Question about Dryers
The lint vent got backed up and the dryer shut off mid cycle and I am unable to get it running again. I have pulled the back off and cleaned it out throughly. Is there an emergency cut of or fuse that might have blown. I have checked the wiring diagram and all connections look good. Please help.
    President:
  • 1,430 Answers
The problem is likely the hi- limit thermostat or thermal fuse has blown. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Posted on Jul 08, 2010
GE Spacemaker dryer PCKS443FBWW. Dryer shuts off mid cycle and will not start again until 10 minutes or so go by
Go to www.repairclinic.com and enter PCKS443FBWW. You will be presented with a list of common replacement parts and may be able to view a generic GE video showing disassembly and identifying various parts. Do some preliminary checking to determine whether something got disturbed during the vigorous cleaning.
Nov 11, 2016 | GE Dryers
Electric dryer runs shuts off then starts again on its own
This could be a bunch of different things. #1 detach dryer vent and clean out. Try running dryer with vent not attached for 10 seconds. (Warning, lint and sand will likely come blasting out the back. Reattach and try. #2 Likely is that you have lint buildup inside. Unplug dryer. Remove back cover. Clean air path from exhaust through lint trap. Look inside or remove heater as well. You are likely overheating the dryer and the sensor is shutting it down. #3. Unplug the heating element and then run dryer. Does it shut off still? No Then the sensor on the heating element is bad. Yes then the timer is bad.
Jan 13, 2014 | KitchenAid KEYS750LQ Electric Dryer
I have an Amana gas dryer DLG330RAW that doesn't heat. When I turn on the dryer the ignitor glows red, and ignites a flame for about 5-10 seconds, then I hear a click and the flame shuts down. A few...
it sounds like there's a block somewhere in the system,unplug it,get a shop vac and a brush,vac up all the lint you can see then set the shop vac up to blow and blow all the lint off of the motor,out of the gas tube where the ignitor is and then clean out the duct that the lint filter slides into,pull the vent line off of the back of the dryer and start it and see if that makes a difference,also on the blower wheel housing there's a cycling thermostat part number 37001136 that could be bad or if you use cling free sheets the back of the t-stat could be covered with the white powder from the sheets and lint,you can try cleaning the back of it off but it sounds like you have a block somewhere,if the dryer does run good after you clean it out and run it with the vent line off the block most likely is in the vent line,if it's a long run stick a leaf blower into the vent line and blow all the lint out of it to the outside,make sure there isn't a cage or anything outside that's blocking the vent.i know you say it's clear but check it again before you start changing parts it sounds like bad air movement.good luck and if possible let me know what you find.
Sep 01, 2013 | Amana DLG330RAW Gas Dryer
The dryer is very hot to the touch after only a few minutes in the normal cycle.
inside dryer should be two screws in lint screen holder take out screws the hole piece comes out then you can get farther into the dryer to check for lint is the outside vent clear you could pull dryer vent off run without vent on back to tell if its a venting prom or in the dryer good luck
Apr 05, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
The dryer shut off mid-cycle. It smelled overheated.
Hi
Your thermostat is shutting you off on mid-cycle because your overheating the dryer...
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me thumbs up.
Sep 18, 2011 | Maytag PYE2300AY Electric Dryer
My dryer shuts off mid-cycle. It heats up and the drum turns but it will shut off mid-cycle. Sometimes it will re-start immediately and sometimes it takes about 15 minutes before it will start again. Any...
Hi and welcome to FixYa, I am Kelly.
There are only 2 causes for this....
restricted Air flow or
broken / damaged blower fan wheel
- Start by pulling the lint filter and washing it with vinegar and water then soap and water to remove any dryer sheet particulate that blocks what appears to be clean filters.
- Next clean out every dryer passage you can access.... use a vacuum with crevice tool and a "U" bent wire coat hanger to get all of the lint out of the lint filter area DEEP down inside....
- Then pull off the dryer duct from the rear of the dryer and clean the internal ducting of the dryer.
- After you think you are done cleaning... reverse the vacuum airflow to pressure... if you see lint floating in the air your not done cleaning. Start over...
- Next follow the duct work all the way through to the outside wall and OUTSIDE. Clean the dryer vent on BOTH sides of the vent flapper outside the home.
