Question about Lexmark X2600 InkJet Printer
Hi, my lexmark x2600 paper load light keeps blinking. I think my daughter was messing with the buttons.
  • clammer42 Jul 09, 2010
    Printmastert, I tried as you directed above but no luck. I can't see any paper jamb if I look in the top feed or throught the output area. Any other suggestions?
  • Official Brand Answer
  • 3,344 Answers
Try to remove all sheets of paper. Then unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Leave the other end of the power cord attached to the power outlet in the wall. Wait at least 30 seconds before plugging back the power adapter in the printer. When the printer's ready, load some papers and check if it's working fine now. Keep me posted by leaving a comment. Thanks.
Posted on Jul 08, 2010
  • Lexmark
    Lexmark Jul 09, 2010
    How about taking out both the cartridges from the printer. Then close the cover. Unplug the power adapter. Plug it back after 30 seconds. When printer's ready, reload the cartridges.
Lexmark x2600 won't recognize new print cartridge
It insists there is a Cartridge problem on the Printer............ In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Blinking Stopped...........Issue Resolved....... Still Blinking: Remove both the Cartridges take a Paper Towel turn the catridges direction so that u can see a Copper plate with small boxes on it....... Just wipe it twice or thrice with the Paper Towel.......... Now insert it and Power on the Printer and see whether the Lights are still blinking if it is still blinking...... Contact Lexmark at 1-800-539-6275!!!!!
Good Luck!!!!!
Apr 02, 2013 | Lexmark X2600 InkJet Printer
Cant find sacan button on lexmark x2600
The Lexmark X2600 scan button on the printer operator panel looks like this printmastert_86.jpg.
For more information on how to scan using your model, please refer to the Lexmark X2600 User's Guide.
Oct 16, 2011 | Lexmark X2600 InkJet Printer
Lexmark x2600 i have ink and ervything my paper isnt jammed but everytime i try to print the button next to the X button keeps blinking orange
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
2. Open the printer cover and remove both the cartridges.
3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check the light status.
8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
10. Load some paper. Try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 21, 2011 | Lexmark X2600 InkJet Printer
I have a Lexmark x2600 printer and when I stated printing many pieces went through and then jammed and won't move in either direction, the paper is really jammed in and I don't see any way to get...
Unplug the printer from the power source to turn it off. Open the printer cover to access the cartridge area. If you see the paper jam, slowly and carefully pull the paper out of the printer. Avoid tearing the paper or avoid leaving torn pieces in the printer. This will cause future paper jams in the printer.
When all is clear, re-plug the printer into the power source. Load some paper and try to print again.
Tips: Use only paper that is in good condition. Fan the paper before loading into the feeder to prevent sticking together. Use the specified media type and sizes for your model. Don't overload the feeder.
Jul 24, 2011 | Lexmark X2600 InkJet Printer
I got a lexmark X2600 and the paper keeps getting jammed when its inside, im also low on ink may that be the problem?
This is common for this printer replace ink reset printer and try new paper,if you believe inks fine try a reset it should realline the paper problem plus check for jammed paper
Apr 10, 2011 | Lexmark X2600 InkJet Printer
Lexmark x2600 is blinking ej
The EJ error on your printer indicates that your ink cartridge carrier has stalled. Open the printer cover and clear the mechanical jam, then press the power button. Try to reseat your cartridges and make sure it's properly inserted in the carrier.
Apr 04, 2011 | Lexmark X2600 InkJet Printer
Scanner won't scan on x2600
Hi there you can try.
How to Restore the Printer Settings on the Lexmark X2600 Series All-In-Ones to the Factory Defaults
Step
Action
Turn off the power to the printer.
Press and hold the Color Copy button:
Press and release the power button:
Once you see a '0' on the display, release the Color Copy button.
5
Press the up arrow button until a ' 5' appears on the display.
6
Press the Black Copy button to restore the printer settings to the factory defaults. When the reset process is complete, the printer will automatically reboot.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 27, 2010 | Lexmark X2600 InkJet Printer
Pull the tray out at the bottom of the printer. This is causing the printer to think it has a paper jam. It is simply the paper feed button.
Any other issues email me at derrickfoster3@gmail.com
Feb 21, 2009 | Lexmark X2600 InkJet Printer
Lexmark x73 all in one
paper was jamed at one point turn off printer with no paper in cartriage turn printer back on
Oct 23, 2007 | Lexmark X73 All-In-One InkJet Printer
Lexmark X2600 InkJet Printer Logo
144 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
