Question about Compaq XW8000 (470061-663) PC Desktop
At switch on I get a modem sound followed by 2 beeps The system will not POST.
    President:
  • 2,678 Answers
Have a look here
http://www.pchell.com/hardware/beepcodes.shtml
Posted on Jul 08, 2010
Maxdata tower computer : - when switched on bleeps 2/3 times and doesn't engage the mouse or the keyboard and the monitor shows " no video input ".Just no response and doesn't turn itself on...
BIOS Beep Codes
Whenever a recoverable error occurs during POST, the BIOS displays an error message describing the problem. The BIOS also issues a beep code (one long tone followed by two short tones) during POST if the video configuration fails (a faulty video card or no card installed) or if an external ROM module does not properly checksum to zero.
An external ROM module (for example, a video BIOS) can also issue audible errors, usually consisting of one long tone followed by a series of short tones. For more information on the beep codes issued, check the documentation for that external device.
There are several POST routines that issue a POST terminal error and shut down the system if they fail. Before shutting down the system, the terminal-error handler issues a beep code signifying the test point error, writes the error to I/O port 80h, attempts to initialize the video and writes the error in the upper left corner of the screen (using both monochrome and color adapters).
If POST completes normally, the BIOS issues one short beep before passing control to the operating system.
I hope this helps.
Mar 14, 2011 | Computers & Internet
Tip
Beep codes
Diagnostics with Beep Codes Following are the beep messages associated with the IBPbios. 1 short beep specifies a normal post 2 short beeps tells about POST errors that can be find onscreen. Continuous beeps indicates power supply and other cardserrors. One long and short beep indicates system board problems 3 long beeps defines keyboard errors No system beep tells about power supply errors.
on Mar 15, 2011 | Computers & Internet
Tip
Error Codes you need to know.
Standard Original IBM POST Error CodesCode Description
1 short beep System is OK 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Display adapter problem (EGA) 3 long beeps 3270 keyboard cardIBM POST Diagnostic Code DescriptionsCode Description 100 - 199 System Board 200 - 299 Memory 300 - 399 Keyboard 400 - 499 Monochrome Display 500 - 599 Colour/Graphics Display 600 - 699 Floppy-disk drive and/or Adapter 700 - 799 Math Coprocessor 900 - 999 Parallel Printer Port 1000 - 1099 Alternate Printer Adapter 1100 - 1299 Asynchronous Communication Device, Adapter, or Port 1300 - 1399 Game Port 1400 - 1499 Colour/Graphics Printer 1500 - 1599 Synchronous Communication Device, Adapter, or Port 1700 - 1799 Hard Drive and/or Adapter 1800 - 1899 Expansion Unit (XT) 2000 - 2199 Bisynchronous Communication Adapter 2400 - 2599 EGA system-board Video (MCA) 3000 - 3199 LAN Adapter 4800 - 4999 Internal Modem 7000 - 7099 Phoenix BIOS Chips 7300 - 7399 3.5" Disk Drive 8900 - 8999 MIDI Adapter 11200 - 11299 SCSI Adapter 21000 - 21099 SCSI Fixed Disk and Controller 21500 - 21599 SCSI CD-ROM System
on Mar 09, 2010 | Computers & Internet
Erro sound/pip when ibm 8310 netvista starts, no error message are show on the screen, the screen are black.
how many times it beeps is an indication of the problem
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard cardhope this helps.
Sep 14, 2009 | IBM (09N5424) Motherboard
Beep sound continus
I went to google and it seems like the beeps can be problems for different problems in the hardware, this is what one message says,  there are lots of computer beeping answers out there: 1 short beep is your BIOS saying "HELLO I'M OK"
1 short beep Normal POST - system is ok
3 long beeps keyboard card
Each BIOS company has modified these codes over the years.
May 25, 2009 | Dell Dimension 4600 PC Desktop
Tip
Beep Codes (Different BIOS) " What they mean "
Code Description
Code Description
200 - 299 Memory
300 - 399 Keyboard
AMI BIOS Beep Codes
Code Description
1 Short Beep System OK
2 Short Beeps Parity error in the first 64 KB of memory
3 Short Beeps Memory failure in the first 64 KB
4 Short Beeps Memory failure in the first 64 KB Operational of memory
or Timer 1 on the motherboard is not functioning
5 Short Beeps The CPU on the motherboard generated an error
6 Short Beeps The keyboard controller may be bad. The BIOS cannot switch to protected mode
7 Short Beeps The CPU generated an exception interrupt
8 Short Beeps The system video adapter is either missing, or its memory is faulty
9 Short Beeps The ROM checksum value does not match the value encoded in the BIOS
10 Short Beeps The shutdown register for CMOS RAM failed
11 Short Beeps The external cache is faulty
1 Long, 3 Short Beeps Memory Problems
1 Long, 8 Short Beeps Video Card Problems
Phoenix BIOS Beep Codes
Note - Phoenix BIOS emits three sets of beeps, separated by a brief pause.
Code Description
1-1-3 CMOS read/write failure
1-1-4 ROM BIOS checksum error
1-2-1 Programmable interval timer failure
1-2-2 DMA initialisation failure
1-2-3 DMA page register read/write failure
1-3-1 RAM refresh verification failure
1-3-3 First 64k RAM chip or data line failure
1-3-4 First 64k RAM odd/even logic failure
1-4-1 Address line failure first 64k RAM
1-4-2 Parity failure first 64k RAM
2-_-_ Faulty Memory
3-1-_ Faulty Motherboard
3-2-4 Keyboard controller Test failure
3-3-4 Screen initialisation failure
3-4-1 Screen retrace test failure
3-4-2 Search for video ROM in progress
4-2-1 Timer tick interrupt in progress or failure
4-2-2 Shutdown test in progress or failure
4-2-3 Gate A20 failure
4-2-4 Unexpected interrupt in protected mode
4-3-1 RAM test in progress or failure>ffffh
4-3-2 Faulty Motherboard
4-3-3 Interval timer channel 2 test or failure
4-3-4 Time of Day clock test failure
4-4-1 Serial port test or failure
4-4-2 Parallel port test or failure
4-4-3 Math coprocessor test or failure
Low 1-1-2 System Board select failure
Low 1-1-3 Extended CMOS RAM failure
on Dec 30, 2009 | Computers & Internet
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Feb 22, 2009 | Lenovo 3000 Y410 Notebook
4 beeps 2373 laptop
Code Description
Code Description
200 - 299 Memory
300 - 399 Keyboard
AMI BIOS Beep Codes
Code Description
Code Description
2-_-_ Faulty Memory
Feb 19, 2009 | IBM ThinkPad T40 2373 Notebook
Beeps
Code Description
For more info go here: http://pulonangka.web.id/software/beep-codes-error-codes
Aug 16, 2008 | Dell XPS M1530 Notebook
Beeping with no boot up
Beep codes mean something has gone wrong with the computer. Beep codes most likely happen for: Memory, Processor, Motherboard.
Try reseating the memory in the computer.
Jul 11, 2008 | AOpen XC Cube EZ65 Barebone
Compaq XW8000 (470061-663) PC Desktop Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
