I have a whirlpool 8100 series top loader washing machine and need assistance in how to clean the filter. Could someone please assist?
ngfam1
  • 639 Answers
SOURCE: Smart Drive 703-strange noise during wash cycle
Sounds like the belt and or a pulley !
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
Posted on Sep 02, 2008
jsrock516
  • 5911 Answers
SOURCE: how to take apart a Whirlpool top loader washing machine
If you have not taken the exterior washer casing off, the first steps will explain how to accomplish this:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
Once the casing is removed, you should have full access the the washer interior components. Since you have mentioned you taken the "internal post" off (I'm assuming this is your agitator), I will spare the steps in involved in accomplishing that task.
Next, follow these series of steps:
1. Remove the tub ring. This is the cylindrical donut shaped ring attached to the top of the wash tub. This ring needs to be removed in order to accommodate the removal of the inner spin basket. The tub ring comes off by placing a screwdriver under the series of the tabs that hold it in place and GENTLY prying them up until they release. Be careful not to break off the tabs, or crack the wash tub.
2. Remove the spanner nut that is under the agitator. This holds the inner spin basket to center post.
3. With the spanner nut removed, the spin basket should lift straight up and out. Sometimes the basket will stick to the center-post and may required some "coaxing" to get it free. This can be accomplished by grabbing the rim of the spin basket and prying up on one side, then the other, in an attempt to rock the basket side to side.
Searspartsdirect.com has excellent exploded view diagrams that you can use as a reference. Simply type in your model number and look under the "Agitator, Basket and Tub" heading. The tub ring gasket, I mention below, is listed as item 6. Appliancepartspros.com also has these same drawings.
Some things to consider:
If you remove the tub ring, it is recommended that you replace the seal on the ring before reassembly. Once the tub seal is broken, it can leak if the seal is not replaced.
When reinstalling the exterior cabinet, follow these steps:
1. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have questions, or need further assistance, please let me know. I hope this helps you.
PS What is the reason for removing the spin basket? Anything else I can help you with?
Posted on Jan 17, 2009
SOURCE: I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Posted on Jun 12, 2009
  • 46 Answers
SOURCE: kenmore series 70 tip loader washer is leaking
your just seeing the water that is leaking dureing the wash cycle unplug washer there will be 2 screws on the header panel 1 on each side take them outgently pull header panel to you then flipupunplug wiring harness thas to the cabnet there will be 2 clips 1 on each sideuse a flat screwdrive and pry back they will come out tip cabnet back to you the whole thig will come off look at the pump in the front it has a weep hole in it see if it has been leaking from there
Posted on Jun 27, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Posted on Jul 01, 2009
Where is the cleaning filter
Sorry but we need the make,model to assist
Sep 07, 2015 | Washing Machines
Assistance with rectifying as to why my LG top loader stops once it gets to the spin cycle. Can someone assist?
Before the washer can start to spin it needs to drain the water from the drum. By you having to drain the water from the machine indicates that the drain operation is not happening. This in the majority of the cases is a bad drain motor.
Aug 26, 2015 | LG Washing Machines
Hi. I have a Whirlpool Gold Ultimate Care II Quiet Wash plus top loader washing machine. Today as the water went in to rinse the wash it flooded out across the floor from underneath. Is there a filter I...
No problem with Filter.
Pressure switch is not working, it is not sensing the water level. There could be one more reason can cause this issue. Please check the Pressure HOSE whether is punchered or not.
Sep 16, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
How do I change the door gasket on a Whirlpool Duet washing machine model WFW8300SW03 I have the new part
The following link explains step-by-step how to replace the door bellow on a Whirlpool Duet series front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: You can view helpful exploded view diagrams of your washer at searspartsdirect.com for assistance as well.
Apr 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I need complete part list for whirpool washing machine models AWO 5763/5;AWM320/3;AWO5963/5 and also where to source for the parts.
Check the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites I listed have helpful exploded view parts illustrations to assist you with properly locating and identifying the parts you need.
Make sure your model number is accurate as these listed are based on the specific number on YOUR machine. NOT the series number on the owner's manual. If this is a Whirlpool washer, the model number will be located on a nameplate located along the wash tub rim under the lid on a TOP LOADER and around the door facing on a FRONT LOADER. If you have questions, please let me know. I hope this helps you.
Feb 05, 2010 | Washing Machines
How do I get the top off my whirlpool washer
If you are referring to a Whirlpool top loader, the following link explains how to remove the exterior cabinet to access the internal components:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
If you need further assistance, please post back with your complete model number (located on a nameplate along the wash tub opening under the lid). I hope this help you.
Dec 21, 2009 | Whirlpool Washing Machines
How do i open the entire lid of washer to repair switch?
The following link explains step-by-step how to replace the lid switch on Whirlpool top loader:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Oct 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
How do you open the console on a Kenmore 80 Series Washing Machin
To replace a motor coupling on a Kenmore top loader, follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Included are all the step-by step instructions you need (including how to open the console). If you still have questions, or require additional assistance, please let me know. I hope this helps you.
Feb 25, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer, water doesnt completely drain even though it spins. need help?
Your drain filter is clogged with debris. Usually small items like dirt, paper, money, and much more. Clean the filter and you should be set to go.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Dec 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Front loader washing machine is not draining
Based upon your description, the drain pump has either failed or become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) Be prepared to catch lots of water. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
If you need further assistance, let me know
Regards,
reg501
Jun 29, 2008 | Whirlpool Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
