Question about Acer Aspire 5720-6661 Notebook PC
The underside of my Acer Aspire 5720 gets incredibly hot after only 30 minutes of usage. What could be the reason(s) and how best to solve the issue.
  • Acer Master
  • 11,800 Answers
2 possible reasons: a program in the background is running constantly at full power (open Task Manager, find it and uninstall it) or the cooler is clogged with dirt (use a can of compressed air and a q-tip to clean it). To remove some of that heat use a cooling pad.
http://www.newegg.com/Product/Product.aspx?Item=N82E16834993371
Posted on Jul 08, 2010
Acer Aspire 5720Z will not turn on please help me
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:
http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/replacement-acer-aspire-5720-ac-adapter-19v-3-42a.html
Nov 15, 2012 | Lifetime Acer Aspire 5720-4126 Replacement...
What's your problem?Acer 5720 ICL50 wont startup
Change the power supply unit out or button one of the two to solve this matter. Before a fire starts with the hot spot catching some dust particles, this has been known to happen............John
Apr 13, 2012 | Acer Aspire 5720-6661 Notebook PC
My acer 5720 laptop gets v hot and shuts down i sit it on a coolin pad already. what could the problem b it seems 2 hapen more often when the power cable is in use and only rarely when the batery is in use
This is a common problem in the acer line, remove bottom and clean all the open ports and fins on the heat sink and fan. Next remove the heat sink and clean the old conductive paste off, including the processor ic with rubbing alcohol, now! apply fresh conductive thermal paste to the heat sink and ic, this will increase the heat dissipation by 50%, and check to make sure the fan is running properly, "high failure rate" this should solve your shutdown problem.
Mar 26, 2011 | Acer Aspire 5720-6661 Notebook PC
My Acer Aspire 5720 wont power up, i have tried it with and without the battery, power goes to the power buttons led and fan for 8-10 seconds and then it cuts out ?
Motherboard problems. It's an Acer and they're notorious for having these exact issues about one year to two years after being bought.
Jul 26, 2010 | Acer Aspire 5720-6661 Notebook PC
Acer Aspire 5720, display no longer turns off
PLease go in control panet by pressing start buttan. Then click power option & change the sleep & stand by mode from there. Your problem will be solve then. Thanks.
Feb 28, 2010 | Acer Aspire 5720 6497 Laptop
Acer Aspire 5720 Laptop issues.
It could be the battery. So i'd try to find a store that sells batteries and replace the battery.
Manny laptops will shut off when the battery is dead. So if your laptop works without the battery and only connected to the wallsocket, it's definitely the battery.
With kind regards,
Jeffrey
Feb 16, 2010 | Acer Aspire 5720-4984 Notebook
Key board problem
It would seem that the keyboard may be defective. It is a fairly standard keyboard layout, so SHIFT-2 should produce the @ sign. It looks to be a fairly cheap fix:
http://cgi.ebay.com/New-Keyboard-for-Acer-Aspire-4520-5315-5520-5720-5920-_W0QQitemZ390088823197QQcmdZViewItemQQimsxZ20090901?IMSfp=TL090901179007r413
Sep 18, 2009 | Acer Aspire 5720-6661 Notebook PC
Reset bios password of acer aspire 5720 notebook
if u froget your bios password then u have to open the back side of laptop.then find the cmos cell then pull away it for 15 minutes then refix again .then it reset then it dont need any passworde.
Jan 19, 2009 | Acer Aspire 5720 Notebook
Acer Aspire 5720-6661 Notebook PC Logo
100 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
