Question about True TD-65-24 Commercial Refrigerator
My door no longer automatically shuts! Driving me nuts!
Mercedes 450sl
Best guess: Electric door lock that automatically tries to lock the door but is too weak to get it done.
Aug 10, 2014 | Mercedes-Benz Otaki Mercedes Benz 450slc...
Drivers-side rear door won't engage-interior bell chimes constantly
Make sure the rear cargo lid is shut. Then if it still appears to be the door, then remove the jam switch in the door sill. The switches usually separate the wires when the door closes. You do not want to lose the wiring inside the doorjam and you do not want to leave a hole open either.
Tie a string on the wiring and/or tape the wiring to the doorjam until you can get a new switch. Tape the wire ends to prevet shorting.
Feb 04, 2012 | 2008 Chevrolet Uplander
My Bosch economic cooler has a door problem. It no longer shuts automatically unless one pushes it hard to shut it.
check for food or shelves protruding. Check if door is rubbing on the bottom, sometimes scrape marks are evident. check to see if gaskets are sticky if so clean them and apply thin layer of petroleum jelly. Depending on the model sometimes the closing cams are broken on the bottom hinge.
Apr 14, 2011 | Bosch Refrigerators
1996 Rav: Driver side door will not shut in cold weather, requiring me to hold the door closed while I am driving. Once vehicle warms up, door will shut. Very Very frustrating, when driving a short...
You have water in the latch mechanism. To solve the problem apply heat to the latch area of the door. I use a propane torch but a hair dryer or heat gun will also work. They will take longer though. Be careful with the torch so you don't burn the paint. hold it fairly close but keep it moving constantly. You will see the paint change appearance when you start to apply heat, keep heating until it changes back. At that point the latch will work. Close and open the door a few times and it should keep working for a while. The best thing to do is spray it with some WD-40 or RustCheck as soon as you get it working. Put the nozzle on the can and bend it right into the latch and spray around heavily. This should keep it from freezing up again. Hope this helps.
Feb 22, 2011 | Toyota RAV4 Cars & Trucks
Have a VW Passat 2002, alarm drives me nuts
sounds like the rear door sensor is kaput.all doors need to be shut before alarm will stabilise/you can leave the car open as if you dont have the key(with the correct code)the car is dead/immobilised.not even hot wiring will start car....
Mar 08, 2010 | 2002 Volkswagen Passat
Crazy electrical problem
you have a broken wire in door to body wiring loom repair this and all will be back to normal
May 28, 2009 | 2004 Jeep Grand Cherokee
those functions are part of the bcm or body control module.
Apr 29, 2009 | 2004 Jeep Grand Cherokee
Looking for fuse to shut down automatic locks
If the locks actuate while driving, usually it's due to the door pin switches that need a slight adjustment. As you drive and go over bumps or turns the body or doors flex slightle and the switch sees the door as open then closed and tells the body computer to lock doors again. Check for the black pin switch on door post near door catch and with a small flat blade screwdriver, pull the center cap of the plunger out about 1/8 inch from the black push in part and close door which will adjust the plunger again to correct depth.
Jan 16, 2009 | 2001 Chrysler Sebring
True TD-65-24 Commercial Refrigerator Logo
19 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
