Question about Acer Travelmate 5730 Notebook
Acer Travelmate 5730 boot/bios password lost...i knew the passw. and i wanted to remove it, i entered the BIOS, and after deleting it, it showed: clear (it was ''set'' before) and after restarting, it asked me for the password again, ant this time it didnt accept the old one nor enter.(because i didnt give any passw in the bios...)
harvester3
  • 181 Answers
SOURCE: Satellite A215-S7416 Bios Password
you're out of luck, unless you're familiar with "shorting" the bios chip.
Of course, you can contact Toshiba for a workaround. Proof of ownership is necessary.
good luck
Posted on Jul 17, 2008
SOURCE: bios password for acer travelmate 2410
You need to reset the BIOS password. One way is to dismantle the laptop. Once you can see the board, look for a battery that is similar to watch batteries but is much bigger (the circle flat kind). Remove it then put it back again. It will reset the BIOS settings on the computer. The tech guy would be just doing the same thing.
Hope this saves you $200.
Posted on Sep 12, 2008
eagle338
  • 4889 Answers
SOURCE: asking a BIOS "Enter CURRENT Password".
Its very simple. You can reset it by removing the CMOS battery and then putting it back in. You will have to remove the back panel of the laptop to get to it. This is what a CMOS battery looks like http://www.computerhope.com/issues/ch000239.htm
Posted on Sep 26, 2008
  • 84 Answers
SOURCE: acer travelmate 4230 bios password
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on May 19, 2009
rulds2008
  • 3866 Answers
SOURCE: i forgot my bios password
Well this will be hard to reset without opening up the unit unless you take it to a qualified rep and have it reset via usb or profile port, dont shoot the messanger just because he is not a hacker!!
Posted on Jun 15, 2009
Clear bios password
Removing the CMOS battery may sometimes clear such password... But if the password is used to protect the hard drive, the easiest means is to replace the hard drive
Feb 03, 2014 | Acer TravelMate 5730-6204 Notebook
BIOS password problem
DID YOU TRY ENTER IN THE BIOS? FROM THERE YOU CAN DO A PASSWORD RESET.
Apr 11, 2012 | Acer TravelMate Notebook
I am using Acer travelmate 4052 model for past 6 years. I used password for booting system. Today I tried to remove my BIOS password using BIOS setting. System asked me current password. So I entered the...
Try "1" or "/" or "A" or some messy combination of keys because it seems like you probably had a typo during setting the new password. Try "Spacebar" try "]" or "[" etc for a password, if you can figure it out you can reset it to nothing again just be careful. Otherwise research acer travelmate bios password removal. Also that computer is kind of old, so if there's nothing on it of importance, I'd replace it. If you need data try your friendly computer shop.
Sep 09, 2011 | Acer TravelMate 2300 Notebook
Acer extensa 5220 bios password i do not have, F12 will not give a boot options menu, i have tried removing the CMOS battery and it has not worked
http://majorgeeks.com/Bios_d235.html
Save, delete, and restore your BIOS settings or
i have used this software and no that it works although you might have to get a computer with an internet connection to download and burn it to a disc
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive)
Apr 23, 2011 | AGPtek 6 Cells Replacement Acer Extensa...
How to install windows 7 in acer travelmate 5730 laptop? plz tell me the way.
Put the cd with windows7 into the drive and boot the machine. If the cd does not boot In the BIOS cd must be set a boot first.
Jan 13, 2011 | Acer Travelmate 5730 Notebook
I don t have the bios password i bought my acer travelmate 4200 second hand and i have a trouble to formate my laptop please help me
press either delete or f2 during the boot process to enter the BIOS you can chage your password from there (be careful)
hope this helps
Aug 13, 2010 | Acer Computers & Internet
Could you please guide me how to remove bois possword for travel mate5730g
Steps for Clearing BIOS Password Check
If users set BIOS Password (Supervisor Password and/or User Password) for a security reason, BIOS will ask
the password during systems POST or when systems enter to BIOS Setup menu. However, once it is
necessary to bypass the password check, users need to short the HW Gap to clear the password by the
following steps:
• Power Off a system, and remove HDD, AC and Battery from the machine.
• Open the back cover of the machine, and find out the HW Gap on M/B as picture.
• Use an electric conductivity tool to short the two points of the HW Gap.
• Plug in AC, keep the short condition on the HW Gap, and press Power Button to power on the
system till BIOS POST finish. Then remove the tool from the HW Gap.
• Restart system. Press F2 key to enter BIOS Setup menu.
• If there is no Password request, BIOS Password is cleared. Otherwise, please follow the steps and
try again.
