My wireless network connection status in connected speed is11.0 and my signal strength is good but I cannot connect to the internet
Are you running any Internet Security software such as Norton? Also make sure your wireless router is actually connected to the Internet, just because your laptop is connected to the router doesn't mean the router is connected to the internet.
If you can, plug your laptop in to the router via an ethernet cable to make sure Internet access is working, alternatively if you have another computer connected to the router check the internet access on that one.
Also try doing a soft reset on the router, just disconnect from the power for about 30 seconds, reconnect, wait one minute then try again.
Posted on Jul 08, 2010
Poor signal with WiFi on my zeepad
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
My wireless adapter says i have a good connection, but when I go to play games online my signal strength changes so much it makes the game glitch
Whats going on is that your signal strength from the router is good but when playing a game the green bars that you see are not that of the signal strength but that of the internet Speed. Seems the signal is there but the internet speed is not I would restart modem and router see if this helps boost speed you can always check speeds at speedtest.net to be sure you are getting what you are paying for.
Jan 24, 2011 | Microsoft Wireless Network Adapter Xbox...
Unable to stream novie sites with my linksys wireless-g router
Check the connection (signal) strength of your wireless connection in the status area of the task bar in Windows. Also, hovering the mouse over the wireless connection should reveal the connection speed. 54mbps is the highest you can expect on a wireless connection, which is generally OK for streaming video..Any less of a signal strength/connect speed will likely not be adequate for streaming video.
A poor signal strength is usually because of too much distance or too many walls between the router and the computer.
Hope that's helpful.
Jan 15, 2011 | Linksys Wireless-G WRT54G Router
I am connected wirelessly to an 802.11N Network. Why would my ps3 only get 1.1Mbps download time if it's reporting 95% signal strength? I can't even connect to the PS3 store the connection is so bad, i get...
Hi. Since you are getting a good signal in your pS2 connecting to your wireless router. Test your internet connection using this site www.speedtest.net. Your download speed should atleast 80% of the speed that you subscribed. For example, If you availed for a 5mbps connection you should be getting 4mbps or more when you test the connection.
Have a good one!
Jul 29, 2010 | Sony Playstation 3 (PS3) Console
Wont connect to internet
Secure is not there to re-assure you, its telling you the network is password protected & you need the password to connect. The wireless key will appear on the staus screen of your router. Connect using a wire, goto the router status screen & write down the wireless key, try to re-connect wirelessly.
Apr 04, 2010 | Belkin (F5D6051) 802.11b Wireless Adapter
My wireless network connection status in connected Speed is11.0 and my signal strength is good, but I cannot connect to the internet connection godd but internet explorer cannot display the webpage
You are getting local access only.
Right click on the icon in the system tray and click repair....
If it still happens you need to connect to a different network..this usually happens if you are connecting to an unsecured network (I assume yours).
Alternative: Unplug the network adapter. Turn off the computer. Wait approx 2 minutes.
Power on computer with net adapter connected....
Dec 18, 2009 | Sony Computers & Internet
I cant get the speed and signal strenght of the wireless network to work
CAN'T GET OR DON'T KNOW?
IF YOU DONT KNOW TRY TO OPEN (MY NETWORK PLACES) THEN CLICK ( Network Connections ) GO TO THE WIRELESS CONNECTION ICON RIGHT CLICK ---> STATUS YOU CAN FIND THE SPEED AND SIGNAL STRENGTH THERE ....
IF YOU DID THESE AND DIDNT WORK TRY TO RE-INSTALL THE EXACT WIRELESS CARD DRIVER ....
Dec 17, 2009 | Maxdata M-Book 1000T Notebook
Internet Explorer cannot display the web page
your router needs to be configured to let your laptop in the network
Apr 09, 2008 | IBM ThinkPad R50e Notebook
Could be a vista compatibility problem.
check Linksys website for updated driver and or connection manager.
check that you still have permission in firewall.
remove the software of the usb wireless adapter,reboot ,then re install.
just a couple of thoughts
good luck
Terry
Mar 26, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
273 people viewed this question
David Payne
David Payne
