Question about Krups FBC112 1600 Watts Toaster Oven with Convection Cooking
I have a Krups Toaster Oven and the door spring is non-functional. Can I replace it and can you provide parts and installation instructions?
SOURCE: Door spring broke on Cruisinart CTO 350 series Toaster Oven
I had same problem with my cuisinar 350 series broken door spring. After disassembly found a broken extension spring measuring about 3/16 dia.,by 6.5 inches long.Spring was broken about a third down. I lifted ,or bended a loop and a halve up from each broken section and joined the two sections together. lifting each loop of the spring is tricky at first, requires a small screwdriver to be inserted between loop to be lifted and then gently bent the loop with needlenose pliers.
Not knowing how to disassemble the unit I had a hard time assembling the unit back.
I would start by taking off the screws holding the front black backlite first, then the main cover.
The main stainless steel cover does not have to be removed completely, by just gently unbending
the cover I was able to access the spring for removal.
Lots of luck
Posted on Nov 10, 2010
SOURCE: krups fbc2 toaster oven cuts off while toasting
returned it to vendor and asked for exchange.  decided no way I should fix it after less than 5 days of use.  Curious if others have encountered a similar problem.
Posted on Sep 28, 2008
  • 3 Answers
SOURCE: My Krups FBC 1 toaster
Most of the time a hardware store will have a variety of springs or try home depot.
That's if you only don't want to wait for a manufactors spring.
Posted on Dec 20, 2010
SOURCE: setting clock on krups toaster oven
When the oven is first plugged in "12:00" appears on the display.
• Press the "Timer" button twice. The display will begin to blink "12:00".
• Adjust the time in steps of one minute by pressing the "+" or "-"
buttons.
• If you hold the button pressed down for more than 6 seconds, the
time will change quicker.
• Press the "Timer" button to enter the time in the system.
If you do not press the "Timer" button, the time will be
entered automatically after 30 seconds.
Posted on Jan 11, 2011
tbreeze47
  • 3083 Answers
SOURCE: My Krups toaster oven bakes,
It might be abe to be fixed, but you should contact Krupps for support, since they have the parts. Here is their support site:
http://www.krups.com/Consumer+Services/Product+Support/Manuals/Use+Intructions.htm
They might be able to refer you to a nearby authorized service center, or offer a swap out, but see what they say.
Good luck, and hope this helps.
Posted on Jan 26, 2011
Where can i get a diagram of a Krups FBC412?
Maybe Krups can provide the diagram if you inquire.
Aug 20, 2016 | Krups FBC412 1600 Watts Toaster Oven with...
Door Replacement
  1. To fix a cocked door, open the door and loosen the screws securing the inner panel. Hold the door at the top and twist it from side to side to seat it securely on its hinges.
  2. Partially tighten the door screws; do not overtighten screws on a porcelain door because the surface may chip.
  3. Test the seal by inserting a piece of paper between the seal and the top corners of the oven. The seal should tightly grip the paper.
  4. To replace cabinet-mounted springs, remove the storage drawer and the oven door. Unhook and replace the springs. Replace both springs even if only one is broken.
Hope that helps..........
Jul 01, 2008 | Krups FBC5 1600 Watts Toaster Oven with...
I need a Manual for a Krups Counter Convection Oven
Krups has one manual for the FBC2, FBC3 and FBC4 models. Start here: http://www.krups.com/Consumer+Services/Product+Support/Manuals/Use+Intructions.htm and use the drop-down menu on the left to select Toaster Ovens. Then select the FBC2. Click on the green and black icon to download the manual. The direct link to the manual is http://www.krups.com/NR/rdonlyres/5605B757-078E-4DF1-9DED-A884209066C8/4351/TOASTOVENFBC234_usa.pdf . The manual is also available here: http://static.highspeedbackbone.net/pdf/TOASTOVENFBC234_engusa.pdf . You can also get this manual from the Krups FBC2 product page: http://www.krups.com/All+Products/Toaster+Ovens/Products/FBC2/FBC2.htm . Click on the Instructions link.
I hope this helps.
Jul 27, 2016 | Krups FBC4 1600 Watts Toaster Oven with...
Why are the control buttons operate intermittently?
