Question about Car Audio & Video
I would like to know how to wire a amplifier it is a bLAUPUNKT,premium sound amplifier. (9m-wk) holden No:92117019?,and a pioneer subwoofer, to a kenwood cd-receiver. kdc-139.the kenwood is already in the car using the instruction manual,just would like tpo know which wires go from the amp and the subwoofer, to the kenwood receiver as there is a lot THANK YOU
  • ghostride90 Jul 10, 2010
    i have a kenwood receiver kdc-139 in my car,i put it in ,it it has no remote contrl. i dont know what he is talking about with the remote turn on wire, my question isn how to connect the amp, which is a:
    Blaupuket premium sound amplifier (am-wk)
    holden no:92113388 gm:92117019.?
    wires from the rear of the amp.
    1.dark green with light green wires
    2.lite brown with grey.
    3.lite bule with dark blue.
    4.yellow with green strip.
    5.green with white strip.
    then from the other side,in a bunch of wires.
    8 wires
    red
    red and black
    white
    white and black
    then theres a yellow,brown,green and purple.
    next bunch
    dark blue
    dark blue with white strip
    light blue
    light blue with black strip
    dark green wire
    light grren with black strip
    white wire
    brown wire
    which wires do i use and which one can i leave out. also i wont to connect a pioneer subwoofer
    THANK YOU
  • ghostride90 Jul 11, 2010
    do you know were i can download an instruction manual for a example holden moter company for a Blaupuket premium sound amplifier (gm-wk) holden no:92113388.
    THANK-YOU
    President:
  • 1,851 Answers
Talking in general you have to connect the "line out" from the cd/receiver at the "line in" of the amplifier and the "sub out" from the amplifier at the subwoofer. In case you need detailed informations provide me the model for the amplifier & subwoofer (I assume that the cd/receiver is a kenwood kdc-139)
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jul 11, 2010
  • 2,272 Answers
How to wire the Amplifier to sub-woofer and then to receiver(HEAD UNIT) :-- 1) Gather your equipment (Amp, Subs, Stereo, and wiring). You can find wiring kits at most stores, ~$40 for 4 gauge wiring and In-line fuse, you won't need anything larger than 4 gauge. 2) Run your amp wires (battery, ground). Figure out where you're going to place the amp, put the beginning of your power (red) wire there and give it about a foot of wire extra, then begin to hide and run the power wire to under the hood. If you need to drill a hole in the fire wall, be careful not to hit anything on the other side. Make sure this wire is safe from any moving objects. 3) Detach the power cable from the battery and attach your sub's power wire to the power cable for your vehicle; leave it unattached. If you bought a kit it comes with an inline fuse, if you didn't you need to get an inline fuse. Just cut the power wire, insert the inline fuse and reattach. 4) Place the amp where you want it, then attach the ground (black or brown) wire to the amp. Ground it to a piece of bare metal (not painted); most people unscrew a bolt from a seat attach the wire and screw it on. 5) Now for the RCA jacks, if you're going to use your stock stereo and run the amp from there you want to buy a LOC (Line Out Converter) ~$20. with the LOC you get a small box with 2 RCA's coming out and 4 speaker wires out the other, you want to take out a door speaker and run 2 of the 4 speaker wires to it, pay attention to the pos. and neg. You don't need the other 2 speaker wires, from here secure the loc out of sight and run the RCA's to the amp, plug them into the "IN" RCA jacks. If your using a after market stereo on the back there is 2 RCA jacks, just run the RCA from there to the "IN" on your amp. 6) Soldering 12v power and ground connectors to the wires will reduce circuit resistance and make your power cleaner, giving you better sound.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • 11,896 Answers
On the back of the deck, there is RCA jacks. Use the ones that say REAR output. The cables go from the Rear output jacks on the deck to your amp rca jacks.
Also on the back of the deck, is a blue wire that says Remote wire. The wire gets connected to the REM on the amp.
(that way amp turns on when you turn your key on)
The RED positive (+) wire on amp goes directly to your battery.
The BLACK negative (-) wire from amp gets directly connected to your trunk. Find a bolt to remove, scrape a bit of pain off the surface, put cable on it and tighten it down.
Then there is the sub. If you are using 1 sub. Put Red positive (+) wire on Left channel ( + ) of amp and the black negative (-) wire on the Right channel negative ( - ) on amp
If you hare using two subs, then one sub goes on left channel and one sub goes on right channel on amp.
