Question about Carrier Siesta II TCA081B Air Conditioner
Carrier Siesta Thru Wall Air conditioner. Should the exhaust button be pushed in or left out?
Should exhaust button be in or out when ac running
Posted on Jul 21, 2010
How to properly install my carrier siesta air conditioner,seems to build up condensation that wont evaporate ,justwant the proper installation diagram ,orhow to do it yourself kinda video
condensation doesn't evaporate
it runs off the evaporator fins into a drain channel and out side
it is possible that the drain is blocked
the action of an air conditioner is to remove the humidity (condensation from the room) and drain it outside
if it is to evaporate then the purpose of the air conditioner would be defeated.
Jun 30, 2015 | Carrier Siesta II TCA101B Air Conditioner
Can I wash the filter or do I have to replace it?
I think you can wash it, but before you put it back the filter must be DRY. If there is moisture smell you also can put one or two car air refreshers (I do this to my AC).
Good luck.
Jul 13, 2012 | Carrier Siesta II TCA101D Air Conditioner
Does the Frigidaire FAH106S1T Thru-Wall/Window Air Conditioner recycle inside air or pull in air from outside? Also, how do I close the vent on this model?
yes it does recycle the inside air - it 'does not' pull outside air in (in the air conditioning mode).
The 'exhaust/outside air' vent - 'if it has one' (some don't these days) will usually be a manual pull/push lever, although I guess it might be a electrical/electronic switch.
hope this has helped.
Aug 05, 2011 | Frigidaire FAH106S1T Thru-Wall/Window Air...
No longer blowing cool air from our Siesta window AC
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 07, 2011 | Carrier Siesta II TCA101D Air Conditioner
Box on the wall. Push buttons
mode will be heat, cool, or automatic. cool will show a snow flake flashing. Heat will show a flame and auto will switch from heat or cool by itself. Usually the auto feature does not work well as one is unable to set the heat and air where they are comfortable on both
Jul 27, 2010 | Carrier 38CKC036 Air Conditioner
Where do i find the model # on my siesta
Since 'TCA101D' - is your model number I'm assuming you're looking for the Serial Number - which is located on a metal/paper tag located usually on the front of the unit, which btw will also have Btu's, Voltage, Amps, and Model Number.
Often this tag is on the plastic front cover of the unit.
May 15, 2010 | Carrier Siesta II TCA101D Air Conditioner
Hi. I just need to get a small knob for a Carrier Siesta II TCA087D air conditioner, and nobody in Australia has a clue as to where I can find one...not even Carrier!Regards, Sharon
I have a small knob for a Carrier Siesta II TCA81D air conditioner. I do not know if it would be the same size as one for the TCA087D. I can send this to you from the US, no charge. I know what a hassle it can be to solve this kind of problem.
Jan 04, 2010 | Carrier Siesta II TCA101B Air Conditioner
I have a 51GR Carrier window air conditioner and the
TRY:
Power off (Disconnect)
Push together "Temp up" and "On/off" and reconnect power while pushing.
Jun 14, 2009 | Carrier 38CKC042 Air Conditioner
Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Feb 25, 2008 | Carrier 52PQ307 Wall/Window Air...
Carrier Siesta II TCA081B Air Conditioner Logo
341 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
