Question about Zebex Z-3080 Handheld
Need Driver for Zebex Z301 Barcode Scanner
Hi we are looking for a driver Zebex Z301 Bar code Scanner. the OS is Windows XP
Sudrajat
  • 20 Answers
SOURCE: No code appear after I scanned the barcode.. Please help!
First of all,have you tried using a notepad ? just to verify that your scanner connected correctly to your pc If it's fine then you should find out if there's an enabled properties of your object such as text box, combo box, that was set to False,change it into true.
Posted on Aug 24, 2007
  • 25 Answers
SOURCE: Stopped scanning
I seldom do this ...but I will comment on the Zebex scanner. This is ...errr ... not the best choice for future scanner needs. I will never forget commercial Zebex experience. They should have stuck to anti freeze (just kidding).
However if it did work and now doesn't there is one problem that is so obvious no one thinks of it ... check the clear plastic protector on teh front and see if it need cleaned. Greasy environments usually fog it over time.
I have the Zebex default codes somewhere in the shop ... but you can replace that scanner with a nice PSC, Mot, or Intermec for about 120.00 why not do that?
Posted on Jan 09, 2008
  • 5 Answers
SOURCE: my scanner scans different numbers to what is on
Firstly, You must be reset scanner.
for reset,
to find programing manual.
if you don't have it.I can send to you.
1. scan start of configuration barcode
2. scan reset barcode
3. scan end of configuration barcode
best regards
Ufuk
Posted on Apr 02, 2009
  • 38 Answers
SOURCE: Alpha 70 Series is not working after disconnecting PC and recnctg
Hello Suzanne. The problem you are going to find here is that Zebex doesn't make this model anymore and haven't for some time. If the unit has power and emits a beam, I have the Zebex generic Programming Card and Programming Guide available on my company's website. Have a look at the sections that include the "reset default" barcodes. Print out that page and try scanning them with your scanner. Resetting the scanner to it's default programming may get everything ironed out. If the scanner doesn't have power or emit a beam, then unfortunately you will be looking at getting a replacement scanner. I can recommend several different scanners what would work fantastically and be quite cheap. If you still need help, please feel free send a message or email me. I hope this helps. Good luck!
Posted on Jan 01, 2010
Need driver for z-3051hs barcode scanner
Hello. The problem will get resolved by going on the links below and download the driver for your Z-3051HS Barcode Scanner.
LINK 1 (Auto Sensor Standard Firmware Version 1.10)
LINK 2 (Standard Firmware Version 1.10)
The links above belongs to ZEBEX official website.
Easily save the file to your computer. Run and install it properly.
I hope I helped!
If you have any other questions, please leave a reply.
Thank you for using FixYa!
May 31, 2011 | Zebex ZBA Z-3051HS Barcode Scanner - P/N...
I HAVE 5 SCANNERS, FOUR OF THEM SCAN AS THE ITEMS PASSES IN FORNT OF THEM AND THE FIFTH ONE NEEDS TO PRESS THE BUTTON. HOW DO I CHANGE THE FIFTH TO SCAN AUTOMATICALLY
If you look in the manual, you will see the code to place the scanner in to "stand" mode which should do as you request. This mode is restricted to certain models however. Near as I can tell, there are a few variants of the Z-3051HS model that support this. Reference the manual at the link below. Please update this with any other questions you may have.
Thanks,
Dan
Link: http://www.zebex.com.tw/old_website/documents/users_manual/handheld/z_3051hs.pdf
Apr 02, 2011 | Zebex ZBA Z-3051HS Barcode Scanner - P/N...
How to use zebex barcode scanner?
Click below for a link to the support site. Click on the User's manual for you model scanner.
Zebex Manuals
Hope this helps.
Zeppelinx12
Mar 11, 2011 | Zebex Computers & Internet
Dec 28, 2009 | Zebex ZB 2200AM
Symblo Scanner not pairing with Base
If the bar codes are in good shape and can be read by other scanners then your scanner probably needs to go to repair. You try to reboot the scanner by pressing FUNC then *
If you need the scanner repaired let me know and I can repair it for you.
Jun 01, 2009 | Symbol P370 Handheld
Barcode scanner
please get programing manual for Z-3080 then
scan start of configuration barcode then USB emulation barcode then end of configuration barcode
probably your problem wiil be solved.
Nov 01, 2008 | Zebex Z-3080 Handheld
Computer does not see the scanner
check that scaner in other system if u found then reintsall your scanner driver in your laptop or usb.driver
How can I determine input whether coming from keyboard or scanner?
Why you need to know from which it is comming? As a wedge is 2 inputs is merged as 1 output. There is no way to tell unless you use special coding in the BArcode that cannot be manually keyin. If I know your need maybe there is a altermnate way to do it.
Apr 03, 2008 | Zebex 90940-RS232-9 Handheld
CIPHERLAB 1000 (serial ) Driver for WinXP
you dont`t have a driver for serial comm.open hyper terminal on com port where is the scaner.read a code and you wilkl see the numbers on the screen.If you want to work with some windows programs change that barcode for usb or ps/2 variant.
Jan 15, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Stopped scanning
Jan 07, 2008 | Zebex Alpha-70 Handheld
Zebex Z-3080 Handheld Logo
173 people viewed this question
Top Zebex Computers & Internet Experts
David Payne
David Payne
Are you a Zebex Computer and Internet Expert? Answer questions, earn points and help others
