Question about Dell Inspiron 6400 Notebook
My computer will not turn on one light stays on two otheres flash then it turns of
    Sniper:
  • 72 Answers
Hey,
Try this, unplug every thing that is connected to the notebook including the power supply. Remove the battery of the unit. Now press and hold the power button on the notebook for 30 to 40 seconds. Now re-connect every thing and try to power up the machine, you should be up and running.
The cause of this behaviour is the buildup of static on the machine.
Posted on Jul 08, 2010
  • Dell Master
  • 8,404 Answers
Your computer is not completing the POST. You probably have a memory error.
Computer turns on and off
One at a time, unplug all wired acessories on the motherboard and turn pc on. When pc stays on, you will find the bad connector or component. Make sure to plug all others in one at a time to confirm only one bad connection. If no bad connections show, remove all components from motherboard one at a time until pc stays on.
Sep 19, 2013 | Gateway Computers & Internet
When break pressed turn signal turns stays on and doesnt flash
My first guess would be a ground problem. The bulbs are mounted in plastic sockets and grounded to the car by a black wire. If one socket is not grounded it will try to ground thru a different socket.
I would check for voltage and ground on each socket in the back.
Aug 03, 2012 | 2001 Chevrolet Malibu
Check engine light stays on
On 1993 model turn the switch to on but no crank to start turn off turn on turn off turn on and let on that position, when all lights turn off the check engine light will star flashing for ej: two flash a quick pause and three flashes will be code 23 after a longer pause will star other code , code 55 is end of codes. after you have the codes can search with it,
Jul 28, 2012 | 1993 Jeep Grand Cherokee
One of my turn signals flash but the other stays solid
could just be a faulty relay, if you have not had a problem before i would think it was the relay.
Jul 15, 2017 | Cars & Trucks
When turning on my monitor - the blue light is on
This could mean that you video card is bad or going bad. Also that the monitor is going out too. Its one or the other.Try to plug the monitor into another computer to test it first. It will give you an idea where to start. then move to the video card.
Feb 15, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Monitor will not stay on
Generally Monitors have a single light in fron pannel, with dual mode colors as Green and Orange.
Green: Everything is OK .
Orange: Everything is OK, except it is not getting
any signals from computer or other source.
Try with any other monitor with your CPU, it may happen that CPU actually not providing any signal to Monitor. Try checking the "NUM LOCK" button on and off, whether it makes the light on keyboard to flash on or off.
If NUM LOCK is woking OK, there is surely some problme with your monitor and you need to get is checked physically with an engineer.
Jan 21, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
My computer monitor will not stay on.
The problem may with the Ram inside your computer
Jul 07, 2009 | Dell E153FP 15" LCD Monitor
Strange behavior
Initially, pls try disabling the hibernation feature of your computer.
Other than that, would appreciate if you can post back the make and model of your computer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Computers & Internet
Black Screen / Computer Stays in Standby Mode
Completely remove the battery and unplug the power cord for a few minutes. Reinsert battery and power up. You can also hit F8 when starting and see if you can boot into safe mode.
Sep 06, 2007 | HP Compaq Presario V2000 Notebook
Dell Inspiron 6400 Notebook Logo
100 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
