Question about Maytag MEC5430BDS Electric Cooktop
On indicator light on my Maytag touch control 500 electric smoothtop range will not turn off, even though all burners are turned off. I also shut the power off but the light still stays on
    President:
  • 1,891 Answers
I can't help you with this if the light will not go off on one burner then replace that switch . but if you turn the power off and the light still is on. the unit is getting power from another unknowen source . mm
Posted on Jul 22, 2010
Maytag precision touch control 500 electric smoothtop
The heating coils in the oven need to be inspected very carefully where they plug in to the oven wall. You will need to remove the back covers and check the insulators and wiring harnesses. Over time the insulation can break down and oxidize the metal connections. You can use a voltmeter or test light to verify that the coils are getting voltage from the thermostat/switch. replacing parts is cheaper than buying new if you can find the parts.
Oct 04, 2017 | Cooktops
Indicator light on my maytag electric smoothtop range will not shut off even though the indicators are off?
One of the high heat sensors has failed on one of the burners under the glass. Disconnect one sensor at a time to find out which one, then replace that burner assembly.
Feb 19, 2011 | Maytag MEC5430BDS Electric Cooktop
The on indicator light stay on all the time on Maytag touch 500
you have a bad switch, you need to unplug the wire going to the conector marked P on one switch at a time til you find witch switch is bad. if you have turned off the breaker to it and the light is still on then the power is not off to it there is not a batery in it, careful that glass breaks easy when out of it's can
Dec 25, 2009 | Maytag MEC5430BDS Electric Cooktop
The heat indicator light does not turn off even when burner is cold
It is either the control for that burner or the sensor on the burner. have to check with a meter to verify which one it is.
Eric
Jul 16, 2009 | Maytag MEC5430BDS Electric Cooktop
One surface element went dead.
Make sure that element didnt come unplugged. Just push it in firmly and it should be fine.
Mar 18, 2009 | Cooktops
Maytag,electric stove-
you need to order a custom control kit, electronic switch that contorls onlly that one burner
Dec 07, 2007 | Maytag MEC5430BDS Electric Cooktop
Cooktop light stays on when cool
the "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Mar 28, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Maytag MEC5430BDS Electric Cooktop Logo
481 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