I install these for a living as part of my business so let me know if there is anything you need help with
  • ghostride90 Jul 16, 2010
    The problem is i want to now what to do and with all the wires comeing from the BLAUPUNKT amp as there is about 35 wires comeing from it. I have already witten out all of the wires and once again i will wite out what sort of amp. It is a bLAUPUNKT,premium sound amplifier. (9m-wk) holden No:92117019?
  • 5,807 Answers
Hi
ghostride90,
1st have the bLAUPUNKT amp, electrical connections set
be sure it turns on properly.
2nd If it turns on properly , then you have a choice to use " Bridge "
( lot louder ) or a single amp .( for speaker connections )
• Connect the positive side to the positive out of the amp
• Same with the negative ( Pioneer Subwoofer )
Connect either L or R output of your Kenwood CD Receiver to the
Audio IN of your amp respectively.
Let me know , if you need more assistance , so I can post
further to help you resolve your connection problem.
Regards
Posted on Jul 10, 2010
  • 13 more comments
  • Rommel Cana
    Rommel Cana Jul 10, 2010
    Does the Kenwood Receiver turns on?
    If it does , then you need the wires that need to " turn on " a separate amp.( like yours )
    On most , it is Blue /White
    you may need to have these
    How
    to test for Continuity
    How to use a multimeter
    To confirm
    I'll post further
  • Rommel Cana
    On your Kenwood KDC 139
    • At the back of the unit
    Here is your option A, if there is a corresponding input in your amp ( RCA input )
    If, there is none on your amp, then we may need to connect it through the speaker out
    of your Kenwood CD Receiver ( Option B )
    I'll post for more
  • Rommel Cana
    the manual for the above can be downloaded here :
    http://manual.kenwood.com/en_contents/at...
    http://ae.kenwood.com/Car_Entertainment/...
    • And these would possibly matched ( Option A ) with these kind of amp VA1400
    While I still look for more possible solution , Is that harness OEM or aftermarket?
    Can you be able to look inside the unit?
    • And try to look for the biggest capacitor that you can see inside the amp,
    ( If can , the positive of that capacitor goes to the + side of your Battery , the second one
    could be any among the wires )
    Of course the body ( amp ) is to be connected on the chassis of the car ( negative )
    • If your amp is similar to the above ( which might not be ) , then try to find the Model number
    • If your amp differs ( which probably is ) , then once it turns on , there will be voltages on each
    output ( going to speakers ) at about +6V , if it is having bridge type Audio IC inside
    • If it is not , then the output is coupled via a series capacitor ( less likely )
    Still looking!
  • Rommel Cana
    here is an image of a sample Blaupunkt T harness
    The Blaupunkt system uses a vehicle-specific Plug'N'Play T-harness
    that connects between your radio and factory plug. The harness contains all the power,
    signal, and speaker wiring necessary to connect the Blaupunkt amplifier to your factory
    stereo. Once the T-harness is connected
    However,
    The Plug'N'Play system works only with select vehicles
    and should not be use in factory systems that include external amplifiers.
  • Rommel Cana
    here , another sample image:
  • Rommel Cana
    Rommel Cana Jul 11, 2010
    Basing on the data above, The harness is very specific to car specifications.
    So, if you need to connect the said amplifier, Color Coding of the wire, will be just a display
    for a moment.
    I cannot guarantee it will work, unless you may have to open the Unit and check for the things
    I have mentioned above.
    First , you need to power the amp ON, then connecting your input and speaker will be later.
    If these step is not followed, connecting anything will possibly damaged either/ or both
    of the two units.
    Have the Kenwood wired and working?
    have you found the " remote ON " ?
    These may be a long shot, but these is how it works!
  • Rommel Cana
    These is an image of a sample capacitor:
    • Find the one that the positive terminal ( capacitor ) is connected to wires going out of the Amp
    And the negative going to the chassis.
    • that would be your Main +12 ( to be connected on the battery +12V )
    • Most of the wires , will go to an output and input stage, but there is one wire that would be
    the " Remote IN " to turn on your Unit ( Amp ).
    And these is your secondary objective.
  • Rommel Cana
    On the group :
    " then from the other side,in a bunch of wires."
    8 wires
    red
    red and black
    white
    white and black
    • These are possibly your Input ( But we will check these later )
    " then theres a "
    yellow,
    brown,
    green
    and purple.
    • Either of these last four, could be your remote IN or main B+ 12V
    • Use a multimeter to verify, But do not connect it to battery supply yet.
    Is there a connector that looks like any of these?
  • Rommel Cana
    • To find the " Ground " , negative of the Amp,
    Set the Multimeter to continuity
    Look and find for the four colors
    namely
    yellow,
    brown,
    green
    and purple.
