Question about Locks & Locksmithing
Where do i find the serial number on conway cruiser folding camper
2018 Cruiser RV funfinder plumbing - what are the 3 drains under the camper?
On my rv they are low point drains for emptying the lines before winterization. Blue is cold water and red is hot water. There should be valves somewhere near them. For normal operation the valves should be closed. Sounds like one is partially open or leaking.
Jun 09, 2017 | Cruiser RV RVs
I want to replace canvas on jayco camper
take the camper to a jayco service center and get the correct replacement items for that camper
then it is a matter of removing all the fitting strips to allow removal of the old canvas and the fitment of the new items
a clue her is to when the new canvas id fitted is to leave the camper opened up and to wet the new canvas with silicon fluid and allow it to dry put before folding it away
why , it stops water coming through the canvas when touched in the rain and prevents mould if folded away when wet
Jun 14, 2016 | Jayco 2008 Baja 10Y
Where is serial number on old singer sewing machine
The serial number could be located anywhere. Usually it is stamped into the metal--look at the back of the machine or even underneath. Note--older Singers do not have model numbers, only serial numbers.
This may help you learn more about your machine when you do locate the serial number:
Singer Sewing Machine Company Serial Numbers
Jan 01, 2016 | Singer Sewing Machines
Find Number Serial
I'm pretty sure this is the serial number, I found it on their site (http://www.convaid.com/cruiser-seat-width-transit-ready-p-74-l-en.html): HCPCS E1236
May 07, 2013 | Convaid Cruiser Stroller Chair
Were is the serial number on a 1992 wilderness camper
Normally a silver tag up in front left corner, stuck on side . If worn off, you may be able to look real close on tongue for numbers as well, as on some models they were stamped into frame. Look inside all your cupboards, closets etc, just in case too.
Feb 12, 2010 | Precision Camera Serial Number and...
Can't fold down a razor cruiser for storage, how do you do it?
There are two steps to release the handle for folding. Pressing the thumb lever is one step and the other is lifting the handle bracket up. The handle is held in place by two metal pins (one on each side of the handle bracket). The pins slip down into a notch on the scooters bottom bracket. If the lever won't push, you will need to spray some WD-40 or other lubricant on it as they do tend to rust. Once you have the thumb lever where it can be pressed down, you can then lift the handle out of the bottom bracket. This may be stuck as well so a light tap with a hammer may be necessary to release the handle.
Mar 31, 2009 | Razor Scooters Cruiser Scooter
Fiat ducato van, the hand brake light is always on
Hi! U should check the hand brake switck it could be stock in the close position.
Jan 29, 2009 | 1995 Toyota Land Cruiser
Locks & Locksmithing Logo
52 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
