Question about Dell Inspiron 1501 Notebook
How do I find the backlight on an inspiron 1501? I can't find it anywhere in the service manual.
  • 3,940 Answers
How to remove bottom cover on inspiron 1510
There is no such model as Inspiron 1510. If you are talking about Inspiron 1501 then click this ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1501_owner%27s%20manual_en-us.pdf link to get user manual for the system 1501. This contains the removal of bottom cover.Goto page 92 and check under Memory how to remove cover
Oct 08, 2013 | Dell Inspiron 1501 Notebook
Motherboard dell inspiron 1501
From a quick search on the internet,
1) http://www.discountelectronics.com/index.php?l=product_detail&p=2426
2) http://www.parts-people.com/index.php?action=item&id=3845
3) http://www.ebay.com/sch/Computers-Networking-/58058/i.html?_nkw=dell+inspiron+1501+motherboard&_catref=1&_fln=1&_trksid=p3286.c0.m282
4) http://www.golaptopparts.com/DELL_Inspiron_1501-Dell_Inspiron_1501_AMD_Motherboard_UW953.html
Dell Support > Inspiron 1501 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/ins1501/en/sm_en/index.htm
Don't forget to use an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws. DO NOT mix them up.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 23, 2011 | Dell Inspiron 1501 Notebook
Dell 1501 laptop screen has gone almost blank. When I open the laptop I momentarily get to see the screen as it should be. I have tried the 'fn' & 'up arrow' keys without success. Any...
This sounds like a loose wire on the backlight on the monitor.
If it were my computer, I would disassemble the screen and check the connections. You can find directions on Dell's site by going to support.dell.com and entering your service tag to get the downloads. You'll find the service manual there.
Jul 22, 2011 | Dell Inspiron 1501 Notebook
How to open a dell inspiron 1501 laptop case laptop is not getting power I suspect the laptop's connector
Dell has service manuals for every one of it's computer on their website. Go to the link below, and enter in your service tag, or your can just browse for your model. Select your language, then select either 'view' or 'download' after the Service Manual section. It will give you are full break-down of what you need to remove, and how to do it.
LINK
Jan 18, 2010 | Dell Inspiron 1501 Notebook
How to hook up dell inspiron 1501 laptop to tv with vga
Do the following:
1. Get a VGA cable (male-male) and connect to your TV and your laptop
2. Select your TV's source as PC (check ur TV manual)
3. From your laptop, select video output to external monitor by clicking on the Fn key and the F8 key at the same time
NOTE: Please rate our help to keep this free service online
Jan 12, 2010 | Dell Inspiron 1501 PC Notebook
Inpiron 1501 keyboard working slow
Does the issue occur in Safe Mode (Press F8 at boot, select safe mode) If not then a program is likely conflicting, run a virus and spyware scan. If the issue does occur in safe mode, try adjusting keyboard settings in COntrol panel
Jun 09, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 laptop screen will not work.
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 20, 2009 | Dell InspironTM 1501 Notebook
Enable my dell inspiron 1501 bluetooth
I looked over the system configurations for the Inspiron 1501, and it doesn't have Bluetooth capabilities built into it. The 1520 series does, but not the 1501. The only way you're going to be able to add Bluetooth technology is to purchase a Bluetooth usb adapter. Here's a link to the 1501 manuals if you would like to look over them.
http://support.dell.com/support/edocs/systems/ins1501/en/index.htm
Sep 02, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
113 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
