Question about Toshiba e-Studio 35 Copier
When we moved our copier it was laid down on its side. Now the scanner assembly is a mess. The heads moved and the cables came off the pulleys. Can this be fixed?
  • 1,110 Answers
Yes it can be fixed. You will need to call an authorized Toshiba Service Center as the tech will need the scanner "jigs" to reposition the scanner back to factory specs. Also note this may not be the only damage to the machine. Placing this machine on it side while moving may have spilled toner and or developer inside the machine. This may require dis-assembly and cleaning as well as replacement and recalibration of the developer. If you have a Toshiba Dealer near you, I would ask them what they charge per hour for labor and if they have a technician trained on this model. I would estimate 3 to 4 hours labor time to correct these issues. If needed, add another $100 for Developer.
Good Luck and Thank You for using Fixya.
Posted on Jul 08, 2010
C3100 call service
C3100 is a scanner carriage problem... The error code indicates that the "home signal" is not reaching the main board in the required time; The problem could be a bad board, bad motor or something mechanical...
Keeping it simple: look through the copy glass; there are two main parts or carriages. The first part is the assembly with the lamp and single mirror. The second part is the assembly with two mirrors. Both of these *ssemblies ride on rails and are connected to each other by a system of cables and pulleys. When unboxed, the KM3035 has 3 yellow screws on the upper left cover that lock the scanner assembly to prevent damage during transit... were these screws removed? Does the scanner assembly move at all when you power the machine on? Look through the copy glass: the scanner cables should be seen connected to the carriages and going around the pulleys; the cables should not be loose or laying on the deck. The home sensor might not be visible to you if the both carriages are in the way, but it is a small black object with two projections. A flag on the carriage slides between the gap created by the projections (this is the home position). Looking through the glass, the sensor is located at the left rear corner and it should not be hanging or tilted.
Feb 06, 2013 | Kyocera Office Equipment & Supplies
My workcentre PE 220 scanner locked . How can I scanner unlocked? Because there is no button in scanner???
Rick Kasper's solution is a good start. There is no mechanical lock for the scanner head (below the glass plate upon which the material to be copied may be placed).
The "scanner" in this context is the optical head that slides along a rail below the glass plate. Its movement from the home position is monitored by a photo transistor. If the scanner head fails to release from its park position under the left hand window as it should, including during the power-up sequence, the failure message will appear.
If you hear a fairly loud whining sound (from the stalled scanner head drive motor) during the power-up sequence followed by the "scanner locked" warning, it indicates that the scanner head is hung up mechanically in its park position below the left hand scanner glass. Verify this by opening the Automatic Document Feeder (ADF) before powering up and note lack of movement of the scanner head assembly. Following the sequence outlined in the service manual, remove the scanner + ADF assembly, open the scanner assembly and move the scanner head on its rail to free it up. Take care to reassemble the scanner head with the white nylon slides properly placed on either side of the head.
If however, during the power up sequence you do not hear the whining noise, it is a sure indication that the motor has either failed or that no drive power is applied, but this is rare compared to mechanical hang-up.
Sep 21, 2011 | Xerox WorkCentre 220 All-In-One Laser...
Ive got a chevy tahoe 2002 and the passenger side window wont roll up all the way. When i get it up all the way it slides down about 4 inches
Assuming you have power windows. Had similar problem on 2000 Buick LaSabre. Had to replace electric motor drive assembly inside of door. The motor moves a steel cable around nylon/plastic pulleys. In time the cable cuts into the pulley. Access motor assembly by removing inner door panel. I had to purchase assembly from the dealer ($$$). Digital snapshots as you disassemble will help you reassemble. Job took about 1.5 hours, and I had never done it before.
Feb 20, 2011 | 2002 Chevrolet Tahoe
Where is the serial number on a mx870 printer ?
On the bottom of the printer or on the side of the box, if you still have it.
Nov 30, 2010 | Office Equipment & Supplies
How to change head gasket?on gas v6. ISUZU RODEO Vin #452CG58V554341786
This is the same for many years. I will send this in 2 post it is to long. Hope this helps you. From the '00 Rodeo workshop manual:
Cylinder Head Assembly
Removal
1. Disconnect battery ground cable.
2. Disconnect connector of intake air temperature
sensor from intake air duct.
3. Remove PCV hose from air intake duct.
4. Remove nut from air intake duct bracket and loosen
hose clamp on throttle body. Remove air intake duct
assembly with air cleaner cover.
5. Remove intake air duct bracket from cylinder head.
6. Drain engine coolant.
7. Move drive belt tensioner to loose side using wrench
then remove drive belt.
033RW001
8. Remove radiator upper hose from engine side.
9. Remove four nuts of exhaust front pipe.
10. Remove three bolts from generator bracket then
remove the generator with brackets.
065RW025
11. Disconnect crankshaft angle sensor connector.
12. Disconnect knock sensor connector.
13. Remove heater hose from adapter side.
14. Remove heater hose from water pipe side.
15. Remove water hose between water pipe and throttle
body.
