Question about Jensen VM9410 Car DVD Player
Quick splice should i have to quick splice any wires for my reciever
  • 4,102 Answers
Hi do you have a wiring diagramme for this or not.
Alot of people who fit these think they can use it whilst driving but the problem is they are designed to only work when the handbrake is on they do this as a safety device but the problem you have with this is you need to find another source thats permanent to get round this but getting this wrong can blow the whole lot. Some wires are higher output than the dvd player so you could short it out.
Is this what you mean if not then sorry but let me know ok then i can assist you further ok
Posted on Apr 18, 2008
I cut the trunk light wire 2003 cavalier. How to fix it
If you are saying you need to put it back together after cutting it..just go to a local auto parts store like Napa or autozone and ask for a quick wiring splice kit or just a wire splice connector ..they will guide you...good luck..
May 02, 2016 | Cars & Trucks
I have a kdc-mp142wm what other recievers would plug right into the existing harness?
There are wiring kits you can buy that have the proper connectors on both ends of the wire harness so it will match up with the radio and the car's wiring harness. No cutting or splicing involved. Just push the connector into the radio and the car's original radio plug connector.
Jan 01, 2016 | Kenwood Car Audio & Video
I want to disable or remove the immobiliser from my 1991 MR2, its a laser line immobiliser thats a real pain, a bit tempermental can it be removed easily
Being your's is a add on unit it will be easier than factory. I would start with contacting "Laser Line", for an installation manual or wiring diagram of your unit. Finding all the components and related wiring would be my next step. Looking for the original cars factory wiring that was spliced to fit the immobilizer. You may have to get your hands on a wiring diagram of your car to check the routing of related wiring. It should be wired to the intercept power to the distributor and the fuel pump. Before the cars computer. As always, add on kits such as this where done quickly by a person more versed with radio installs than anti-theft devises. So looking for out of place wiring, easy to access or get to locations, botched splices and electrical tape where there should not be, are keys to the location of add on wiring. Looking for the org. cars factory wiring colors and sizes, following the routing you will find cut wires spliced to different colors and sizes. Hope this helps FixYa up.
Aug 27, 2011 | 1991 Toyota MR2
I have 2003 v-star classic with the silverado package. Along each side of the main head lamp it has the running lights on the front. I have lost the use of the two side running lights. Can you guys show...
Have had the same problem, same bike. Dealer installed the additional running lights so they come on with the low beam headlight. Go off when the high beam is turned on. Mandatory for my state inspection procedure.
Possible solution to problem: open the headlight housing, should be a solid green wire going to the headlight bulb. Dealer spliced wire for running lights into this green wire.
Splice was just a crimp on splice. Vibration on a bike wipes out this type of splice quickly.
Got rid of the crimp on connector and did things the old fashioned way, used solder for the connection. Vibration does not bother the soldered connection.
Took care of the problem
Apr 04, 2011 | 2003 Yamaha V Star Classic
I bought a place with intermatic malibu outdoor lighting. The wire on the light fixture was broken when bushes were taken out. I can't find any instructions on how to connect a new fixture to the...
Malibu low-voltage light fixtures come equipped with a quick-connect that is pressed onto the power cable to make connection to the wires within it. These quick-connects are handy, but they are also relatively fragile, subject to shorting/disconnections, and nearly impossible to repair. I have spliced a replacement connector's wire leads onto the wire leads from a broken fixture, but the connectors are nearly impossible to find (I remove mine from fixtures that are beyond repair). Perhaps the simplest and most effective repair is to strip small sections of the power cable, splice the fixture wire leads onto the cable (don't be overly concerned about matching polarity), and seal the splice with electrical tape and a silicone sealant.
I hope this information helps.
Bill B.
Nov 23, 2010 | Home
I recently replaced a stock radio in my mothers car, a 2004 subaru forester. I have done this before in my honda by cutting and splicing the wires and using no wiring harness. except this time i thought...
you may have spliced into the illumination wire as your auxillary power. use a volt meter to check and see if either of your power wire recieve 12.0 to 13.8 volts when you have your headlight on. if you do then you have used the wrong power wire
Aug 24, 2010 | Car Audio & Video
Yamaha htr 5240 receiver, need fm antenna adapter
this is your manual http://www2.yamaha.co.jp/manual/pdf/av/english/re/HTR-5230.pdf
this is the 300 ohm adapter you need from radio shack and just install some small gauge speaker wire to it. or just splice the one that came with your receiver.
http://www.radioshack.com/product/index.jsp?productId=2062054
Feb 26, 2009 | Yamaha HTR-5230 Receiver
Wire attached to the Positive Battery Cable
disconnect power, with dvom ( volt meter) check for continuity in wire that was spliced. possible bad connection.
Jul 05, 2008 | 1999 Dodge Intrepid
Wiring
I suspect that your harness may be the culprit. Examine the power wires on it. There should be two (one yellow, and one red). If you did any splicing of wires... perhaps the splices are faulty.
Jun 07, 2008 | 1998 Honda Civic
Hook up problems
either cut an rca cable and splice it to the speaker wires (not easy because the rca cable is coax type or buy rca ends from radio shack and do a little soldering
Jan 02, 2008 | Sony STR-DE835 Receiver
Jensen VM9410 Car DVD Player Logo
46 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