    Either of these , could be connected to the chassis of the Amp.
    Once these is done , other wire will lead us to the supply and post back what you find .
    Include the resistance value ( also in reverse of the Multimeter probe )
  • Rommel Cana
    Rommel Cana Jul 16, 2010
    • Not knowing the Model of your Car Amp and having a very little details on your unit , would be
    hard to find, and may not be available for download.
    • To have the complete details , you may need to specify which car , it has been formerly
    connected , these would at least narrow down our search.
    • You are looking for a data that is very specified for a certain specific car.And transferring it to
    another car, would void the unit warranty and may damage the unit , if not done properly.
    Here is a link for example:
    http://www.holden.com.au/owners-info/tec...
    • Have someone to help you trace and look inside the unit, These could be a more sure thing to do.
    once you have identify the ground ( negative ) then more to follow next.
    You can post images, if you want to, so I can encircle , and give you more possible solutions.
    Regards!
  • Rommel Cana
    • These unit can only be successfully connected once it powers up.
    But you might be having a Compatibility Problem connecting your Kenwood Unit.
    We will never know till the unit power up, Once it powers up, we will try to find
    a suitable input source for your Blaupunkt Amp ( which I feel do not have RCA input ).
  • Rommel Cana
    For whatever data you can download, you can never be sure , It is really right, till you open the unit
    and cross check it with a
    Multimeter
  • Rommel Cana
    While we are still looking for your Wiring guide,
    • Have the Kenwood Unit powered , and check if it can run separately.
    Meaning it can drive speakers,
    • You will be needing that output terminals to drive your Blaupunkt Amp
    • Once it does , connecting your Blaupunkt Car Amp will be to follow.
    ( If the Amp , is powering up ).
  • Rommel Cana
    Rommel Cana Jul 28, 2010
    Have you tried opening your Amp?, I can help you further if you can give me details.
  • Rommel Cana
    Rommel Cana Aug 04, 2010
    • have you opened up your Amp? and see what is inside?
    Even a low cost analog multimeter can detect which is which.
    ( set on R X 10 )
  • 677 Answers
Hi,Things You'll Need:
  • Amplifier
  • Subwoofer
  • Power Wire (~17ft: 8 AWG or lower)
  • Ground Wire (~3ft: 8 AWG or lower)
  • Remote Turn On Wire (~17ft: 18-14 AWG)
  • Speaker Wire (~3ft: 14 AWG or lower)
  • RCA Cable (~17ft)
  • Fuse and fuse holder
  • Phillips Head Screwdriver
First, under the hood of your vehicle, disconnect the cable from the Negative (-) terminal of the battery. This will prevent any accidental short circuits from happening while installing your amplifier.
Locate an area under the hood where you can mount your fuse holder. Be sure to find an area that is as close to the battery as possible since the fuse can only protect against a short circuit if the fuse is within the short circuit. Once you have located an area, drill and screw your fuse holder in place.
tep 3 i would like to know - install-car-audio-amplifier-subwoofer-1.3-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep3 span.image a:first').attr('href','http://i.ehow.com/images/a04/kq/rh/install-car-audio-amplifier-subwoofer-1.3-800X800.jpg'); }); Sample firewall pass-through grommet From inside the car, locate an area, preferably an existing protective rubber grommet, that will provide an easy pass through the firewall and under the hood. The image to the left shows an example of an existing rubber grommet that provided access from inside the car to the area under the hood. Once you have located this grommet, try pushing the power wire through it from inside the car. If you are unable to do so, puncture the grommet a couple of times with a screwdriver and try pushing the power wire through again.
Once you have pushed the power wire through the grommet, find the power wire under the hood and pull enough slack to connect the wire to the fuse holder. At this point, you may place the fuse in the fuse holder and attach the power wire that has been fed through the firewall to the fuse holder. You may also connect a short power wire from the positive terminal of the battery to the other side of your fuse holder.
p 5 jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/kq/rh/install-car-audio-amplifier-subwoofer-1.5-800X800.jpg'); }); Rear seat removal Route your power wire through the car and into the trunk. Generally, a good place for routing the power wire is along the drivers side edge of the carpet. This is usually held on with plastic fasteners that can easily be pried loose and refastened. Removing the rear seat will also give easy access to the trunk. The rear seat is usually held in place with two clips that are located under each 'bucket' seat. Sometimes there is also a bolt the holds the seat in place.
