Question about Rockford Fosgate Punch 800a2 Car Audio Amplifier
Wiring configuration 800a2
I have a punch 800a2 and 2 jl 12w3 dual 6 ohm, should it be ran as 6 ohm,or i can wire for 1.5 ohm but is this amp stable for 1.5 ohm load? and how should i wire it if i just wanted to bridge it? thnx please help!! :(
  • benms79 Apr 18, 2008
    i have a punch 800a2 and 2 jl 12w3 dual 6 ohm, should it be ran as 6 ohm,or i can wire for 1.5 ohm but is this amp stable for 1.5 ohm load? and how should i wire it if i just wanted to bridge it? thnx please help!! :(
    this is a punch 800a2 older one i believe from around 98 99. chrome 1 with the triangled look to it when end caps are added.
  • 323 Answers
Http://mobile.jlaudio.com/support_pages.php?page_id=161
Here are the diagrams for running dual voice 6 ohm sub's.
Posted on Apr 19, 2008
  • Dalynn Turner Apr 19, 2008
    I wouldn't advise running your subs at 1.5 ohms unless your amp is 1 ohm stable. I ran my sub's at 1 ohm on a two ohm stable amp and my sub locked up. I had to hook my sub up to a battery and pop it to get it to work again LOL! Just for further reference ;)
  • 631 Answers
3 ohms per channel or 6 ohms bridged are the only options. 3 ohms per channel is a better option.
I have 1 12in. 4 ohm punch dvc sub and a punch
Check crutch fields website for sub wiring detailed wiring plans
Oct 07, 2014 | Car Audio & Video
Just wanted to know best way to wire 2 12' JL 12W3-D6 subs to Direct-D mono D-800 amp?In series or parallel?Considering subs are 6 ohms each.can you help me?
In playing the math game in audio, I would recommend wiring them in series. This way you can take them down to 3 ohms and still maintain a usable impedance on the amp. Plus you'll get the added benifit of actual usable output.
Taking most amps into a higher impedance (in parrallel it would be 12 ohms) you might over stress the amp (trying to get reasonable volume from your setup) and then trip the MOSFETs (or whatever their using today). Not that this will ruin the amp, but repeated tripping of the current reading ICs will eventually render the amp useless.
All being, most car audio is designed to be stable at 2 ohms anyway. My biggest peave with that is that sonically, 2 ohms slaps the speakers instead of driving them, not to mention limiting the actual headroom.
Hope that helps...
Oct 07, 2010 | Jl Audio 12W3 Car Subwoofer
Try to install 3 12w3d6 subwoofers connecting 3 sub together to put them in box
You need to wire them according to the limitations of your amp you can pull a 1 ohm overall load just by connecting all of your coils in parallel- or you can get an overall load of 4 ohms by wiring each sub individually in a series configuration which will yield a 12 ohm load per sub -and then wire the 3 sets in parallel which will bring your ohms back down to 4. You can do a lot with that many coils it depends on your amp really-ideally a 1 ohm stable class d mono amp that is 1000-1500 watts rms would knock the **** outta those things JL is the good stuff.
Jan 16, 2010 | Jl Audio 12W3 Car Subwoofer
Who to wire JL audio 12w6 to its max
Hello shermalestuc,
The JL Audio 12w6 v2-D4 has dual 4 ohm voice coils that can be wired for either a final load to the amp of 2 ohms (parallel) or 8 ohms (series).
If your amp is 2 ohm stable, the best power solution for a single sub is to use the parallel configuration, both positives and both negatives together and then to the amp.
Nov 08, 2009 | Jl Audio 12W6 Car Subwoofer
How 2 wire 3 jl audio w6 v2
Hello mikey4569mky,
Unless your amp is stable below 1 ohm, there's really only one wiring solution. And that is to series the voice coils making each sub 8 ohms, then parallel all 3 subs to the amp for a 2.67 ohm load. If you parallel the voice coils and then parallel the subs, the impedance will be 0.67 ohms, much too low for most amps.
You could parallel the voice coils and then series the subs for a 6 ohm load, but the amp won't put as many watts into a 6 ohm load. Most are optimized for 4 ohms or 2 ohms. And it's not good to run subs in series anyway.
Here's the wiring diagram.
Hope this helps.
Sep 13, 2009 | Jl Audio 12W3 Car Subwoofer
I have 2 positives and 2 negatives on back of my alphasonik sub, do i connect amp to one side or both sides?
Hello gaz69,
Your PSW815 has 2 ohm dual voice coils allowing you to better match the impedance to your amp. Each voice coil is 2 ohms. If you wire them in parallel (both +'s together and both -'s together and then to the amp terminals), the sub presents a 1 ohm load which is too low for most amps. Wiring the voice coils in series (one + to the other - and the remaining + and - to the amp terminals) results in a 4 ohm load.
This link shows the wiring diagram for both options. If you know for sure that your amp is 1 ohm stable, use Wiring Option #1. If the amp is not 1 ohm stable, use Wiring Option #2.
Hope this helps.
Aug 09, 2009 | Alphasonik PSW815 Car Subwoofer
Three jl w3 single coil
You can't run parrallel on 3 single voice coil subwoofers. If you run all the negatives from each coil and possitives from each coil to one terminal you will be dividing the ohms by 3. I don't think JL ever made a single voice coil 2 ohm subwoofer though. If you ran a parrallel on 3 8 ohms you would be at 2.7 ohms. 3 4 ohm would put you down to 1.3
Feb 27, 2009 | Jl Audio 12W3 Car Subwoofer
Wiring
Run a Jumper from coil 1 + to coil 2 + and a jumper from coil 1 - to coil 2 - and then run + from coil 1 to amp and - from coil 2 to amp. This will put your load to 3 Ohm and that will give you the most power. You could get more by going to 1 ohm but I don't think the mtx amps are stable at 1 ohm.
Sep 30, 2008 | Jl Audio 12W3 Car Subwoofer
Hooking up three 12 in w3v2
It depends on how much power/watts and ohms your amp is stable at if it stable at a 1/2 ohm then you can bridge them in series and this will lower the ohms of the speakers to 2 ohms
Aug 30, 2008 | Jl Audio 12W3 Car Subwoofer
Ohm load???
You can't wire a pair of single voice coil 2ohm subs to achieve a 2 ohm mono load. Too bad you don't have 2 four ohm SVC's. Sorry
Jun 19, 2008 | Jl Audio 12W3 Car Subwoofer
Car Audio & Video Logo
390 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
