Question about Jura Capresso CoffeeTEAM 455 10-Cup Coffee Maker
LCd display not clear
Many pixels have burned out making the LCD display impossible to read.therefore I can not make any adjustments to my coffee maker. Can this be repaired?
Coffee machine is on but lcd is clear
Well I guess you know the display is burned out, the question is this do they make parts for the appliance, based on my experience the answer is no.
Oct 12, 2016 | Gaggia Titanium Espresso Machine
Blurry text
LCD monitors do best at their native resolution. There might be 2x2 pixels per spot at that resolution. Once you change the resolution, you might have 2.7 x 2.7 pixels per spot (merely an example). Although a resolution might fit well, at 3x3 or 4x4 pixels, all the other resolutions might look out of focus as each character bleeds over into an adjacent pixel.
The 16:9 aspect ratios are the only ones that will work correctly with this monitor; others will show black at the top and bottom or left and right, or images will be too tall or too wide.
The resolutions you should try are 1920 x 1080, 1280 x 720 or 800 x 600. When I look at resolutions available for my 16:9 ratio monitor, those are the three that are bold.. others are available, but would not show the high quality display.
There are also buttons on the front of the monitor to adjust the display left/right, up/down, re-size, focus, brightness, etc.. A change there could make a difference too.
Oct 30, 2013 | Westinghouse Electric L2220HW 21 inch LCD...
When i put the computer to max resolution, i get blue pixels flying around in the left of the screen!
control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
hope this helps
Nov 01, 2010 | Acer 22" X223w LCD Monitor
What are the possible disadvantages of computer monitors?
Monitors, otherwise known as displays or screens, currently come in two formats: LCD and Trinitron ("the boxy thingy").
LCD pros: Flat, low radiation (as far as I know) LCD cons: displays can either come with or develop "dead pixels" - pixels that remain a solid color or display black, are very fragile - pressing the display surface is not "healthy" for the display
Trinitron pros: deep color Trinitron cons: relatively moderate-to-medium radiation
Both types of displays can suffer from "screen burn" - if an image is displayed for too long (several hours/days) it will permanently "burn" itself into the display and be visible at all times.
Jul 15, 2010 | Computers & Internet
Whats the difference between Backlight inverter and LCD??http://www.fixya.com/PostQuestion.aspx?dm=1&ref=thask
Liquid Crystal Display commonly known as LCD is an
electronically modulated optical device made up of any number of pixels filled with crystal.. The one you called the screen.. facing you when you are in front of the lcd monitor
It needs light source for this to have display... the light source whose responsible for the image to be displayed is the backlight inverter.. Its in the form of a cold cathode lights...frequently located at the upper and lower back edge of the LCD screen..
Hope i clear things out for you...
Much appreciated if you rate this help..thanks..
LCDs therefore need a light source and are classified as "passive" displays
LCDs are more energy efficient, and offer safer disposal, than CRTs. Its low electrical power consumption enables it to be used in battery-powered electronic equipment. It is an electronically-modulated optical device made up of any number of pixels filled with liquid crystals and arrayed in front of a light source (backlight) or reflector to produce images in color or monochrome. The earliest discovery leading to the development of LCD technology, the discovery of liquid crystals, dates from 1888.[1] By 2008, worldwide sales of televisions with LCD screens had surpassed the sale of CRT units.
May 23, 2010 | IBM ThinkPad T20 2647 Notebook
Out of range message
This is caused by a resolution and/or refresh frequency setting in your computer's display properties that exceeds the values supported by the monitor.
Find out the optimum (native) resolution of your monitor (in case of AMV 17V5 it will be 1280x1024 pixels), and supported refresh frequency (usually 60Hz for LCD monitors), and set your display properties to these values.
Nov 23, 2009 | Amptron AMV 17V5 17" LCD Flat Panel...
My Harmony 550 remote works fine, except that the lcd display is messed up. It appears to only show every other line on the display, making it impossible to read.
update the firmware
1. click "Downloads" at the top of the software, 2. select "Firmware" 3. Update the remote
if that doent fix it then it's a hardware issue.
Oct 21, 2009 | Logitech Harmony 550 LCD Remote Control
Lost pixels
For lost pixels on the phone's LCD, it needs an LCD replacement. Most phone manufacturer, they just replace the phone itself instead of replacing the LCD on your wireless phone.
Aug 07, 2009 | Motorola Mobility 5.8GHz Digital Cordless...
Screen all white
netrecov - you clearly did not read the original post, therefore explaining the lack of any usefull response from you.
Seeing as it is an LCD, it uses a backlight to illuminate the pixels. this is clearly working (you see white), but it is not displaying the image data over the backlit screen.
I would suggest looking at the inverter or at least in that area.
- TimeMeddler
May 23, 2008 | ViewSonic VX900 19" LCD Monitor
Red pixels on the Srceen
Dead or stuck pixels are not uncommon in LCD displays, and the less you pay, the more likely it is to happen (as a general rule) Most manufacturers will a dead pixel warranty, ranging from 7 days to lifetime.
Read your warranty carefully, and speak to the place where you bought your display.
I hope that helps, if you have any further problems, please add them ass comments to this question. If I have been able to answer your question (or not) please click on one of the ratings buttons to let everyone know how I did.
Thanks for your feedback, and good luck.
Jan 14, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Jura Capresso CoffeeTEAM 455 10-Cup Coffee Maker Logo
41 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Jim Goldsmith
Jim Goldsmith
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