- Before hooking up / re-connecting the dryer ducting again to the back of the dryer... turn on the dryer. Use the back of your relaxed hand over the duct / vent outlet of the dryer... the air flow must be strong enough to push a relaxed hand / wrist gently away from the hole.. IF you do not have this kind of air flow after your cleaning session... the most probable failure is the hub of the blower wheel / fan is cracked allowing the blower to spin on the motor shaft.
I think once you get things cleaned up... your dryer will return to normal again. My last comment.... and I am being honest. I have made a lot of money... cleaning out dryer duct work after the customer said they had cleaned it very well. I finished the job they started.... and got paid for doing so. I am passing on 40 + years experience here for free because I believe in helping people help themselves..
Thanks for choosing FixYa,
Kelly
Apr 17, 2011 | Dryers
Kenmore gas dryer 110.70882990 runs & heats but shuts off at anytime during any cycle then i restart it & it may run until dry or may shut off a few minutes later ?
Here's a few things to check that most people can do on their own. Keep in mind, that if you start taking the unit apart, you need to unplug the unit first. We don't want anyone getting zapped!
1) Obvious things first. If you have a propane gas dryer, make sure you are not out of gas! Go to the tank, lift the lid, look at the % gauge. If it's pointing at 5% or less, you may be empty or about to run out of gas. Order a gas delivery.
2) Another obvious tip. Check your lint filter. It may be so clogged that your dryer can't breathe. Clean it. Using a flashlight, look down into with the filter opening and see if there is a lot of lint still inside. If so, try using a small vacuum2_bing.gif attachment and clean out lint. This applies to both gas and electric2_bing.gif dryers.
3) Most gas dryers have either a small access panel in the front or at the very least, a peep hole. Open the panel or pop out the plastic peep hole cover so you can view the igniter. Turn on the dryer and watch for orange glow at the burner. If it does not glow, it will not light the gas burner. You may have a broken igniter and will need to replace it or have a new one installed. If you do it yourself, be sure to unplug the dryer and do not touch the very fragile ceramic piece of the igniter. You can confirm it is broken by locating the broken piece below where it is attached or noting it is missing a piece of ceramic on the igniter.
4) This tip applies to both gas and electric models. Another thing you can do is check for blockage in your vent. Unplug the dryer, and pull the unit out as far as you can to get access to the back of the unit. Be careful not to step on or kink the gasline. Pull the venting off the back of the dryer. There is usually a squeeze clamp holding it on. Clean out lint in dryer and from within the vent tube. Some cheap venting are made of expandable plastic or aluminum and can get squished to the point they restrict air flow. Make sure your vent is not collapsed and doesn't get squished when you push the unit back. Once you have cleaned and reassembled it, plug it in turn on the dryer and watch for ignition. If it lights, go outside to the vent cap and check for lint there and make sure your vent flap opens with the hot air flowing out. Clean and adjust as necessary. If you have a long vent tube like I have on mine, then you should clean it out annually. I use a wind-up toilet snake and crank it around knocking lint loose from the walls of the vent. I can always tell when it needs to be cleaned again, when clothes2_bing.gif no longer get dried in the first cycle. If you are unsure of, or unable to perform this task, then you'll need to hire a repairman.
Anyway, these are just the easy, quick fixes that most homeowners can perform on their own. If none of these solve the problem, you will need to troubleshoot further or hire a repairman. Hope this helps. Douglas
Jun 04, 2010 | Dryers
Kenmore 80 series keeps shutting off. new motor and lint line cle
take off the vent line from the back of the dryer,if it runs fine your vent line is blocked or the outside vent where the flapper opens might have a cage on it to keep animals out of the line,it keeps the animals out but it's a lint trap.if you have a long run use a leaf blower and blow out the vent line,if that's ok check the t-stats on the heater box,
Nov 12, 2009 | Kenmore Dryers
Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Vic
Jun 01, 2009 | Dryers
Electric dryer shutting off
most likely cause is the air duct is blocked with lint, some always gets past the screen and builts up in the exhaoust line. not enough air flow, the air gets hotter than normal and trips the over temperature cutout.
for most dryers
clear the fan, and exhaust ducting all the way to the wall, and the outside vent hood, of lint
Sep 22, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
