/3 cable than two 12/2 cables to get two circuits into the same general area.
Twenty amp 120 volt circuits in dwelling units are required for kitchens, dining rooms, washers, disposals, and other appliances that require more than 12 amps (but less than 16 amps) to operate. Twenty amp 240 volt circuits are typically for specialty appliances and devices such as electric heaters, pumps, etc. Generally, 20A/240V appliances devices do not need a 12/3 cable as they only require connections for Line1, Line2 and ground. One insulated conductor would be unused in a 12/3 cable serving such a device. A 12/2 cable is run instead and the white wire is taped red (any color other than gray or green, to indicated that it is no longer a neutral) at each location it is accessible, such as wiring compartments, panels and junction boxes.
Circuits fed by 12/2 cables will connect to single pole circuit breakers and those fed by 12/3 cables must be connected to double pole circuit breakers. Check the National Electrical Code (NEC) to determine which locations require GFCI (Ground Fault Circuit Interrupter) supplied circuits. The latest (2012) NEC requires most new circuits in dwelling units (residential) to be protected by AFCI (Arc Fault Circuit Interrupter) type circuit breakers. Consult your local building department to find out if the NEC has been adopted in your locality before installing.
Lastly, a 12/3 cable would be run between 3 way & 4 way light switches and hard wired smoke detectors; but only if they are on a 20 amp circuit. Most circuits in the home are 15 amp capacity, especially for lighting circuits. A 14/3 cable would be run on these circuits as there is no need for the additional expense of a cable with the larger #12 wires and the increased labor to handle, install and connect the wires to device terminals.
I hope this helps. Please rate my reply - thanks!
Jan 18, 2012 | Siemens Hammering
TRYING TO INSTALL WORDPERFECT OFFICE 12 FOR FHOME USE ONLY ON MY LAPTOP. HAVE WINDOWS 7 INSTALLED. WILL NOT COMPLETE INSTALLATION. SAYS ERROR AND CLOSES OUT.
WordPerfect 12 is almost certainly incompatible with Windows 7 -- and is the reason you are getting the error message. The current version of WordPerfect is X4 -- at least 3 upgrade versions from version 12.
The drivers in version 12 were for Windows 98 / 2000. It would have worked OK with XP and maybe even Vista - but Win-7 is a new OS altogether. Sorry, but it sounds like you may need to do an upgrade.
Jan 07, 2010 | Corel WordPerfect Office 12 Home Edition...
When I convert files and delete frames, the audio becomes unsynced
Did you try to install the patch for your Studio 12? If not try to download the patch to the website of Pinnacle. By the way if your Studio 12 is version 12.1 no need to download and install the patch.
Oct 03, 2009 | Pinnacle Studio Ultimate 12 for PC
I need to install a 12 volt power outlet on my truck
this should be a simple task for you since the cherokee already runs on a 12 volt power system. the easiest way to do it would be run a single pair wire from the battery itself to a 12 volt connector. there are harder, more detailed versions of this where you would need to dig into the fuse box, but if you are looking to power something low voltage like a gps, cell phone the first way will work.
you can buy the connector and wire with a fuse on it from any autoparts store. you will need to drill through your firewall and I would recommend a uni-bit or multi-bit to get through it. it will go right on to your drill.
Sep 25, 2009 | Car Audio & Video
Computer keeps trying to install WordPerfect Office 12
It may be in your programs that you need to uninstall WordPerfect Office 12. It just seems like something is partially installed and wants to complete.
Jan 10, 2009 | Corel WordPerfect Office 12 Standard...
Fiery x12
Have you gone into the driver properties and checked if the setting in the drive is defaulted to duplex?
Jan 17, 2008 | Xerox DocuColor 12 Printer
Dometic Rooftop RV Air Conditioner Logo
101 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
