Question about Hobart Handler 125 Ez
Installed new spool wire tangled in wire feed compartment and stopped. Now wire feeder doesn't feed.
    Genius:
  • 1,212 Answers
If the feed wheel mechanism does not move, check for voltage at the motor. If there is none present, you need to look for a failure on the control board, which may be a fuse, or even one of the SCR's. Often an 8 amp 200 volt type.
Posted on Dec 29, 2011
A new welding machines lincoln 500s with wire feeder linc feed 45 co2 gas shielding ... when i begin the welding process continueous just for 10 seconds and then the wire feeder stop and then after 50
the obvious, yet sometimes overlooked problem is to check if the wire feeder rollers.do you have the proper tension set?(did you do the wire test when you shot the wire to see if it bends or stops)
Apr 11, 2013 | Lincoln Electric Welding Tools
Have a lincon 255Xt mig welder. You push the triger and it feed and try to weld and it arces then it stops right a way. Let go of the trigger and push the trigger and it feeds again. What is are problem?
Have you checked the tension on the wire roll feeder? Inside the unit where the spool is, the wire feeds off of the spool, through the feed roller, this roller has a tensioner spring on it that keeps the wire flowing steady, and also check the spring tension the keeps the spool from turning freely, keep this loose as can be, and just enoughthat it doesn't unwind on it's own.
There are so many things that it can be, but this is a start.
Good Luck.
Paul
May 07, 2010 | Lincoln X2688 2 YR EXTENDED WARRANTY FOR...
Wire quit feeding checked motor and tested good was welding when wire quit spooling visibly all pc board compononents look good checked numerous things feeling lost on this one any guidance would be...
if motor and feeder roller is turning. check that their is the correct pressure on feeder roller for the wire thickness you are using and that it is in the right groove on those rollers.
also check the tip it may have splash buildup which is affecting the wire feed.
hope this helps
Mar 03, 2010 | Welding Tools
Brother 8500D sewing/emb machine - upper thread stops feeding
If the thread is hanging up at the spool - this could be the way it was manufactured, a nick in the spool end or the thread is unwinding too fast, puddling and wrapping around the spool pin.
Keep the bobbin case and surrounding area clean and free of thread tangles and snips. Thread tangles in this area can cause the machine to stop.
When the presser foot is down on any sewing machine, the tension closes and you cannot manually pull the thread through.
Sulky and C & C black tends to fray more than other brands of thread.
If the problem continues, the machine will need to be serviced by a professional.
Feb 24, 2010 | Brother Sewing Machines
Feeder motor on hh135 works fine with constant trigger pull but slows to stop when you work trigger
Check the wire feed does not become obstructed when the trigger is pulsed. The wire can become tangled on the roll if it is able to get loose. The reel tension must be adjusted as the weight of the roll decreases.
Nov 23, 2009 | Welding Tools
My welder just stopped welding. It's a Telwin 220 Mig. The fan is still running but there is no noise from the welder and the wire is not feeding. I had only used it for around 30 seconds before it...
your feeder may need adjusting or more commonly the tip has tacked itself on the edn cap
keep the line as straight as you can & keep feeder compartment clean!
keep plyers handy for when wire is stuck in the tip
if you need to replace wire spool or a brakage of the wire make sure the wire is free or BURRS b4 you put it in the tube or you will damage the tube!
Cheer Rob.
Jul 16, 2009 | Astro Pneumatic 3 Pk. MIG Welder Torch Tip...
I have a shakespeare sigma fishing reel that tangles up when I cast it, any solutions
The line needs to installed on the reel as it is on the new spool when purchased. Also check spool drag. If it is a spinning reel it is important to install the string correctly and use a quality brand of string.
May 18, 2009 | Shakespeare Surf Fishing Rod and Reel...
Line gets tangled in gear under feed spool
Problem solved. We noticed something was broken off a small part inside the spool holder. My husband took it to the local hardware store, and one of the employees gave him the part from a trimmer that had been returned.
Apr 06, 2009 | Black & Decker St7000 13'' Automatic Feed...
Hobart Handler 125 Ez Logo
161 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Troy
Troy
Level 1 Expert
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
