Question about Magic Chef 31000 Gas Kitchen Range
Oven not comming up to set Temp
Takes an hour to come to temp setting even after an hour max temp may be only 250 when set at 425.
Sometimes never gets past 100
    Sergeant:
    Champion:
  • 311 Answers
Replace the oven ignitor.
Posted on Jul 10, 2010
Gas owen overcooks
I get this service call a lot so lets verify temp before we discuss possible causes set the rack in the middle of the oven hang an oven thermometer in the center of rack set a 350 let run 1 hour check the temp after an hour this gives the oven enough time to cycle and stabilize this will give you the true average of oven, temp placement of thermometer is important plus or minus 15F on either side of 350 is not that much of a big deal the max range for a temperature offset is usually 30F, there should be a tech sheet in a plastic pouch on the back of the unit now if you do find it to be running 50F too hot well there are test to determine if the temperature sensor is operating correctly it should read appx. 1654 ohms at 350 this tells the control board to open the heat relay stopping power to the gas valve lot of work you have to have the oven out back panel off to access the wiring going to control unplug machine at 350 disconnect wiring from board to ohm out sensor, sensors go bad and so do boards, sensor is cheaper try changing it first.
Apr 04, 2015 | Maytag Kitchen Ranges
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Oct 14, 2010 | DeLonghi DO400 Toaster Oven with...
Oven temp
I am experiencing the exact same problem. May try to trouble shoot myself if no one provides assistance on this site. It looks like the problem has to do with either the Sensor, Heating Element or etc..
Jul 03, 2010 | Amana ACF4215 Electric Kitchen Range
Have a viking professional oven and it takes too
A weak oven ignitor will cause this problem. even though it eventually lights the temp has dropped considerably so you don't get consistent temp. turn the oven on and listen for the burner to light. should light within about 2 minutes. if not replace oven ignitor(s)
May 20, 2010 | Viking 27" Professional Select Built-in...
Problem with oven is it takes hours to reach temp
temp. sensor isnt working you would have to call in a repairman
Nov 25, 2009 | Magic Chef 31000 Gas Kitchen Range
Preheat takes forever
http://www.applianceaid.com/nuker.html
click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
Some ohm readings and there temperature:
Degrees F    -   Resistance
            100 - 1143 ohms
             200 - 1350 ohms
             300 - 1553 ohms
             350 - 1654 ohms
             400 - 1753 ohms
            500 - 1949 ohms
click this link
http://www.applianceaid.com/elecrange.html
Mar 01, 2009 | GE Ovens
Kenmore oven doesn't keep heat
im going to assume it is gas.. you may have a bad ignitor.. it is not gettin hot enough all the time to ignite the gas.. eventually it will not lite it at all..
Feb 15, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 30425 Oven will not reach target temp
the ignitor is moast likley bad, look for a hot spot on the ignitor showing a open on the filament.
Dec 25, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Magic Chef 31000 Gas Kitchen Range Logo
133 people viewed this question
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
