Screens no longer fit in the window. They did at one time. House is brick. It appears the brick comes up too close to bottom of window. Some windows have a slight bow in them where they meet the brick. I suspect they were not installed correctly when house was built 12 years ago. Do windows have to be replaced?
  • 28 Answers
You have posted this question in a help forum for computers.
I think you need to find a home improvement forum.
Posted on Apr 19, 2008
Our wall mounted air con is set at 16 degrees but it is not cooling the house at this temp. Could it be the thermostat
most wall mounted ac units are designed to only cool a room, not a house
close all the doors to the room along with all windows
generally a 3kw unit (32,000btu )will cool a room 12ft X 12 ft X 9 ft quickly but anything bigger, the time that is taken to bring the temp down gets longer and longer depending on the setting and 16 C is far too low
Dec 07, 2016 | Heating & Cooling
Is it possible to order bricks
We designed and built a house in TN in 2000 and special ordered brick for it. We looked through some samples and chose brick that appeared to have subtle fossil and leaf patterns. The brick was delivered to the house site.
Jan 02, 2015 | Building Materials
I need to replace aluminum windows in a brick home, because the foundation has shifted slightly during a drought making the windows hard to close all the way.
You are not going to get good advice about house windows in a Cars and Trucks category.
The problem is not the windows, it is the opening. It is no longer square and that is the real problem. Just replacing the window in a bad opening will not help. You need to square up the window in the opening, probably with shims.
Nov 24, 2013 | Cars & Trucks
How to hanging curtain hardware
The most important thing with fitting hardware is to find the studs in the wall for brick veneer or in the case of solid brick, you must ensure the wall plug goes deeper than the wall plaster. The wall plug needs a hole drilled for a good fit- not loose or the plug will rotate as you tighten the screw.
Side openning - you can adjust the curtain postion after installation by lifting the cord from its clip on the carriage and moving the carrier along to the correct position.
On one of the carrier slides there needs to be an overlap for the little carry bar for the curtain hooks so you do not get a gap when the curtain is shut.
When designing curtains there should be at least 2.5 drops ( window cobverage) for a good looking curtain.
To prevent heat loss thermo syphoning up the window, you should close in the pelmet on the top. Just 3 ply will do this fine.
For one side pull, you need to screw the cord pulley end to the floor or skirtin via the spring provided and set the length of cord by shortening at one of the carriage slides.
I may be rambling here, but a simple stud finder is really handy to find the studs (vertical timbers) It also shows power cables but they will not be as wide. Any photos of your house under construction is good to show where the timbers and power cables are.
It is a good idea not to hit the power cables - tends to burn things - like houses.
Anyway if you describe waht sort of fittings you have you may get more useful info.
Dec 28, 2011 | Cameras
Our toilet is 127mmsfrom the wall to the centre of the s fitting and most toilets are 140mm, how can we fit a new toilet pleaase, also the water pipe is on the left hand side and toilets i have loked at...
Toilets water pipes can come on either side majority are on the left side when facing toilet.A longer water supply line can be used for the water connection if the toilet has it on the opposite side.A plumbing supply house and some good hardware stores will carry a close rough toilet that can set 50 mms closer to the wall than a standard toilet. Generally toilets are measured from the wall to the center of the drain in the floor which standard is 304.8 mm so a close rough would fit with a drain 254 mms from the wall
Jun 22, 2010 | Plumbing
When I turn on the range I am getting orange flames on all 6 burners. The problems seems to be intermittent but when it happens the flames are wild unless the burner is on simmer.
try it with the window open and again closed. if flames are good with window open you will need fit an air brick in the wall or unblock the brick you have.
Feb 15, 2010 | Dynasty DGRSC 36-6 Gas Kitchen Range
LF appears in time remaining window.
LF means long fill (taking to long to fill tub, Check inlet screens inside the valve and sometimes they are inside the hose fitting. Make sure hoses are not kinked & if hoses are over 5 years old REPLACE.
Dec 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Ive got an angle iron to fit but unsure how to install in it.im taking the window out and putting french doors in the solder bricks on top of window are lose hence the iron im just unsure how to fit it
The horizontal part fits into the side bricks--you need to remove mortar to allow it to slide in. The upper bricks need to be reset on top of the iron in fresh mortar. Hope you bought a heavy piece of iron to span the distance and support any weight above.
Oct 24, 2009 | Saws
My ps3 turns on but nothing will appear, it used to show the splash screens (the waves) and it would just stay there... but now it wont even show anything?? help... i think i might just send it in, but...
okay i think I know what you have either your ps3 overheated or your ps3 got bricked,a bricked system is when the firmware or operating system gets delited or coruped. to my knowlage I don't know how to fix a bricked ps3.
Apr 08, 2009 | Sony Playstation 3 (PS3) Console
Jaguar rear window removal
I followed the instructions given by your expert Richard.His instrutions were clear and precise,and I had the problem solved in 5 minutes.best regards A.Taylor
Jul 02, 2008 | 2000 Jaguar S-Type
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