Sounds like there is a loose wire connection. Have you contacted the manufacturer?
Aug 11, 2014 | Krups FBC212 1600 Watts Toaster Oven with...
Tension spring on door
I found the answer (see below) posted on another web site. I followed the instructions and replaced the spring. I found, as the original poster had, that the new spring works better than the original and is much more sturdy. To the original instructions, I would add the following:
1) There are about 20 screws so have patience removing and replacing the screws.
2) Step 3, "Slide off the rear panel" requires further clarification as the panel will not slide off even with all screws removed. I had to turn the oven over, with the top of the oven sitting on the work table. I then used a screw driver to lift the two tabs that hold the back panel to the bottom panel. With the tabs lifted, the back panel will rotate away from the oven along the edge where back panel slides into the top panel. The back panel can then be slid out. I have included three photos that show this step.
3) Step 7, "Re-attach feet": Be sure to use the guides on the bottom of the oven to slide the foot assembly onto the oven. I had unsuccessfully tried to screw the feet onto the oven without using the guides.
Oringinal instructions for replacing the broken spring:
Just repaired this yesterday.
Got a spring from Lowes (Hillman Part # 543028 for about $4), it's larger than the original but seems much sturdier, original is really thin metal. Fit the space provided without problem.
Oddly, end result was a more 'giving' spring action, prefer it to original, which loved to snap shut unless door was 100% opened (ie fully 90 degree open).
This is for BOV800XL:
1. Remove all rear screws
2. Remove feet entirely
3. Slide off rear panel
4. I was not able to remove top housing - but I was able to gently pry sides open just enough to thread the new spring with a little ingenuity and effort. Watch out for sharp metal edges everywhere.
5. Slide back in (remember that top edge goes under the top edge/lip)
6. Put all screws back in
7. Re-attach feet
7a505b80-f785-4973-b674-12594d9dcb1d.jpg 2e67ee3d-99c9-4e88-8b9f-8d1721e5caa6.jpg 529808f4-8d72-4aea-8286-b525347addee.jpg
Apr 02, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
We have a Krups FBC4 1600 Watts Toaster Oven. The door hinge seems to have disconnected from some kind of spring mechanism within the left wall, is there any way to take apart/repair it or have it...
Here is a Krups website address that helps you locate service by state or contact the Krups company.
http://www.krupsusa.com/Consumer+Services/Service+Centers/List/CentersList.htm
Apr 08, 2011 | Krups FBC4 1600 Watts Toaster Oven with...
I have a fbc2 krups convection oven and the handle is broken. is there a replacement for this?
Molly, there appears to be some replacement parts available:
this is a link for the oven door and handle, which appear to come together: http://www.smallappliance.com/product.asp?pid=2478&cur=USD&sid=18956&gid=18984&pfor=2805&shopBy=Category this site is referenced as authorized by Krups, but Krups did not show this replacement part in their online store.
this is a link for the tray handle: http://www.krupsonlinestore.com/product_detail.asp?T1=KRW+SS%2D185298&MENU=parts&SELECT=toasterovens&SKW=PARTFBC2 for 1.99 from Krups, and http://www.smallappliance.com/product.asp?pid=2479&cur=USD&sid=18956&gid=18984&pfor=2805&shopBy=Category for 8.99 from smallappliance.com, referred by Krups.
Hope this is helpful.
Dec 22, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
My Krups FBC 1 toaster oven has a broken spring for the glass door.
Dec 19, 2010 | Krups FBC1 1600 Watts Toaster Oven with...
How do you change the top heating element on the krups fbc 412?
Based on the markings on the sockets, there are 400W ones in the center and 600W ones on the front and back. That adds up to 1600W on each, the advertised total. So be sure you have the correct replacement. After removing the cover you will see that each one has spring connectors.
Aug 08, 2010 | Krups FBC4 1600 Watts Toaster Oven with...
Krups fbc2 toaster oven cuts off while toasting
Sep 27, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Krups FBC112 1600 Watts Toaster Oven with Convection Cooking Logo
256 people viewed this question
Top Krups Toaster Ovens Experts
warcraft demonhunter
Level 1 Expert
Are you a Krups Toaster Oven Expert? Answer questions, earn points and help others
