Question about GPX ML648B MP3 Player
My screen broke and I am unable to change my settings. Is there any way ui can get a picture of the mode settings?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 96 Answers
Holding the MODE button will return you to the main screen. They are Music-Movie-Picture-Setting. You should be on the Music screen first. Pressing down will take you through these in order. Under Setting is LCD set, Language, online device, memory info, firmware, remove mtp info, default, exit.
While in Music (as long as you are not playing a song) tapping the MODE button will give you the option of going to the local folder or exit.
If you play a song and press MODE you are given the following options Play Mode, Equalizer, SRS WOW Mode, and exit.
Under Play mode are the options, Normal, repeat one, folder, repeat folder, repeat all, random, and intro.
Under Equalizer is flat, rock, pop, classic, soft, jazz, DBB
Under RS WOW mode is srswow, user setting, disable srs wow and exit.
I hope this is what you were looking for.
Posted on Sep 03, 2010
It shows erro 124-315
The serial no., product no., and billing count are stored at three locations; the MCU NVM PWB (IOT), the SEEP ROM (SYS1) on the Backplane (BP) PWB, and the ESS NVM PWB (SYS2). This procedure allows the data in all three locations to be synchronized in case of replacement of one of the PWBs, or due to data corruption associated with one of the following faults:
  • 124-324 (3 Billing Counter Mismatch)
    124-325 (1 Billing Counter Mismatch; Unable to recover Billing Counter during recovery)
    124-312 (Product No. Mismatch)
    124-313 (Serial No. Mismatch)
    124-310 (Product No. Failure: Not initialized)
  • 124-311 (Serial No. Failure: Not initialized)
Procedure
  1. Enter UI Diagnostic mode ( Accessing UI Diagnostics).
    Select Adjustment/Others.
    Select Machine ID/Billing Data Settings.
    Select a PWB with the correct data.
    Select Start.
  2. Enter the correct serial number in the Serial Number screen and then select Confirm.
Mar 02, 2016 | Xerox WorkCentre 7232 7242 220v Fuser...
Workcentre 7238. What causes error code 124-315?
Procedure
    Select Start.
Sep 26, 2013 | Xerox Office Equipment & Supplies
Dx-ldvd22-10a does not power up what part do you think broke
It sounds like your TV is in Shop Mode.
Shop mode is a set of picture parameters that have been optimized for a store showroom or display floor. Shop mode does not allow you saveicon1.png any picture settings such as brightness or contrast.
To get the TVicon1.png out of Shop Mode press and hold the Menu button on the front panel for three seconds, the picture will blank momentarily then reappear with "Dynamic Mode" shown on the screen. At this point the picture parameters can be changed and saved.
If this method doesn't work for your TV there is an alternate method that might.
From the buttons on the front of the TV (not the remote):
1) Press the Volume + (increase volume) button
2) Whilst the volume button is pressed, press and keep pressed the menu button
3) Let go of the volume button and keep the menu button pressed for 5 seconds
4) After this time the screen should go blank and "Dynamic" will appear at the bottom of the screen.
from
http://www.fixya.com/support/t399140-samsung_le46f8_picture_setting
Jul 27, 2013 | Televison & Video
I have a xerox 7428 with error 124-315 how can i fixit
Procedure
    Select Start.
Apr 20, 2012 | Office Equipment & Supplies
Dear Sir: I am unable to find a way to take a picture in MACRO mode WITHOUT the autoflash popping up. Do you have any ideas? Thank you so much
The best way of preventing this, is to remember the settings which are indicated on the screen while in Macro Mode. Then you switch to Manual Mode (M) and adopt the settings from Macro Mode (You can check on the light meter, if the picture would be under- or overexposed without the flash (if yes, just change your settings until it fits).
Feb 14, 2011 | Nikon D3100 Digital Camera
MS Vista Windows patches broke my desktop
reboot the computer and then press f10 this should get you a screen with a text line that says safe mode,with net or command scroll down to last settings that worked and try that ps. you really need to make a recovery disk. its that important.
Jun 29, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
I keep getting a box that pops up say that consent for UI has stopped working.. I'm unable to uninstall programs on my laptop. I have vista.. how do I fix it?
hi,
This is a known problem in windows vista (it is actually a security feature)
You can do either of following:
1. Disable UserControl from control panel.
2. If above doesn't works then change the registry settings [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System --> EnableLUA = 0]
3. if this even doesn't works, then, reboot your pc in safe mode (continue press F8 number of times after finishing booting screen on reboot, you'll get safe mode) and disable User control from control panel.
Hope this helps.
Thanks.
Mar 16, 2009 | Computers & Internet
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
GPX ML648B  MP3 Player Logo
Top GPX Audio Players & Recorders Experts
Tequella Chapman
Level 1 Expert
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
