Question about Fujitsu Siemens MYRICA P50-2 50 in. Plasma TV
We got a Myrica PQ42-1 that takes the fuse in our house all the time. After 2-3 times it turns on. Is this normal??
I have the same problem. Returned the TV for warranty repair and got it back still with the same problem. "Change your fuses to 16A slow" was the message from FSC service shop. (16A=3500Watts!)
I have mounted a 10A fuse directly 'between the TV and the 230V outlet so the (house) fuse does not drop.
Now my ******* TV went all black, probably the backlight.
Posted on Feb 06, 2011
1999 Expedition hazards do not work. The turn signals and brake lights work normal
Flashers have a fuse that goes bad from time to time. Your local auto supply house usually stock them inquire about it and get information on its location. It is usually fastened ot the steering column under the dash. I hope that this solves your problem.
Jun 22, 2015 | 1999 Ford Expedition
I have a Carrier model 42KPC019303. It turns off while running. The LED blinks five times, stops, and then blinks 5 times again in cycles. After a few minutes, it turns back on again and off again after a...
hello
1- you check thermostat .
2-maybe temp your house is below 26c.
3-you check fan condenser and evaporator .
4-maybe cut off low pressure system.
Sep 12, 2011 | Heating & Cooling
I noticed our heat pump was running all the time, even on warmer days 40 degrees and warmer. i turned it off in the house at the tstat and flipped the breaker off, hoping to reset it, when i turned it back...
Sorry to read about your problem, I hope this helps you out.
sounds like you relays are frozen on at the compressor, you should have a grey box, that looks like a power box, you can pull the fuse their or at the ckt breaker
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE Heating & Cooling
Black screen on my Fujitsu Siemens Computers Myrica television
sound no picture does it flash when first powered on ? its the invertor board it controls all the lamps
that light the screen/shine torch into screen you
will see picture/needs repaired google{ohm supplies uk}
Apr 18, 2010 | Televison & Video
2007 dodge ram fuse problem
my 2008 dodge ram is displaying no fuse underneath the spedometer. it makes a clicking noise about 5 times and turns over fine. runs normal/drives normal. it delays when turning off (i turn the key off and it takes about 5 seconds to turn off) remote entry does not work.
Feb 12, 2010 | 2007 Dodge Ram Truck
Guru
Runs but no heat? check your house breaker or fuses it takes 2 thirty amp breakers or fuses if you have breakers flip them off then back on several times. then try again still no heat you would need a volt- ohm meter to check the element, t-stats,thermal overloads etc. If you have fuses just replace them with 30 amp time delay fuses and try again.
Oct 18, 2008 | Whirlpool LER4634J Electric Dryer
Power button
Sorry, I have to say it. If the bulb (LED) is shot it would have to be zero flashes :-) It's my weird sense of humour. After that I hope you'll forgive me and someone can give you some real help.
May 27, 2006 | Sony KDF-E55A20 55 in. LCD Television
Fujitsu Siemens MYRICA P50-2 50 in. Plasma TV Logo
406 people viewed this question
Top Fujitsu Siemens Televison & Video Experts
kj henriksen
kj henriksen
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Fujitsu Siemens Televison and Video Expert? Answer questions, earn points and help others
