I have a kenmore washer. MOdel 110.47532000. It is giving me a F2 error code.
  • 6,784 Answers
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects(Actual drain filter location and procedure below)
• If the above does not correct the problem replace the pump
How to Check your drain pump filter for foreign objects:
Most likely, this issue will be the cause of a clogged drain filter. Use my procedure below to help locate and clean this filter.
First, you will need to unplug your unit and shut off the rear water faucets that feed the unit. Next; Open the small trap door next to the drain hose connection to the back of the washer to gain access to the filter. Now, Push twits and pull out the filter cap that is visible ounce the trap door has been opened. Clear out any debris and wipe the filter and the surrounding area with a mild detergent. If needed, wear gloves and use vinegar or bleach to remove odors, mold and mildew. Rinse the parts completely, if possible. Next; Remove the drain hose and clean it with a mild detergent or warm water. If necessary, again use vinegar or bleach to remove odors and mildew. Completely purge this hose. Once the drain hose has been purged, Reconnect the drain hose and filter. Close the trap door. Reconnect the inlet hoses and plug in the unit and turn it back on for a test run.
Posted on Jul 08, 2010
What does error code F2 mean on a Kenmore HE3T front load washer
As far as I can find out online, the F2 code indicates a problem with the drain system.
Jul 07, 2015 | Kenmore Washing Machines
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
Kenmore elite h3 front load washer is not working error code f2 flashes
The F2 error code mean that the washer didn't drain the water within the normal time it takes to drain,usually the reson the washer hasn't drained properly is because the filter screen on the drain pump is clogged with debris. this tip i have written will show ya how to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 08, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I am getting an F2 error constantly on every wash. Any ideas what this F2 code means or how I can fix it. Thanks
1 check the drain hose to make sure its not kinked.
2 unplug the machine
3 check the electrical plug at the pump and make sure that the pump runs
4 check the drain pump filter for foreign objects
5 plug washer back in
6 if the above does not fix the problem go to #7
7 unplug machine
8 Replace the pump
Part #8181684 http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Washer-Parts/Model-11042922200/0583/0153200/P0309046/00006?blt=06&prst=&shdMod=
Dec 22, 2010 | Kenmore Elite 45986 Front Load Washer
F2 code on a oven mod#911-41069690
go to repairclinic.com click on repair help, then error codes... scroll to kenmore (it will give you a list by the first 3 digits of model number, who really made the machine.. (kenmore doesn't make anything) then go to appropriate brand and find error codes.
Feb 25, 2009 | Kenmore Ovens
Panel Beeping and F2 error code.
IT SOUNDS LIKE YOU GUYS HAVE A BAD KEYPAD/USER INTERFACE. LOOK IN THE SERVICE MANUAL FOR THIS TOPIC AND FOLLOW THE TEST:
ACTIVATION OF CONSOLE AND INDICATORS
DIAGNOSTIC TEST MODE
BOYNISMO@YAHOO.COM
Aug 05, 2008 | Kenmore Oasis HE 27087
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
