Question about Goodman GPC1342H21A Air Conditioner
The outside fan does not come on how do i fix this?
    President:
  • 1,515 Answers
Hi, this fan is the condenser fan motor. The motor has probably failed, bearings or open windings, You can check the capacitor to see if it is faulty, leaking any oil, swollen like its ready to burst. If so, change it out. When the condenser fan motor fails, always replace the run capacitor with it, it must be changed with the new motor. You can remove the fan guard on top after the unit has been running, and the motor body should be very hot. With the power off, turn the blade to see how it turns, if the bearings are frozen or its tight you will no. You will have to buy one at a appliance parts house or if you know a contractor, they can get one at cost for you at a a/c parts house. These motors go out a lot as they work hard in the heat. When we get our first heat wave here, this is what we do first is start getting lots of calls to replace these motors. Check these things and let me know.
Sincerely,
Shastalaker7, A/C, Heating, & Refrigeration Contractor
Posted on Jul 08, 2010
Testimonial: "thank you so much for your quick response I will try what you suggested and let you know how it turns out"
  • Robert Horton
    Robert Horton Jul 09, 2010
    Thank you for the very kind rating. I am sure you have lost the motor. I replace about 12 per summer.
    Shastalaker7
How to fix a air conditon
Clean air filter?,. Coil air filter protects clean?,. Wash outside coil,. Is blower fan and outside fan up to speed,. If all this is true the. Freon related most likely
May 29, 2016 | Honeywell Heating & Cooling
How do I fix my A/C
can be a bad fan motor, defective capacitor or contactor issue. capacitor is cheapest fix if bad.
May 11, 2014 | Bryant Heating & Cooling
My LG LWHD1200FR air conditioner turns on, but the fan doesn't spin and no cold air comes out. What's the problem? How do I fix this?
Which fan doesnt spin the inside fan or outside fan? If its the outside fan try replacing the dual capacitor for the fan and the compressor. First take the fan blade and see if it spins freely if you spin it and it stops immedietly the fan bearings are bad. If it spins freely replace dual capacitor. If trhis helps please rate me and do a testimonial.
May 31, 2011 | Heating & Cooling
My air conditioner has stop working its blowing air inside but the fan is not spinning outside .....
If the fan is not running is the compressor not running also...if neither is running the possible reasons are 1..no power to outside unit...2..bad contactor on outside unit.is this buzzing if it is this indicates no power...3 bad capacitor,do both compressor and fan humm then quit humming and hum some more...4 high pressure switch has shut unit down because fan wasnt running if compressor was running but not fan....if your unit has this there will be a manual reset button where the lines come out of unit...if compressor was running and fan was not...1 bad fan...2 bad capacitor.. if you do not have any electrical knowhow i would recommend calling a hvac tech to come and fix unit...Thanks
Feb 01, 2011 | Samsung AS18A6RB Air Conditioner
I have a Intertherm heat Pump. Everything turns on inside the house. Blows warm air and the outside Fan wont turn on. Both the outside copper pipes are same temp, neither hot nor cold. Don't know the modle...
If the fan outside doesn't work the compresor will overheat and shut off by the thermal protection inside the compressor , to fixed this you have to replace the fan motor and its capacitor.
Aug 26, 2009 | Heating & Cooling
Bryant air condition fan outside not coming on
Check breaker for outside unit Also check to see if you ahve afloat switch on the inside air handler. Located under or in front of unit. It may be full of water and tripped. Blow out drain if tripped.
Jun 15, 2009 | Ruud UBHC Air Conditioner
The compressor wont go on outside but the inside unit fan is working. it will not get cold.
This could be caused by so many issues,It would be best to call a Heating and air company for a service call.
May 31, 2009 | Fujitsu Heating & Cooling
OUTSIDE UNIT TURNS ON ,BUT FAN WILL NOT RUN.
bad motor? faulty thermostat? turn fan switch to on still no motor you'll need a volt meter to figure out what is wrong or hire somebody with a meter who can fix it hvac contractor.
Dec 17, 2008 | Goodman CKL36AR36 Air Conditioner
Outside fan will NOT turn off
A relay can be welded "closed" and cause this. It is in the outside half of the air conditioner. If you have printed circuit boards, it's a lot harder to guess what's wrong from over here, but I've actually seen this problem when it was caused by a relay. Of course, I am assuming no person has been in there changing wires around.
Open it up, find the relay where one of the fan wires is going, give it a sharp rap with a screw driver handle. If that fixes it, replace the relay.
Jul 22, 2008 | Carrier 38CKC036 Air Conditioner
Goodman GPC1342H21A Air Conditioner Logo
167 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
