Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Phillips 60" magnavox chassis # PTV843
I have this problem with my TV, When it's cold no picture or sound. But when it's hot outside picture and sound comes in but the picture starts off very small the after about an hour it goes to full size. When there are brighter scenes in the picture the immage start flashing or ghosting it doesn't like bright immages. Please help.
  • Anonymous Feb 02, 2009
    60" Magnavox has no sound or picture but power light is on
  • Philips Master
  • 3,459 Answers
Problem solved.
I had the exact same problem with my Magnavox TV. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.  To help others like me I documented the fix and created a step by quide and repair kit to fix the problem. You can find it here. http://www.magnavoxhelp.com
Posted on Jun 20, 2008
    Genius:
  • 1,139 Answers
Hello lagqboy,
It looks like you are having a high voltage problem where one or more of the HV components are failing. The picture starting off small and the growing as the TV heats up is a sign of this (high voltage) problem. The problem experienced when a bright scene occurs is due to poor high voltage regulation. I would suggest that you take this set to a qualified TV repair shop due to the fact that the section I am talking about deals with voltages that can be fatal.
I hope this helps,
Thank you,
Shuttle83
Posted on Apr 29, 2008
I lost my picture I still have sound but no picture.
I have a Philips Magnavox Projection TV.
I had dish satelight install on my TV. It worked well for two days, then the picture started showing in a square box. I ffixed the convergence and it seemed okay. The next day I turned on the tv and it had sound, but no picture. When I press the status button, the picture would come on then go right back out. Now I don't have any sound or picture. Here is the model information:
Brand: Philips Magnavox
Model #: 9P6040 C104
Serial #: 51190366
Chassis # PTV843
Manufactured: Nov. 7, 2000 (3910K071H)
TV Receiver Listed: 347K E10839
Amps: 3.7
HZ: 60
V: 120
Can someone please, please help me!
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
I have a Philips Magnavox ptv843 and it has a red tint. The picture is really dark, I can hardly see anything in dark seens. I tried to adjust the contrast and brightness but no help. Thanks
These TV's are known for polluted coolant in the picture tubes.The coolant is between the lense and the tube. The factory has a Service Bulletin about this problem and they say to change the coolant in each picture tube. This will make the TV look like it did when it was new.
Aug 02, 2009 | Philips Magnavox 9P6034C 60" Rear...
Screen is getting darker
The most likely cause is the blue and green tubes need to have the cooling fluid changed. After many years the blue and green get clouded with algae. The red tube won't have the problem due to the red spectrum kills the algae before it has time to grow.
The way to replace the fluid for is to completely remove each CRT from the set, remove the drain plug, drain the fluid out the tube, disassemble the lens, give it a good cleaning; then reassemble; add fluid; and reinstall in set. If you check with the site www.TvRepairKits.com they are working on a kit that includes the fluid and photo instruction guide.
Dec 14, 2008 | Philips Magnavox 9P6034C 60" Rear...
Sound but no picture 60in phillips television
I beleive you can get a chip to fix this problem from www.magnavoxhelp.com.
Aug 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox 60 inch tv
not showing a picture are making a sound.
Jul 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Regarding service manual for philips magnavox
You can also get a Factory Service manuals from www.magnavoxhelp.com. The manuals can be downloaded instantly. They are complete with over 2000 pages in all.
Their manuals cover all projection TV models with Chasis # PTV835, PTV836, PTV840, PTV841, PTV842,PTV843, PTV844, PTV847,PTV853
Feb 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
My 60" Philips Magnavox, model 9P6034C103, chassis PTV835
It could be the flyback losing resistace in its windings. What is the chassis number I should have the service manual for it. Phillips/magnavox is hard to cross reference without the actual chassis number.
Feb 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Unknown AutoLock on my Philips rear projection tv
If you look on the rear of the set and locate the chassis number can probably assist you. But I will need the chassis number for RCA & Phillips/magnavox.
Feb 02, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
676 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