NOTE: The steps are only for clearing BIOS Password (Supervisor Password and User Password).
Check below for the picture of the HW Password reser gap. The gap that needs to be "shorted" is G77.
Jan 27, 2010 | Acer TravelMate 5730-6204 Notebook
Bios password
You will need the BIOS password to enter the BIOS setup.
To do a hardware reset remove the CMOS batteries for 30 minutes. Once your BIOS password is removed, you will need to press the <F2> key during POST (Power On Self Test) to enter the Acer BIOS setup.
After you enter BIOS, go to the Boot tab and down to "Security" and make your changes there.
If you need help with the default password, please re-post your request.
Thanks and good luck.
Mar 19, 2009 | Aspire Acer 7520-5324 Laptop
Bios password problem
Guide to remove BIOS password of Acer computer (Both Laptop & Desktop).
There are four ways to remove the BIOS password
1. Reset Password BIOS via Backdoor BIOS Password.
2. Reset Password BIOS via Software.
3. Reset Password BIOS via hardware.
4. Reset Password BIOS via default manufacturers.
You can contact acer support or search internet for Acer's default BIOS password and that would be real easy for you, But if you are comfortable enough to use Dos you can also try this method.
OK, here is my guide to Remove Acer Bios password computer via Software. This has been done on testing machine Laptop Acer Aspire 3620/ Travel Mate 2420. Anyway, I'm not sure it will work on every Acer PC/Laptop so just consider to do at your own risk, I’m not responsible for any damages caused by this guide.
As we know most of Acer computer (Laptop & Desktop) allow us to setup BIOS in Microsoft Windows (9x/XP/Vista) environment. Great, this is the powerful that help us to remove the BIOS password because all we know if we enter Setup Utility at the boot time we have only three times of filling the password and if all wrong then the system will halt. frown.gif
The program helps us to enter Acer BIOS setup in Microsoft Windows is “Acer eSettings Management” which comes with the CD when we buy Acer PC/Laptop. If you lost the CD then just come to Acer website to download the program.
Before you can install “Acer eSettings Management” you have to install program called: “Acer Empowering Technology” so you’d better to download both of them from Acer website and install & restart your computer to be ready for the job. Here is the link of Acer website, just come there and sellect right series/model of your computer to download these programs:
Code: ftp://ftp.support.acer-euro.com or
Code: ftp://ftp.work.acer-euro.com
Another one program is also very important we will need called: “CmosPwd” - CmosPwd is a cmos/bios password recovery tool. CmosPwd is under GNU Public License. You can freely distribute it. It can be compiled under Dos, Windows, Linux, FreeBSD and NetBSD.
Download it here:
Code: http://www.cgsecurity.org/cmospwd-5.0.zip Guide to install CmosPwd and remove password:
1. Download & extract to a folder. I put it in drive D like this: d:\ cmos
2. To work on cmos memory, ioperm need to be installed and running. ioperm gives direct port I/O access for specified ports to user-mode process (ring 3) using Ke386SetIoAccessMap and Ke386IoSetAccessProcess kernel functions.
Log on to Windows as Administrator priviledges and do as follow: (see picture):
a. Click Start-->Run: type CMD hit Enter on your keyboard.
b. now us the CD command of Dos to come to d:\cmos\windows. (here is: d: hit enter; cd cmos hit enter; cd windows hit enter).
c. when you are already in d:\cmos\windows in drive D then: type “ioperm.exe –i” hit enter.
d. to start ioperm service: type “net start ioperm” hit enter.
e. ok, type: “Cmospwd_win.exe /k” hit enter, we will see:
1 - Kill cmos
2 - Kill cmos (try to keep date and time)
0 - Abort
Choice :
Type 1 and hit Enter to clear cmos.
f. run the Acer eSettings Management program: start-->program-->Acer Empower Technology-->Acer eSettings Management.
g. now come to the: Bios Password to see: if you still see password enable, that means we fail but if we see they are Disable so we are done. Remember if we success remove password then we have to create a password for it and then remove it and click Apply to save to cmos memory. This is very important because sometimes we see it Disable but when reboot the computer they are Enable again cuz the password is still in the CMOS.
That’s all, good luck & don’t forget to set an easy password later.
Dec 27, 2008 | Acer TravelMate 2502LM Notebook
try this,
members have reported that they were able to remove their Acer BIOS passwords by simply opening their notebooks and removing the CMOS batteries for 30 minutes.
if that don't work, acer support charges 100.00 to reset the password, What a rip-off.
Jul 12, 2008 | Acer TravelMate 2500 Notebook
Acer Travelmate 5730 Notebook Logo
1,607 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