16. Remove fuel pipe joint eye bolts from fuel rail
assembly and remove fuel pipe bracket with electric
ground cable.
042RW001
17. Disconnect connector for evaporation valve.
18. Remove canister hose.
19. Remove fixing nut of intake manifold stay from
cylinder block side.
025RW002
20. Remove two bolts from intake manifold for water pipe
support and remove cylinder head assembly.
21. Remove engine harness cover and disconnect three
connectors from chassis harness on left rear side
engine compartment.
22. Disconnect connector for power steering pump
pressure switch.
23. Remove four bolts and remove crankshaft pulley.
ENGINE MECHANICAL (X22SE 2.2L) 6A–23
020RW014
24. Remove two bolts and nut then remove timing belt
front cover.
25. Remove ventilation hose from cylinder block side and
from cylinder head side.
26. Remove two bolts, ignition cable cover and remove
ignition cables from spark plug.
27. Disconnect camshaft angle sensor connector.
28. Remove ten bolts and remove cylinder head cover.
29. Remove fixing bolt of timing belt tensioner then
remove timing belt tensioner.
020RW010
30. Remove timing belt.
CAUTION:
 Do not bend or twist belt, otherwise its core could
be damaged. The belt should not be bent at a
radius less than 30 mm.
 Timing belt drive gear counterhold with J–42620.
 Do not allow oil or other chemical substances to
come in contact with the belt. They will shorten
the life.
 Do not attempt to pry or stretch the belt with a
screw driver or any other tool during installation.
 Store timing belt in cool and dark place. Never
expose the belt direct sunlight or heat.
31. Remove two idle pulleys, the left side with idle pulley
bracket.
32. Remove two bolts and stud bolt and remove timing
belt rear cover.
33. Remove camshaft angle sensor
34. Disconnect engine oil pressure switch connector.
050RW005
35. Remove camshaft assembly exhaust side.
36. Use J–42623 to remove ten cylinder head fixing bolts
012RW007
6A–24 ENGINE MECHANICAL (X22SE 2.2L)
Installation
1. Put cylinder head gasket on the cylinder block.
012RW011
2. Install the cylinder head assembly, tighten cylinder
head bolts by four steps tightening method in the
following sequence to the specified torque.(use
J–42623)
Torque: 25 N·m (18 lb ft) + 90 + 90 + 90
012RW006
3. Install camshaft assembly exhaust side and tighten
camshaft bracket bolts in the sequence to the
specified torque.
Torque: 8 N·m (5.9 lb ft)
015RW014
4. Connect engine oil pressure switch connector.
5. Install camshaft angle sensor.
6. Install the timing belt rear cover and tighten three
bolts to the specified torque.
Torque
M6 bolt: 6 N·m (4.4 lb ft)
M8 bolt: 8 N·m (5.8 lb ft)
020RW012
7. Install left side idle pulley with idle pulley bracket,
tighten to the specified torque and install right side
idle pulley and tighten to the specified torque.
ENGINE MECHANICAL (X22SE 2.2L) 6A–25
020RW016
Oct 09, 2009 | Isuzu Rodeo Cars & Trucks
HP6110 OfficeJet scanner squeaks
Make sure that the scanner is level and not twisted as this will put unnecessary strain on the scanner frame and pulleys. If your system has springs on the pulley cables then this may be the cause of the problem as they may be worn out or chafing or rusted and need replacing.
Also make sure that the guide rails are not obstructed and brush them out and clean thoroughly and if necessary carefully apply some silicone grease to them.
Also check that the carriage assembly is not bent or twisted which will put unnecessary strain on the drive mechanism and pulleys.
Also check that the pulleys are not bent or the pulley mounts are not bent.
Sep 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Timing for tropper 6cly and 4 camshafts and 24 valves model 2000
Timing Belt
Removal
2. Remove air cleaner assembly.
3. Remove radiator upper fan shroud from radiator.
4. Move drive belt tensioner to loose side using wrench
850RW001
Legend
(1) Crankshaft Pulley
(2) Cooling Fan Pulley
(3) Tensioner
(4) Generator
(5) Air Conditioner Compressor
(6) Power Steering Oil Pump
(7) Drive Belt
5. Remove cooling fan assembly four nuts, then the
cooling fan assembly.
6. Remove cooling fan drive pulley assembly.
7. Remove idle pulley assembly.
8. Remove serpentine belt tensioner assembly.
9. Remove power steering pump assembly.
10.Remove crankshaft pulley assembly using
5–8840–0133–0 crankshaft holder, hold crankshaft
pulley remove center bolt, then the pulley.
11. Remove right side timing belt cover then left side
timing belt cover.
12. Remove lower timing belt cover
13. Remove pusher.
CAUTION: The pusher prevents air from entering
the oil chamber. Its rod must always be facing
upward.
014RW011
Legend
(1) Up Side
(2) Down Side
(3) Direction For Installation
(4) Locking Pin
14. Remove timing belt.
CAUTION:
1. Do not bend or twist the belt, otherwise its core
could be damaged. The belt should not be bent at
a radius less than 30 mm.
2. Do not allow oil or other chemical substances to
the life.
3. Do not attempt to pry or stretch the belt with a
4. Store timing belt in a cool and dark place. Never
6A–30 ENGINE MECHANICAL
Installation
NOTE: For correct belt installation, the letter on the belt
must be able to be read as viewed from the front of the
vehicle.
014RY00042
Legend
(1) Crankshaft Timing Pulley
(2) RH Bank Camshaft Drive Gear Pulley
(3) Water Pump Pulley
(4) Idle Pulley
(5) LH Bank Camshaft Drive Gear Pulley
(6) Tension Pulley
014RY00043
Legend
(7) Alignment Mark on Oil Pump.
(8) Alignment Mark on Timing Belt
(9) Alignment Mark (notch) on Crankshaft Timing
Pulley.
(10) Alignment Mark (groove) on Crankshaft Timing
Pulley.
014RW006
Legend
(1) Timing Belt
(2) Engine Rotation Direction
(3) Cylinder Head Side
1. Install timing belt.
1. Align the mark (notch) of crankshaft timing pulley
(2) with mark on oil pump (1).
Align the mark (groove) on the crankshaft timing
pulley (3) with alignment mark (white dots line) on
the timing belt (4).
NOTE: When timing marks are aligned, No.2 piston will
be on Top Dead Center.
014RW003
Legend
(1) Alignment Mark on Oil Pump
(2) Groove on Crankshaft Timing Pulley
(3) Alignment Mark on Crankshaft Timing Pulley
(4) Alignment Mark on Timing Belt
ENGINE MECHANICAL 6A–31
2. Align the alignment mark on the RH bank
camshaft drive gear pulley (2) to the alignment
mark of the cylinder head cover RH (3).
3. Align the alignment mark (white line) on the timing
belt (1) with alignment mark on the RH bank
camshaft drive gear pulley (2) (on the left side as
viewed from the front of the vehicle) and put the
timing belt on the camshaft drive gear pulley.
Secure the belt with a double clip or equivalent
clip.
014RW00004
Legend
(1) Alignment Mark on Timing Belt (White line).
(2) Alignment Mark on Camshaft Drive Gear
Pulley.
(3) Alignemnt Mark on Cylinder Head Cover RH.
4. Align the alignment mark on the LH bank
mark of the cylinder head cover LH (3).
5. Align the alignment mark (white line) on the timing
belt (1) with the alignment mark on the LH bank
camshaft drive gear pulley (2).
When aligning the timing marks, use a wrench to
turn the camshaft drive gear pulley, then set the
timing mark between timing belt and camshaft
drive gear pulley and put the timing belt on the
clip.
NOTE: It is recommended for easy installation that the
belt be secured with a double clip or equivalent clip after
it is installed the timing belt to each pulley.
014RW00005
Legend
Pulley.
(3) Alignemnt Mark on Cylinder Head Cover LH.
6. Install crankshaft pulley temporarily and tighten
center bolt by hand (do not use a wrench).
Turn the crankshaft pulley clockwise to give some
belt slack between the crankshaft timing pulley
and the RH bank camshaft drive gear pulley.
2. Install pusher and tighten bolt to the specified torque.
Torque : 25 N·m (2.5 Kg·m/18 lb ft)
1. Install the pusher while pushing the tension pulley
to the belt.
2. Pull out pin from the pusher.
NOTE: When reusing the pusher, press the pusher with
approximately 100Kg to retract the rod, and insert a pin
(1.4 mm piano wire).
014RW011
Mar 18, 2009 | 2000 Isuzu Trooper
Cpoier
Feeding is not completed within the specified time after starting feeding. (The scan head locking switch is locked)
Underneath the left side of the scanner is a locking mechanism for the scanner.  Turn it in the opposite direction and see if that works.
If that doesn't do the trick, there is binding on the ribbon cable underneath the scanner.  This can be fixed by removing the slack from it and taping the ribbon cable down with scotch tape.  make sure there is enough slack in the cable to move the scanner from one end of the glass to the other.
Sep 17, 2008 | Sharp AL 1631 Copier
Officejet 7310: Scanner Failure
If you get a "Scanner failure" message then the problem is the motor itself. Notice how the motor works fine when the scanner is moving slowly, like copies or faxing with the original laid on the glass. HOWEVER, the scanner failure comes up when you use the automatic document feeder on top. Why? Because the scanner assembly has to move to the other side of the printer at high speed to get into position, and it's the high speed movement that triggers the error on the printer. The motor is expensive, part number Q3450-60003. Many other models use the same motor, maybe you could find one cheap somewhere and swap the motor?
Jan 10, 2008 | HP OfficeJet 7310 All-In-One InkJet...
WON'T SCAN
Did you have things apart far enough to mess with the scanner.  The scanner should move to one side when it first goes on, and then trip a sensor (home position sensor).  Also, the scanner is probably belt or cable driven.  Check to see that the belt is somewhat tight, and that the gears and pulleys leading to the scanner motor are in place and not broken.
Oct 27, 2007 | Lexmark X3470 All-In-One InkJet Printer
391 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
