If your Midea Cube 20-Pint Smart WiFi Dehumidifier is stuck on "Water Level 50%" even though the tank has been emptied multiple times, you can try the following steps to reset it:
Unplug the dehumidifier from the power source and let it sit for 10-15 minutes.
While the dehumidifier is unplugged, remove the water tank and check for any obstructions in the water tank outlet or on the float switch.
Clean the water tank with warm water and mild detergent, then dry it thoroughly before replacing it in the dehumidifier.
Plug the dehumidifier back in and turn it on. If the water level indicator still shows 50%, try pressing and holding the "Water Level" button for 3-5 seconds to reset the sensor.
If the issue persists, try performing a factory reset on the dehumidifier. To do this, press and hold the "Timer" and "Mode" buttons simultaneously for 3-5 seconds until the display panel shows "F". Then, press the "Power" button to turn the dehumidifier off, unplug it from the power source, and wait for 5-10 minutes before plugging it back in and turning it on.
If none of these steps resolve the issue, it may be necessary to contact Midea customer support for further assistance or to have the unit serviced by a professional.
That would depend upon the size of the dwelling. If it is a smaller, open-concept type of place, a stand-alone will work fine. If it to operate unattended, you would need to have a drain available to collect the moisture collected so the unit would not fill up and shut off. If the place is larger or has many rooms where air flow is restricted, then the humistat is the better option, since it will use the homes HVAC system to recycle the air and remove the excess humidity. Also, since the A/C coil in the air handler is already connected to a drain, moisture removal becomes a non-issue.
After sitting so long did you drain out the old gas as well you could have a dirty and plugged carburetor. Just to try an experiment take the spark plugs out and squirt a little gas into the plug hole and put the plugs back in and hook up the wires and see if it tries to start. If it does then you know the carburetor or dirty gas lines needs cleaning. if you do this several times there is a chance it may keep on running..If there is a gas filter it may need changing.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Still have the receipt? cause if its a stand alone i would say return it, short cycling could be anything from bad sensor or controls to it over heating etc., if its one on your central system, well fire your installer and call a reputable contractor.
The only thing that could cause it to short cycle it other wise would be a half opened half closed float contact switch on the internal storage for the h20 removed form the air (assuming its a prattle stand alone eat that is)
Possibly the primary humidity sensor behind right side grill. Unit MUST be unplugged from outlet. Take right side grill out, unplug sensor from wire socket and plug back. If no help, you need new sensor.
The sealed system of the Kenmore 54701 dehumidifier is warranted (Parts & Labor) by Sears for five (5) years. Since the fan in your unit runs but the compressor doesn't, I suggest that you return it to Sears and request (demand) a new replacement unit under their warranty. I say "demand" because Sears will undoubtedly tell you that the problem is due to some "other" component which is not covered, and will charge you mega-bucks to repair it. Been there - - done that.
FYI, read the (very low) customer reviews of these units on Sears website and you'll see you're not alone in your experience with Sears' inferior quality units.
Above all, do NOT pay to have it repaired. That money is better spent on the purchase of a far more reliable brand of dehumidifier - - (which will most likely cost less that what you paid for the Sears unit).
make sure that the circuit breaker for the electrical plug is not faulty, cause after a long lifetime of high amperage flowing through it, the springs will start to get weak. If this is the case then you need to replace the electrial breaker. Otherwise, make sure that the power system on the system is not pulling too much current, Or that there is not a faulty breaker inside the printer itself, which has become weak.
or you can remove all of the plugs from the console: AC, remote sensor, AV. This is important: You must also unplug the AC from the electrical outlet. Then wait 45 seconds, then plug the AC adapter back into the wall and your console. Power On.
