Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Can i get instructions to download on how to change the chain on my homelite 33cc chainsaw with 14.35 chains
  • 6,826 Answers
Got to homelite.com and input your model number.
WARNING:
When servicing, use only identical Homelite
replacement parts. Use of any other parts may
create a hazard or cause product damage.
WARNING:
Always wear safety goggles or safety glasses
with side shields during power tool operation or
when blowing dust. If operation is dusty, also
wear a dust mask.
GENERAL MAINTENANCE
Avoid using solvents when cleaning plastic parts.
Most plastics are susceptible to damage from
various types of commercial solvents and may be
damaged by their use. Use clean cloths to remove
dirt, dust, lubricant, grease, etc.
WARNING:
Do not at any time let brake fluids, gasoline,
petroleum-based products, penetrating
oils, etc., come in contact with
plastic parts. Chemicals can damage, weaken or
destroy plastic which may result in serious
personal injury.
LUBRICATION
All of the bearings in this product are lubricated with
a sufficient amount of high grade lubricant for the
life of the unit under normal operating conditions.
Therefore, no further lubrication is required.
REPLACING THE guide BAR AND
CHAIN
See Figures 34 - 43.
DANGER:
Never start the engine before installing the
guide bar, chain, clutch cover, and clutch drum.
Without all these parts in place, the clutch can
fly off or explode, exposing the user to possible
serious injury.
maintenance
Fig. 34
Fig. 35
Fig. 36
WARNING:
To avoid serious personal injury, read and
understand all the safety instructions in this
section.
n Always place the switch in the stop “ ” position
before you work on the saw.
clutch
cover
Run
Position
sprocket
Page 26 — English
cutters
bar
groove
chain drive links
Fig. 38
maintenance
chain rotation
chain drive links
Fig. 37
n Make sure the chain brake is not set by pulling
the chain brake lever/hand guard towards the
front handle to the run position.
NOTE: When replacing the guide bar and chain,
always use the specified bar and chain listed in
the Bar and Chain Combinations section later
in this manual.
n Wear gloves when handling the chain and bar.
These components are sharp and may contain
burrs.
n Press in on the clutch cover lock knob and rotate
counterclockwise until the clutch cover can be
removed.
n Remove the bar and chain from the mounting
surface.
n Remove the old chain from the bar.
n Lay out the new saw chain in a loop and
straighten any kinks. The cutters should face
in the direction of chain rotation. If they face
backwards, turn the loop over.
n Place the chain drive links into the bar groove
as shown.
n Position the chain so there is a loop at the back
of the bar.
n Hold the chain in position on the bar and place
the loop around the sprocket.
n Fit the bar flush against the mounting surface
so that the bar studs are in the long slot of the
bar.
n Replace the clutch cover ensuring that the
adjusting pin in the clutch cover is in the bar
chain tensioning pin hole and that both bar
studs are securely in their respective holes in
the clutch cover.
NOTE: The adjusting pin may need to be slightly
repositioned with the chain tensioning dial so
that it is aligned with the position of the bar chain
tensioning pin hole.
n Replace the clutch cover and rotate clutch
cover lock knob just enough to hold the cover
in position.
NOTE: The bar must be free to move for chain
tension adjustment.
n Lift the tip of the guide bar up to check for sag.
n Remove all slack from the chain by rotating the
chain tensioning dial clockwise until the chain
seats snugly against the bar with the drive links
in the bar groove.
n Release the tip of the guide bar and, if the chain
sags, turn the chain tensioning dial clockwise.
Repeat this process until sag does not exist.
n Hold the tip of the guide bar up and tighten the
clutch cover lock knob securely.
Posted on Jul 08, 2010
Homelite chain saw 3316c
ok check the magneto if rusty clean with fine grit paper then try it if not then may be time to change the coil and magneto..
Jul 13, 2014 | Garden
Need replacement part
Google Homelite PN# 310508001 and you will find it at many locations
May 09, 2013 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
Homelite 16" 33cc chainsaw. Sarts but win't keep
Hello rick.... Get an aerosol can of starter fluid at your local autoparts store. Also get an assistant. Remove the air filter and start it up. Have your helper squirt some starter fluid into the air intake to keep it running for a couple minutes until the partial blockage in the carburater clears. Joe
Thanks for choosing Fixya!
Mar 12, 2011 | Homelite Garden
What is the mix for my Homelite 16" 33cc chainsaw?
50:1 is the fuel to oil ratio. Never use petroleum oil (engine or boat motor oil). Always use a synthetic saw oil available from home centers, hardware stores and saw dealers. The bottles are usually graduated to various ratios for a gallon of fresh gas. Always premix in it's own container and shake the container thoroughly each time just before filling the tank to prevent oil starvation. Be sure to use bar/chain oil for the chain as well, and keep the chain sharp and well adjusted. Hope this helps!
Nov 14, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Can i download a manual for the homelite 33cc chainsaw to get instructions for how to put a new chain on
Release the chain brake. Back off the chain adjustment screw several turns and remove the two large cover nuts. Remove the drive cover, then pull the bar back toward you. This will allow the old chain to be removed. Remove the bar and clean the entire area where the bar mounted. Check the outside edges of the chain groove area for any flaring out of the bar metal due to wear. Use a flat file to cut off this flaring edge (at about 45 degrees) so that nothing projects beyond the bar vertical surface on both sides. Turn the bar upside down to even the wear in the chain groove. Clean the oil holes in the bar end including the small channels that bring oil from large holes out to the chain groove on each side and clean the entire chain groove. Insert the bar, then feed the new chain with the teeth on the lower run cutting toward you, onto the sprocket, then work it over the entire bar and pull the bar out as far as it will go. Install the cover (which has been cleaned too) and run the nuts on finger tight (make sure the adjustment tang dropped into a large hole at the bar rear). Turn the adjustment screw CW until the chain ceases to droop from the lower bar, but the chain can still be pulled by hand. Tighten the large nuts firmly and recheck chain tension--if ok, start the engine and hold the bar tip near a piece of cardboard while the engine runs at speed for several moments--you should get a thin line of oil thrown off onto the cardboard. Hope this helps!
Jun 11, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
HOMELITE CHAIN SAWS LOOKING for a parts manual to repair and replace damage parts. model ut109470 33cc family 4hcps0384aa sin #AGO780395-03-4 Can you help
Go to: http://hcpi.arinet.com/scripts/EmpartISAPI.dll?MF&app=HNL531&...
This gets you to drawings and part numbers of the entire saw. Also, for an excellent article on the Walbro carburetor, go to: http://www.drystacked.com Hope this helps!
May 02, 2010 | Homelite ZR10926 16 Chain Saw
Chain not moving
Perhaps. The chain and bar get very hot, sometimes causing the chain to bind, there is a reason for the bar oil reservoir. You may have burned out your clutch. Your chain may be excessively tight. I suggest you find a neighborhood chainsaw seller/mechanic and pay for a quick inspection. While there ask for a 10 minute instruction on how to use your saw. Purchase of a complete set of personal protective gear sounds like a good idea too. HTH
Lou
Sep 17, 2009 | Homelite Garden
CHAIN SAW QUITS CUTTING AS IT HITS WOOD.
The make, model, and occationally the serial number help us solve your problem.
Does the engine quit running? (Carburator needs adjustment)
Or does it continue running and chain stops? (need clutch refaced or replaced.) (to aggressive a chain for the size of the engine)
I think you replaced parts unnecessarily. Maybe quicker and cheaper to visit your friendly neighborhood chainsaw shop. A good one can repair it even if they do not sell your brand.
HTH
Lou
Sep 09, 2009 | Homelite Garden
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
282 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
