posted by Halderman on Apr 18, 2008
the cd door is stuck - i cant open the door or close it, help?
Tray does not open when switch is depressed. Green light burns steady.
Comment by Halderman, posted on Apr 20, 2008
I found my problem. When I installed the internal TDK 440N burner I confused the flat cables and connected the wrong cable from the motherboard to the burner. When I connected the right cable from the motherboard to the burner the burner works just fine. Sorry to have bothered you all with my goof. Thanks much for your help.
1 Other User Has The Same Problem
Comment by ptoffice, posted on Apr 20, 2008
I too have a cd draw that wont open. Short of taking a hammer to it I am fresh out of ideas.
Best Solution
http://video.about.com/pcsupport/Open-a-Stuck-Drive-on-Your-PC.htm
First, you'll need a paperclip. Unfold it so there is 1 to 2 inches that is straight.
Now, look closely at your drive door. There should be a very small pinhole either above or below it.
Insert the paperclip. There is a very small gear that when rotated, will manually open the drive door.
Retract and reinsert the paper clip as many times as it takes to eject the drive enough so you can hold onto it.
Pull Out the CD or DVD Drive.
Now slowly pull the drive out until it is fully retracted. Remove your stuck CD or DVD, and slowly push the drive bay back until the door is closed.
Rating Locked! (?) Halderman has rated this solution as Helpful
Can you Help with these Removable Media problems?
TDK (DVD+RW47BXS5) Storage Media
TDK DVD RW 4.7 GB Single Sided
Help! I have a dvd rw and it... Answer This...
Repair Service
Find Removable Media Repairman Near You:
