Question about Microsoft Office Professional 2007 Full Version for PC
How to save file with some edit without deliting original
    President:
  • 2,666 Answers
Click Save As and rename the edited file. Original will still be in place.
Posted on Jul 08, 2010
Magix Movie Edit Pro Premium 2015 cannot find or recognize many of my saved MVP Project files. All previous saved project files still show in MEP 2015 folder. How do I get MEP 2015 to open them?
Magix software can be fickle at times. All I can suggest is that you are very careful with files and directories associated with the working files of the software. One tiny change will produce a file not found response. You can sometimes manually take it the missing file, but it's messy.
I suggest that any outputted files are not directly changed, but left where they are. If you want to do with something afterwards create a new folder and copy the files you want into that folder. Then change those files.
If you look at the original files that you worked on, you will see around four files near it. Deleting any of these files will produce that response. If you alter any of the original files you worked, you will get the same response. Because the Magix files around it will no longer match with the file you altered.
Sep 23, 2015 | Magix Computers & Internet
Tip
How to edit Media Center Recordings
Easiest FREE way I've found to edit Recordings made in Windows Media Center is done using Windows Live Movie Maker (Part of the Windows Live Essentials Free Downloads)
I have found that there is some technique involved in making successful edits of the recording.
  1. Open the recording you want to edit in Movie Maker, click save and name the save file what you wish (This file just stores your edit markers and makes no changes to the original recording)
  2. Since most recordings have some overlap, you first need to find the actual beginning and end of the recording, under tools, mark the start and end points using the buttons labeled as such. Click SAVE
  3. Editing the commercials is done in a similiar manner. Browse thru the recording to the start point of the commercial, under tools, click the SPLIT button, then browse to the end of the commercial segment, click split again. (This separates a the commercial portion from the rest of the recording) Right click the commercial segment, Click Delete on the drop down menu and that commercial is deleted (Note the run time is adjusted to the removal point) Click save and repeat on all other commercials.
  4. Once editing is complete, you should have about 22 minutes for a half hour show or 43 minutes for an hour show. Click Save
  5. Here is where I drove myself crazy till I learned the trick. Once edits are saved, CLOSE movie Maker. I don't know exactly why, but I spent a week learning that no matter what I did, 90% of the time when I tried to create movie, movie maker would LOCK UP. Trial and error eventually proved that if I made my edits, then Saved and closed Movie Maker. The re-opened Movie Maker and opened the edit file, that I could then Create Movie successfully every attempt. Click File, Create Movie, and choose your format. (I use widescreen) Saving process is slow, about the length of the show or 1% per minute. This creates a .WMV file about 1/3 the size of the original.
  6. If you want to compress the file even more you can use an encoder to convert the file from WMV to a compressed format (I prefer AVI) I use SUPER © from Erightsoft.com
on Aug 11, 2010 | Computers & Internet
How can I restore photos that I edited?
If you didn't keep a copy, you may well be out of luck. If your camera hasn't been used much, you may be able to "undelete" the original picture from the camera using software like this:
Freeware to undelete files from sd card with iCare Data Recovery Free
Jan 30, 2015 | Cameras
After cropping and saving a picture, how do I revert it back to the original photo?
Hello Karen,
You need to go to the original picture file. As you can only undo cropping or other changes while the undo option in edit menu is active, usually early on when file is open in programme editing with. Just after doing the cropping.
So hopefully you didn't crop picture then write over its original file. You saved it { save as } to a new file. If you did overwrite original file after cropping; then you will need to relocate this original picture from the source it came from to access original composition, size etc. If from your camera then simply re transfer to your computer & open it there.
If you're not sure about where it is on your computer then you can do an open search by typing in part of the file name or file format { part after the dot in filename & go through the results lists to try & locate it.
Hope this helps.
Dec 18, 2012 | Microsoft Digital Image Pro 10
How to save a file without replacing the original file?
Choose the "save as" option and change the name. ie add a number.
Aug 18, 2012 | Microsoft Word 2007 Home and Student...
How to save scanned image from MX310 to computer?
Save the scanned image as a TIFF for archiving. TIFF files can beresaved and edited without compression loss, thus maintaining the highquality of an image. If you are enlarging an original 4 x 6 photo to8.5 x 11, save the scanned image as a TIFF at 600 dpi resolution. TIFFsprovide more detail than other file formats. Scanned images for emailand posting on the Web, which are to be viewed on a monitor, should besaved as JPEGs at 75 or 100 dpi. JPEGs generate smaller file sizes,which download faster on the Internet. Increase the resolution to 150or 300 dpi only if you are emailing a scanned JPEG image for therecipient to print. Save JPEGs at the maximum quality setting.
Dec 16, 2009 | Canon PIXMA MX310 All-In-One Printer
How do you relink a file to corel videostudio?
Using a USB key is the worst thing you can do when you are video editing.
When you are editing video it is best to have the video clips on your main hard drive for the best Play back and rendering performance.
Video editing software doesn't actually change the original files, it just remembers what parts of the videos you want to use and then saves that memory in a project file, it does not save the video files. when you render the video it will make a new video file.
If you make any changes to the project files (Pictures and videos) in the project (e.g. name change, location, re-save) the video editing software will no longer be able to link the files back to the project and will then prompt you to re-link the files.
Also the performance of video editing software relies a lot on the data transfer speed. when you are using a USB drive you are cutting the performance down BIG time.
When you are using VideoStudio save all the files you are editing to the hard drive in one folder. when you are done and you want to transfer the project off, select File | Smart Package. What this will do is gather all of the project files and allow you to save to a USB drive and you can transfer the project to any other computer and open the project using VideoStudio without the relinking issue.
Dec 07, 2009 | Corel Video Studio Pro X2 for PC
Can i revert a photo edited on adobe photoshop? i had a picture and i was editing it in adobe photoshop, but 1 of my young cousin used my computer and saved what i was doing, but she overwrited the...
Once the edited image has been saved, the original image gets over written and there is usually no way to go back to the un-edited version.
If you have the original source file, you can restore it to your hard drive. An example of this would be copying a picture from your digital camera to your hard drive again.
You can also retrieve the original file if you've used Windows Backup or some other backup program to save a copy of selected files.
Sep 06, 2009 | Adobe Photoshop CS2 for PC
Delited files in ad or remove program and my modem keeps saying error so wont to delite xp and put it back on but my xp disk is older than the one on the computer please help
See this is not the disk from the previous installation was done. It was done either from pirated CD (if corrunt one is original) or The current one is pirated.
if corrent CD is original, simply uninstall the SW then reinstall from current CD, otherwise get the latest version of the SW ( offcourse licensed) and install the new one after uninstalling olderone, or update in order to keep your setting same.
Goodluck
Zulfikar Ali
Feb 24, 2009 | Microsoft Office Professional 2007 Full...
Adobe photoshop album starter edition 3.0
Photoshop Album Starter Editions (PASE) doesn't 'store' photos. When you 'import' pictures, it only saves a thumbnail and remembers the location of the original file. It isn't designed as a filing solution. You have to locate and keep track of your original files. Here's an article explaining it in more detail.
http://www.startereditionuser.com/?page_id=6
Sep 22, 2007 | Adobe Photoshop Album 2.0 for PC
Microsoft Office Professional 2007 Full Version for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
