Question about Lowrance GPS
The warn do not oper when driving comes on when I first turn it on and it will not go off,when I push the X button,or anything eles I try.
No the problem is not fix and I don't feel I should have to pay to find out how to fix it,as the gps is still under warrenty.
Posted on Apr 20, 2008
How do I reset and turn off the "Maintenance Required" warning message on my 2006 Lexus LS 430 with built in navigation and radar cruise control? Many thanks.
normally disconnecting the battery for about ten minutes then reconnecting is enough to reset the computer and get the light to go out. although is there is a existing problem i will come back on after about 10 minutes of driving.
Apr 09, 2011 | 2006 Lexus Ls 430
I need to know the procedure to reset, 'Change Oil warning' on my 2006 Ford Freestar.
On the right side of the steering wheel there is a button that says "setup". Turn the ignition key to the on position, push the setup button and hold it until the change oil warning shows 100%. There should be a message that pops up telling you to push the reset button to the right of the setup button. Push the reset button and hold until the message confirms the oil life has been changed to 100%. Release button turn off ignition key. Now start the engine to make sure the warning light does not come back on. If it does, try again.
Jan 22, 2011 | 2006 Ford Freestar
I have an esp button on my VW should I switch it on in this weather or is it on default?
IMPORTANT NOTE: PERMANENTLY YOU SHOULD LEAVE THE "ESP" BUTTON FREE! It is "ON" by default, and ESP warning lamp on dashboard is turned off.
If you need ESP system deactivation for short time, then push the ESP button. The ESP warning lamp on dashboard will be turned on, for warning you that ESP system is deactivated. Only for short time in few special cases ESP system needs to be deactivated when you need to skid the car to go out of a bad situation, (e.g. to start off on slippery road, to climb on hill slippery road, ...). When you push again the ESP button the ESP system will be activated back, and ESP warning lamp on dashboard will be turned off.
If you don't push the ESP button when driving, and the ESP warning lamp on dashboard will be turned on itself accidentally, the ESP system is faulty and it's not active! Then you need to go at workshop for repair the car!
Please do rate my response. Thanks!
Dec 22, 2010 | 2003 Volkswagen New Beetle Convertible
Television goes blank without warning for undetermined time
Power supply board have problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 02, 2010 | LG 32LC2D Television
How do you reset the "maintenance required" on a 2006 Lexus LS 430?
1. Push the “ODO/TRIP” button to change the display to
blank.
2. Turn the ignition off.
3. Turn the ignition switch to “ON” with the trip meter
“RESET” button held down.
4. Keep pushing the “RESET” button for longer than 5
seconds after the ignition is turned on.
After the above operation, the master warning light comes
on, a warning tone sounds and the message
appears to inform you that the engine oil maintenance data has been reset.
Sep 14, 2009 | 2006 Lexus Ls 430
Fixing an apartment sized GE range - pushbuttons don't respond
I'm not sure what your question is. Are you trying to find out why only one burner works? The top burners are simple and if you can work on it I can tell you how and what makes it works. The burners are as most ele. things. You have a line in, a switch, a load and a ground. The switch has 220v coming in. When you push a button it allows ele from the line to go to the element which is the load. Which button you push dictates the amount of ele that is allowed to go to the load. It should have a OFF, LOW, MEDIUM and a HIGH. If you check the wires between the switch and the element after you push the HIGH, you should show 220v. If not, you have a bad switch. I hope this helps like I stated, I'm not sure what your question is.
Please rate this solution
Aug 27, 2009 | GE Kitchen Ranges
Warning light on audi a4
This is the indicator for ESP (stability control). If you look on your dash, you'll see a button with, you guessed it, ESP written on it. This allows you to turn your stability control on and off. If your light is on constantly, try pushing the ESP button. If it flashes on and off (ie during hard driving) this simply means it is working.
May 15, 2009 | 2002 Audi A4
Zanussi zwf1430s error codes - E40 / E41 & ELE
hi
ele means the pcb is in factory settings . all you need to do is turn back off the on again then will be back to normal use. but e41 usally means the door lock has failed. does it click alot when you start it up and not do anything? if so this will be the lock
regards
Mar 19, 2009 | Zanussi ZWF1430W Front Load Washer
Warning light and on/off button flashing
Hi You can Try 2 things.
Ok try this may work
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 18, 2009 | Canon PIXMA MP170 All-In-One InkJet...
GPS Logo
53 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
