NEC NW-892 - MILLENIUM 8KG FULLY AUTOMATIC WASHING MACHINE: NOT SPINNING - THE LETTERS 'OE' ARE LITTEN UP - WHAT DOES THAT MEAN? ALSO HAS 'IE' 'UE' & 'LE' - WHAT DO THESE MEAN?
  • 11,896 Answers
IE is Water inlet error - Correct water level is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes. - Water valves not fully opening
UE is unbalance/off balance error - tub is off balance
LE is Lid Error - Lid not closed or faulty lid switch
LE on some machines, means Locked Motor
Posted on Jul 08, 2010
  • 1 more comment
  • jo_meta Jul 09, 2010
    HI THERE - THANKS FOR THAT BUT WHAT DOES 'OE' MEAN, WHICH IS THE ONE THAT IS SHOWING AT THE MOMENT? REGARDS, JO!
  • Nate Stansfield
    Nate Stansfield Jul 09, 2010
    OE means wash machine hasn't fully drained.
    This can also indicate a stuck or plugged pump or plugged drain
  • Daryl Adams
    Daryl Adams Dec 23, 2011
    at the back of the machine, down the bottom, unscrew the blue cap enough to pull on it and pull the filter out, use a flat blade screwdriver if it's too tight. clean the filter and put it back, screw the cap back up and the OE code should be gone.
My washing machine shows UE errors
The UE Error Code indicates that the laundry load is unbalanced. Just redistribute the load and when you shut the lid it should start to re-spin again. On some machine you have to push the start button.
Apr 09, 2014 | Samsung SW62ASP Top Load Washer
Washing machine not spinning, stops & the letters LE flash, washing machine is a NEC NW-892 Millenium
It sounds like your lid switch is not working correctly, look to see if there is supposed to be a finger that protrudes from the bottom of the lid and enters a hole in the top of the washer, this is a safety switch to ensure the lid is closed, it is possible the actuator finger is broken or missing, If this is the case, I have heard of people manually actuating the switch to finish the load, I am not suggesting that because there is a safety issue, but it has been done. Your washer might not have an exposed actuator,it could be hidden under the washer top, but the LE error code indicates the lid is open.
Nov 10, 2012 | Washing Machines
My Samsung fully automatic washing machine Model # WA13G2Q showing 1E error code.What do I do?
My Samsung fully automatic washing machine Model # WA13G2Q showing UE error code.What do I do? THIS IS MY EMAIL engrabih12@hotmail.com
Apr 13, 2011 | Samsung SW62ASP Top Load Washer
I am Looking for the meaning to eror code LE on my washing machine it is an nec model No NW 452
According to what's written in the manual...
'LE' will light up if the machine is unbalanced or the lid is open. This can be corrected by following operation: WATER SUPPLYfi RINSEfi DRAIN. However if the unbalanced condition is unchanged despite repeating the above operation, the lamp 'UE' will light up, and the buzzer will sound to indicate a problem.
Jan 13, 2011 | Washing Machines
NEC NW 892 Errror E9
This error is related to the pressure sensor
check connections or replce pressure sensor
Check at the water source end of the hose and make sure the filter is not occluded. Both hot and cold. more likely the cold side as the hot water may disolve the particles more easily.
If all else seems good you will have to replace the sensor
Aug 01, 2009 | Washing Machines
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
What does the OE light mean, ta the machine wont drain and spin and the light keeps coming on.
Here are error codes/:
OE= PUMP BLOCKED OR WATER NOT PUMPING OUT ( LOOK FOR PROBLEM IN THE PUMP IMPELLER )
IE = NO WATER INTO APPLIANCE CHECK WATER TAPS ECT
DE = DOOR OPEN OR NOT LOCKED
UE = IMBALANCED LOAD
SE = NORMALLY MOTOR FAULT BUT COULD ALSO BE MAIN PCB FIRST CHOICE IS CHANGE MOTOR.
CE = CURRENT ERROR SHORT CIRCUIT TO MOTOR OR MAIN PCB DUFF
LE = LOCK ERROR BASICLY WIRING TO THE DOOR LOCK IS FAULTY
FE = TO MUCH WATER IN TUB
TE = TEMPRATURE ERROR NORMALLY THERMISISTER OR ELEMENT FAULT
PE = PRESSURE SWITCH FAULT
Jun 18, 2009 | LG Washing Machines
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
Letters UE on display
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 26, 2009 | Washing Machines
Washing Machines Logo
832 people viewed this question
Top Washing Machines Experts
