Question about Texas Instruments TI-83 Plus Calculator
I can't get any keys to work on the calculator
The screen has numbers i typed in, but now i can't get the calculator to do anything- clear, turn off, enter, nothing works.
  • kakima Jul 08, 2010
    Warning: A hard reset will clear all memory!
    Remove all four AAA batteries. Press and hold the ON key for at least ten seconds. Replace the batteries. Does the calculator now turn on and work normally?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Having received no response in over a month, I assume the reset solved the problem.
Posted on Aug 20, 2010
How do I multiply numbers?
Clear the LCD screen to zero
To multiply numbers, enter the first number by typing the number key pad; press the "X" key and enter the next number; to tabulate those two numbers, press the "=" key
For example, if you want to multiply the two numbers 125 by 425, the expression pressed on the calculator would be 125 X 425 =
Feb 28, 2015 | Canon P23-DHV 12-Digit Two-Color Printing...
Mem cleared Changed out the batteries and received a messege mem cleared and nothing will work.
Follow this steps to resolve this problem:
1. Press ON to turn calcilator on
2. Press 2nd and then press + key button. TI- 81 displays RESET menu
3. Press 2 to select the RESET, the second item in the RESET menu. The display shows the message Mem cleared. Press CLEAR to clear the screen
If you cannot see anything on the screen, you may need to adjust the graphing TI- 81 calculator contrast:
-To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark
- To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light
Aug 22, 2012 | Texas Instruments TI-81 Calculator
My ti-84 calculator show unreadable code only?
Honestly, I do not understand what you mean. This calculator is designed to run commands one after the other. You may stack a few of them only if you do not need the output of the first ones.
Anyway, the memory is limited and that includes the register where the current line is stored. If you enter too many characters, the calculator stops accepting them and the cursor will change shape.
If memory is full you can no longer do anything. One simple way to regain some working memory (RAM) is to clear entries (the commands you typed). Press [2nd] [+] to enter memory managem2nt and select the command ClearEntries. You can also select ClearAllLists, or Reset. For the last choice you can then choose to reset ALL RAM.
Apr 28, 2012 | Texas Instruments TI-84 Plus Silver...
I have no power to my ti-83 plus, I changed batteries and the backup battery is still good
When you change the batteries the display reverts to default setting. My optimistic guess is that the screen display is so light that you cannot see anything on it. This can be arranged.
A Try this before thinking of repairs.
  1. Push the ON button.
  2. Even if you see nothing, press the [2nd] key and release it.
  3. Press and HOLD the UpArrow key until the screen darkens.
  4. You may have to keep pressing UpArrow for a little while before you see anything.
B If that does not work
  1. Remove one of the AAA batteries.
  2. Press and hold the [CLEAR] key.
  3. Whileholding [CLEAR], reinsert the AAA battery and then
  4. turn the calculatoron.
  5. The calculator should display the message "RAM Cleared".
  6. Release the [CLEAR] key and then press it one more time to remove the message "RAM Cleared".
C. Third option
  1. Remove batteries including the backup battery for 5minutes.
  2. After the 5 minute period, reinsert all of the batteries and
  3. turn the calculator on.
  4. Adjust the contrast if necessary.
D. Last option
The last option requires the reinstallation of the system. So to use it you must download the TIConnect 1.6 software from education.ti.com. You must have the TI USB SilverLink or the TI Black serial cables ready.You must be connected to the Internet.
  2. Press and hold the [DEL] key.
  3. Whileholding [DEL], reinsert the AAA battery and then
  5. The calculator should display "Waiting...Please install calculator software now".
  6. Connect the TI Connectivity cable between the computer and the calculator.
  7. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader.
  8. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
If all else fails you can contact Texas Instruments at ti-cares@ti.com
Hope it helps.
Thank you for using FixYa.
Nov 22, 2009 | Texas Instruments TI-83 Plus Calculator
Ti 83 isnt turning on after i changer all the batterys
C. Third option
D. Last option
Hope it helps.
Nov 21, 2009 | Texas Instruments TI-83 Plus Calculator
Changed out both the back up battery and the 4 AAA's .calculator is still not coming on. what can i try next.
C. Third option
D. Last option
If the message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
It is just not working. it is freezing on me?
C. Third option
D. Last option
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
Nov 19, 2009 | Texas Instruments TI-84 Plus Calculator
When I turn on the Ti-83 the screen comes up in all grayed out and can't do anything except turnoff
C. Third option
D. Last option
Hope it helps.
Nov 16, 2009 | Texas Instruments TI-83 Plus Calculator
Screen is normal but when i type something in it goes blank.
I suspect the batteries are depleted. Change the main batteries.
If that does not solve the problem, apply the following procedure.
C. Third option
D. Last option
Hope it helps.
Ti-83 plus silver edition. calc won't turn on.
Well, if screen shows the RAM CLEARED message, that means your calculator is working. Just press the [CLEAR] key, message will be erased and you are ready to crunch numbers.
Hope it helps.
Oct 09, 2009 | Texas Instruments TI-83 Plus Silver...
Texas Instruments TI-83 Plus Calculator Logo
98 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
