Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
New capacitors now freeview unavailable
I replaced bad capacitors with new capacitors now freeview unavailable,i've tried the info,menu,mute power on and selected reset,it went thru tuning then said enjoy your viewing but no freeview or analogue tv,press buttons for these and it just says unavailable,also tv starts in dynamic mode every time it is switched on,works ok when manually adjusted and as long as tv is on,and sky thru scart works ok,any ideas anyone.......thanks....Bob
  • bobboyd27 Jul 08, 2010
    the ones that were in had blown out (domed at the top)I had to short out eeprom chip (pins 5&6) then it powered up ok,went thru reset process and it seemed to tune in but no freeview tuning menu,tv is working fine apart from this
  • 901 Answers
What was the need to replace capacitors. if so on which circuit? Hope you have replaced the right value and type of the capacitor. Observe whether soldered points getting into other pcb track. Clean them again and give a try.
Posted on Jul 08, 2010
  • Ambari Jul 09, 2010
    The present day Tvs have changed amazingly to a new design. The problem you are reporting looks like eeprom. It might be partly currupted. Or if program can be loaded externally, it can be tried.
    You have to take the manufacture's support through their service center. The parts may not be available pre-programmed. Even if avilable exact version of the software should be checked.
Freeview frozen on ch 19
Is this connected to cable, sat or dsl box. If so your issue is with this external box not the tv. If the tuner in the set is used the do auto scan in setup menu.
Apr 11, 2013 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Oct 03, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Similar problem
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Oct 01, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
While trying to tune in my le32r7 tv..I find that I can't select the tuning option as the cursor keeps by passing it..What can TI do?
Sep 30, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
SAMSUNG LE32R73BDX/XEU TV Digital TV Stuck on bbc1, no access to DTV menu to reset or retune. Sometimes picture is frozen, always it shows BBC banner and Mono. Standby - Info - menu - Mute - Power is not...
Sep 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
After power outage tv will not work
I have sort of simular problem with my TV it plays from sources but the freeview is not working + LCD is dim. You can try INFO-MENU-MUTE-ON and select Reset, you have to rescan all your channels again. I currently investigating reprogramming the flash part of the freeview controller via the service port or buying a new controller PCB. Thats as far as I am currently. Thanks T.
Sep 19, 2009 | Samsung Televison & Video
Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Oct 24, 2007 | Televison & Video
Freeview locked
Phil.. to reset: Info>Menu>Mute>Power Button make sure tv is off to start with! messing around in here could void your warranty..it resets the tv to manufactures settings. if you just want to reset freeview.. 0 0 0 0 then press the colour buttons in sequence.. im having a much bigger problem..i think my freeview has blown on my LE46m87bdx..its only 1 month old..i turned it on and it went crazy..then no more channels..no signal..and i get a max bit error with 0 signal strengh..add to this with the fact that the screen goes crazy and resets on the DTV mode..ive got a service person coming round on the weekend! if it is blown..then ill have to do without freeview on the tv...im not letting him take away the tv...no no no no no!
Jul 14, 2007 | Samsung LE40R74BDX 40 in. LCD Television
Built in freeview locked up in tv
I also got a black screen! I then turned the TV off, pressed TV and while it was lit, quickly pressed info, menu and then mute. Then switched the tv back on and amazingly......the menu was there. Go to item 12 and reset. I am please to say that we are back in business,
Jul 12, 2007 | Samsung LE40R74BDX 40 in. LCD Television
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
179 people viewed this question
Jerry Greenberg
Jerry Greenberg
