Question about Honda Electrical Supplies
Em 5000sx runs but stalls under load. had a hard time starting have to play with choke. drained gas cleaned carb finally got to run. now when i plug something in it stalls under load
    President:
  • Honda Master
  • 1,388 Answers
GX340 engine always works best with complete carb kit that at least contains main jet, needle valve, main nozzle and orings. It is hard to clean varnish/crud from carb and soaking may make it worse. Kit is not expensive. Check ebay, less than $10. Before you change any parts make sure that your cap is venting properly. Many California gas caps (tall chrome gas cap) may cause fuel lock. Also check that muffler is not restricted with carbon. Good luck
Posted on Jul 10, 2010
2010 Sportsman 500 HO
have seen this happen to my honda, water gets ingested in the carb when in deep water and settles in the bottom of the fuel bowl. you must remove the fuel bowl drain cap to drain out water
May 07, 2017 | Polaris ATV
Rough idle mower stalls at will
Take the Carb off and clean the ports and make sure the float isn't sticking
Aug 26, 2012 | Murray Garden
Engine surging 179cc craftsman snow thrower
sounds like the carb will need removing and having it ultrasonic cleaned
Dec 16, 2011 | Mtd Garden
Hi, my description is lengthy, but I tried to provide as much detail as possible for troubleshooting. I'm seeking technical input re: a continuing carb issue w/my '96 Magna, which would not turn...
Reserve tube is usually set at a 1 gallon level in the tank, if you only added a gallon to an empty tank,I would fill the tank at least half full, If that doesn't fix the issue then replace the petcock, It's not a carb issue if it runs fine in reserve.
Jun 28, 2011 | 1996 Honda VF 750 C Magna
Hard 2 start wont stay running
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RON LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 26, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
1997 honda magna, has not run for couple of years, was able to have it idle, with full choke, push in choke after warmed up, and it stalls. Then it will restart with full choke. left it alone for a week,...
Sounds as if the carbs are fouled. Best bet is to get rid of the old gas, remove, tear down and clean up. With time old gas will cause plugging in jets and such. If you are able to drain all the old gas from the tank you may be able to get away by using new gas and a fuel treatment for cleaning the carbs. You'd have to get the engine to run for a bit to get the fuel cleaner in to the carbs, if the jest are plugged you'll have to tear them down.
I hope this may have helped,
Tom
Apr 15, 2010 | 1997 Honda VF 750 C Magna
400 Eiger ATV, starts and runs fine, stalls the
If 2 stroke check crank seals, check plug cap for proper resistance,check for good fuel flow to carb.Spark should jump at least a 1/4" gap,NOT JUST the .030 or plug gap.
Sep 08, 2009 | 2004 Suzuki DR-Z 400 E
Compressor wont stay running
couple of yrs worth of varnish in carb or filter now has hard time getting fuel fast enough for high rpm. try running some fuel cleaner if you dont feel like taking bowl off carb and cleaning jet.
Apr 17, 2009 | Dewalt d55151 factory reconditioned emglo...
Engine idles fine, stalls soon as its given gas
Hi there!
Open up the carb and clean the jets with pressurized air. I also suspect water on the carburetor reservoir, before opening the carb, drain it first then run. Also, make sure the plugs are clean. Pull on the choke when twisting the accelerator, if it accelerates well, then warm the beast at normal temperature first before twisting the throttle hard again.
hope this helps-
levibit-
Mar 29, 2009 | 2004 Yamaha V Star 1100 Custom
Electrical Supplies Logo
517 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
