Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have an intermittent problem with the power going out on my craftsmen opener. If I bang on the end where the wires are attached the lights come on and it works for a while. I opened it up and all the connections look fine. Any ideas?
    President:
  • 3,197 Answers
You need to remove the logic board and check for loose connections on the printed circuit board especially around the small transformer. The logic board is on the end you are banging.
Posted on Jul 08, 2010
Intermittent defrosting of freezer, ruining food
U must have a corroded connection somewhere if a simple bang on unit causes the compressor to turn on! Check all wiring that results in power getting to the compressor.
Jun 16, 2017 | Refrigerators
Tip
Craftsman belt drive garage door opener intermittent
My opener was flaky- intermittently going on and off. I could bang it and it would do the same thing so this suggested a loose connection somewhere. This wasn't a unit with the battery backup.
Safety note- don't take apart unless you first unplug the entire unit!!! I took it apart and there were two circuit boards- a logic board and a power supply board (latter was smaller of the two). I took out the power supply board and examined the solder joints on the back. I found one that was cracked (this soldered a connector pin), and another that looked like it wasn't good (not shiny). I resoldered and this fixed the problem.
Another time my wall control acted up (this has the IR sensor and buttons). There is not much room around the screws on the backside for connecting the wires. One of the wires was a little long and shorting out to a nearby component.
Hope this helps someone with similar problems.
on Aug 26, 2015 | Building Materials
03 cadilliac deville brake lights won't come on
test brake light switch --underdash on bracket attached to brake pedal
Jun 06, 2017 | Cars & Trucks
Raccoon ate ate my sensor wires. Can I override them so I can use my remotes?
The safest thing to do is fix them. It really isn't hard, I have done it myself. The wires are small and you can buy move at hardware store or radio shack. When you get them repaired, spray them with ammonia.. raccoons do not like that. This is from the Internet: Low-Voltage Circuits 1 Raise the garage door using the control button on the garage wall or the remote control unit from a vehicle. Inspect each sensor to make sure the green or red power-indicator lights are illuminated. Proceed to the next step if one or both lights are not illuminated.
2 Stand a stepladder at the area of the garage door opener unit. Unplug the power cord from the outlet at the ceiling. Remove the cover at the back of the unit. Identify the connection terminals where the ends of the low-voltage senor wires attach. Reattach a loose wire to the appropriate terminal. Tighten the terminal screw with a small screwdriver. Plug in the power cord and observe the lights on the sensors. If both lights are not illuminated, proceed to the next step.
3 Inspect the double-strand insulated low-voltage wires from each sensor to the back of the garage door opener. Use the stepladder to inspect the wires near the upper part of a wall and at the ceiling. If no damage is noted, one or both sensors must be replaced. Proceed to the following steps if any wires are bare, burned or broken in one or more places.
4 Loosen the terminal screws that connect the faulty wires at the back of the overhead unit. Start at the ceiling and pull the wires out of the insulated fasteners at the ceiling, walls and along the side of the door opening to the sensor. Disconnect the ends of the wires from the terminals on the sensor.
5 Determine the length of a replacement wire using the faulty wire. Cut a piece of new double-strand insulated low-voltage wire to length with electrical pliers. Strip 1/2 inch of insulation off the both strands at one end. Attach the ends to the appropriate terminals on the sensor.
6 Start just above the sensor. Feed the opposite end of the wire through the fasteners at the side of the door, the wall and the ceiling. Strip the ends of the wires as before. Connect the wires to the appropriate terminals and tighten the screws. Plug in the power cord to the opener unit.
Feb 04, 2015 | Building Materials
KITCHEN AID MIXER K5SS has a banging noise when turned on how would I find out how to fix it ?
You will need to open it up and inspect the brushes carefully. Look for a little copper wire, this wire needs to be firmly attached to both the brush and the little disc at the other end of the spring. Clean the brush out with a can of electric cleaner to free any dirt that has built up around the gears.
Jan 04, 2011 | KitchenAid KITCHEN AID 5 Quart Artisan...
CAble seems faulty-Is it a magnetic pick up? how can I test it?
The best and safest way (if you don't have a multimeter) is to use a torch battery, 3 pieces of wire and a torch globe. Attach wires to the centre terminal of the globe, & one to the globe base. Now cut the wire attached to the globe base and insert the torch battery between the cut ends.This creates a test circuit with the torch globe, & battery in series.There are now two wire ends free. To test your circuit, touch the two free wire end together. If you have done this right. the torch globe will light. To use your tester, touch one wire end to a pin on your shaver wall plug, touch the other wire to a hole in the shave end of shaver cable.If the globe does not light, try the other hole. If it still doesn't light, touch your tester wires together to test it's still working ok. Test the cable again, if no light, you have a broken power cable.
NOTES:
1. For this operation the razor and cable are NOT CONNECTED to the power outlet
2. Use insulated wire and solder them to the torch globe if you can, otherwise use a cheap globe holder from Tandy
May 01, 2010 | Braun 4775 Electric Shaver
HAVE A 1/3 HP CRAFTSMEN OPENER THAT WILL OPEN WITH THE REMOTE BUT NOT CLOSE MUST HOLD THE HARD WIRE BUTTON TO CLOSE. GREEN LIGHT IS FLASHING.
If the main light flashes 10 times and the door reverses to the open position you have a door sensor problem. Make sure they are pointed at one another and the small lights on each one is lit and not flickering. Tweak them to see if you can get the lights on. If not you have a sensor that has failed.
Mar 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a 1990 Corvette with a ground wire attached to the rear frame behind the drivers rear wheel that is not attached to anything. My side lights, back up lights, and gas gage does not work. What is this...
The Devil is the grounds on Corvettes , I would check the lights with a test light to see if they are getting power , and also clean and reconnect that dangling ground under the car . if you still don't have lighting I'd start going forward till you DO find those powers or grounds.
Mar 17, 2010 | 1990 Chevrolet Corvette
Seakers shorting out... wiring or amplifyer?
Sounds like a wiring problem. check the connections on whatever is easier first (radio/speakers) if the connections are good you may have to trace the wires to see if there is a break or short somewhere.
Nov 11, 2008 | Kenwood DPX-MP4030 CD / Cassette Player
1993 Ford Ranger charging system problems
in order to answer your question i need to know if you have internal or external regulator for alternator
Jun 02, 2008 | 1993 Ford Ranger SuperCab
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
124 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
