Question about Dryers
Gas dryer spins but there's no heat and it doesn't stop on settings. Make is Whirlpool heavy duty super capacity Model # LGR5636EQO Stock# LGR5636E. How do I or can I fix it?
  • 833 Answers
SOURCE: turn off buzzer
Assuming you mean the end of cycle alert. The only way to do this is to follow the wiring diagram and install a switch to cut it off.
Posted on Dec 21, 2007
jsrock516
  • 5911 Answers
SOURCE: kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Posted on Aug 12, 2008
SOURCE: Whirlpool Heavy Duty Super Capacity Plus top loading washer
i see water around the bottom outside of my whirl pool heavy duty spuer capacity washing machine...in the spinning cycle it appears to be going out the drain hose and drainning ok???
Posted on Aug 25, 2008
SearsTechToo
  • 261 Answers
SOURCE: my whirlpool will not spin
What we need to do is pull the machine out 2 feet from the wall and tilt it back. This will expose all the parts we need to remove. The pump is first held on by two metal clips, pump will clip to frame arm with a screw driver through a hole for support. Next is the motor,first unplug the wire harness, maybe a white switch wire and two red wires in addition to unplug. Next there is two 1/4 inch hex screws and then the motor unclips, bottom one first. Now you can see the coupler, note how it is attached. Turn the spindle on each side lift with a screw driver to remove the flanges. To seat the new flanges I use a 1/2 deep well socket on a extension to tap flush the flanges,flush with the spindle. Now insert the rubber coupler at the gear case side and align to the motor and reverse the process and then test.
Posted on Sep 21, 2008
  • 21 Answers
SOURCE: dryer timer is not working and won't heat but runs fine
check the ignitor. That's a very common cause for no heat in a gas dryer. other possibilities are the coils, or it could be that you have a bad fuse in the dryer.
Posted on Dec 26, 2008
Dryer run but does not heat
Chedk your breakers the dryer will run on 110v but wont heat
Nov 21, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Amana heavy duty super capacity dryer heating element location
get the Model # and then go to Repairclinic. com
Jun 28, 2013 | Washing Machines
My dryer is a ultimate care heavy duty super capacity runs fine but it wont heat up so it don't dry. Does it have a pilot or something i need to replace?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 20, 2011 | Whirlpool Dryers
I have a Whirlpool Heavy Duty Super Capacity Gas Dryer model no. LGR7646EQ1. Today it suddenly stopped heating. Normally I can hear the igniter start. Now I can not and the gas is not coming on the drum...
Their is a way to test it with an ohm meter Unplug unit. unplug igniter connector has two white wires going to it an check for continiuty between the two terminals on the igniter side of connector,.if no continuity replace..Hint when installing new ignitor do not touch the heating end of it oils from your body will create a hot spot and shorten the life of the ignitor....Hope this helps in your repair
Aug 15, 2010 | Whirlpool Dryers
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Capacity of Kenmore Model: 110-9155120 Washer and 97566200-75662
3.6cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 30, 2009 | Whirlpool GEW9250 Electric Dryer
I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
Mar 17, 2009 | Kenmore Dryers
Whirlpool model number LGV7646ANO gas dyer will not heat up
Can you hear a click like always? If not then it has to be either the fuse, ignitor,or sensor. If you hear it clicking then the operator coils are dead. HERE is a link that shows pictures of these parts and locations.
Jan 19, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
90 people viewed this question
Top Dryers Experts
