Question about Fellowes 220 Powershred Strip-Cut Shredder
Fellowes Powershredder, making clunking noise and ceases to shred
Our Fellow Powershredder in intermittently making a clunking noise followed by the paper jamming. We can only put 1 or 2 pages through at a time. We are unable to local someone who repairs these shredders in Northern Ireland.
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 99 Answers
2 probably causes
to check this 1st unplug the machine
now take the top off ,there are 2 screws underneath the front edge of the cover assessable when the door is open, and 2 on the back you will want to back the shreddr up to a table when you take off the top (the sensors and switches are all still connected so this takes the stress off of the wires)
now you will need to remove the blade guards there are screws at the left and right ends of the guards,
once these are removed you should have a pretty good view of the blades, look for any visible obstruction (part of a binder clip or paper clip or metal closure from an envelope for example)
if this wasn't the cause try this
on the side of the blades there is a fan wheel that is connected to the motor. When you turn the fan with your hand you can manually turn the blades, typically you will be able to turn it to a given point and then it will be increasingly hard to turn, you might also notice that the bar on the outer edge of the blades begins to bend at this point. These bars seem to break under fairly low stress and having one break will also produce the symptoms you described. replacing one of those is a costly repair, (cost is largely because it is very time consuming,)
Posted on Oct 30, 2011
Squealing noise when shredding
Have you tried putting any shredder oil on a piece of paper and running that through the shredder?
Feb 03, 2014 | Fellowes Manufacturing Powershred C-480C...
Shredder does not pull paper in anymore, it makes noise, does not shred
Add some paper shredder oil. A shredder needs oil to function properly, oil should be applied every month or more depending on how often you shred. Learn more here: http://hubpages.com/hub/Paper-Shredder-Oil
Jun 13, 2010 | Fellowes DM8C Cross-Cut Shredder
Makes noise blades don't move
you have some teeth missing off of one of the gears, most likely the dual gear thats driven by the motor.
razors
Apr 23, 2010 | Fellowes 220C-2 Shredder
Not completely shredding. one side only makes
need bearing plate call cooks mobileshredding inc. or email cooksmobileshred@bellsouth.net or call bill cook or beverly miller 901-565-8188
Apr 23, 2010 | Fellowes Powershred 220CC Shredder
My Fellowes ps-40 will not shred. The motor is
you have some shredded gears. i don't think fellows has replacement parts for their personal shredder line.
Nov 15, 2009 | Fellowes 3011001 Shredder
Will not shred, but makes clicking noise, will run in reverse
Possible that the actuator which feeds paper in has gotten affected. With the unit UNPLUGGED try looking to see if some paper has gotten wedged in there. If you can disassemble it you might be able to see the problem. Good Luck.
Aug 04, 2009 | Fellowes 3011001 Shredder
Makes a buzzing noise and won't shred. This is a Royal 140 cross cut shredder.
There is something causing the motor to not run properly. My guess is that the shredder gear (one of them) has a tooth stripped. If it is under warranty, call Royal. If not, carefully open up the unit to inspect (unplug it of course). I had a Fellowes PS400 unit and the plastic gear had a tooth broken on it. Fellowes was never able to solve the problem so I trashed it
Mar 08, 2008 | Computers & Internet
Shredder problems
Seems it could be a problem with one of your sensors Fellowes Customer Service can easily and quickly diagnose your problem. 1-800-945-4545
Dec 07, 2007 | Fellowes Powershred 420 Shredder
Fellowes 220 Powershred Strip-Cut Shredder  Logo
794 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