6 install-car-audio-amplifier-subwoofer-1.6-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.com/images/a04/kq/rh/install-car-audio-amplifier-subwoofer-1.6-800X800.jpg'); });
Posted on Jul 08, 2010
  • ikechukwu joshua
    ikechukwu joshua Jul 08, 2010
    RCA and Wire Routing
    Gain access to your aftermarket CD receiver or stereo headunit with RCA outputs and remote wire hookup. Once you have access, connect your RCA cables to the Subwoofer Output (SUB OUT) and also attach the remote turn on wire to the 'RMT' or 'REMOTE' wire on your CD headunit (usually a blue wire). Run these wires back to the trunk to the amplifier location as you did with the power wire. To prevent noise from entering the system, run signal and speaker wires down the passenger side of the vehicle and keep them separate from the power wire.
    Connect the Power Wire to the '+12V' or 'PWR' connection terminal on your amplifier, connect the remote turn on wire to the 'RMT' or 'REMOTE' connection terminal on the amp, and also connect the RCA connectors to the RCA Input on your amp.
    Crimp a ring terminal to one end of your ground wire. Find an existing bolt in your trunk that you can attach the ground wire ring terminal to. If one does not exist, find an area that will be covered by carpet where you can drill a whole and place your own bolt. Be sure to scrape away some of the paint to achieve good conductivity for the ground wire. Now, attach the ground wire to the 'GND' or 'Ground' connection terminal of your amplifier.
    Connect the subwoofer to the amplifier with your speaker wire. Make sure that the positive (+) terminal on the subwoofer is connected to the positive (+) terminal on the amplifier or your subwoofer will be out of phase 180º.
    Now, reconnect the negative terminal of your battery and check to see that the amplifier turns on and that the subwoofer is audible. Once you have ensured that everything is properly connected, reassemble your car and enjoy the bump!
    Tips & Warnings
    When choosing your power, ground, and speaker wire, make sure that you are using a gauge of wire which is suitable for the amount of power that it will be delivering.
    Select a fuse that will be only slightly larger than the current that your system intends to draw. Selecting a fuse that is far too large can cause the wire to heat up and cause melted insulation and possibly catch fire.
    Anytime your are working with electricity there is always the potential for danger.
    Make certain that the negative terminal of the battery is disconnected while working on anything electronic with your vehicle. This will prevent a lot of accidents.
Lost Code for 2000 Holden Astra Blaupunkt 520 Radio
i dont know the code but if you contact the manufacturer maybe a technician can help you no promises i had a few that knew less than me best of luck with your problem
Mar 03, 2013 | Car Audio & Video
I have a pioneer gm-354 amp and the power indicater light on the front has changed from solid to flashing and no sound from the amp to the subwoofer it used to power any idea's
If it is flashing it went into the protect mode.Check that a speaker wire hasn,t come off, Or that the ground cable conection is good end all other hook up wires to it.
Oct 27, 2012 | Pioneer GM-X354 Car Audio Amplifier
Ineed to know my blaupunkt car radio code nomber for a holden vectra equipe 2001
Hi,I have a 1999 holden vectra we replaced the battery and radio needs some code! Could anyone help me about this?
Radio No. 92 057 951
Type. Blaupunkt 520
On the sticker big U1E sign
And Some Bar code .BP8393W0791670
Thanks
Endre
Feb 16, 2011 | Car Audio & Video
Is the pioneer ts-a6815 a good replacement for stock 2009 premium sound system?
Depends on the manufacturer of the premium sound system.I replaced my premium stereo(JBL) with pioneer mids and highs and yea they were a heck of a lot louder and the sound was like brighter and better all around but i put in a new deck and had a amp running them so i dont know if that helps you.
Jan 10, 2010 | Pioneer TS-A6815 Coaxial Car Speaker
Which terminals to use
if your amplifier is 2 ohm mono stable - you can wire them in parallel.
Put a piece of wire from one + terminal to the other + terminal on the subwoofer.
Then do the same to the -.
Now pick one pair of teminals from the subwoofer and wire it to the amplifier. (one set of subwoofer terminals will have 2 wires each).
If you reply with your amplifier make/model, I can tell you the best usage.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 30, 2009 | Pioneer TS-W307D4 Car Subwoofer
Blaupankt 520 Car Stereo, for 2000 Holden Astra
take it apart and then use the serial code numbers any (4) also jumble
Apr 09, 2008 | Blaupunkt PCA250 Car Audio Amplifier
2000 Astra Blaupunkt Stereo
Leave SWITCHED ON...UNDISTURBED for a couple of hours
Apr 07, 2008 | Blaupunkt PCA250 Car Audio Amplifier
Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Oct 24, 2006 | Pioneer GM-7200M Car Audio Amplifier
Car Audio & Video Logo
543 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
