Question about Panasonic AG-HMC150 AVC Camcorder
Sdhc card not reading, clips show as ! tiles?
  • 85 Answers
Kindly check if your cam is compatible to use SDHC that you can found or read from your manual. if not you need to use only SD card, but if yes try to format your memory card or insert another sdhc card and you found out what is the problem.
thank you
Posted on Jul 08, 2010
Camera saying memory full but card brand new
Not only the size is important, the manual says SD max 2 GB.
But even a 1GB SDHC card won't work, because the camera is not compatible with SDHC and SDXC.
They used to make SD cards up to 4 GB, but most new cards from 1 GB and up are SDHC and above 32 GB the cards are SDXC. Older camera's can't handle these cards, although they look the same.
To read more and to understand compatibility from device versus Memory card, read this:
Secure Digital Wikipedia the free encyclopedia
Apr 10, 2015 | Samsung Digimax D73 Digital Camera
Targus High speed SD/SDHC/MMC Micro SD-TF Card reader could read any of the SD/SDHC/MMC cards earlier when I had purchased it on my Lenovo Think Pad laptop having Window-7 . Now it is showing, when in
This is more likely a problem with the card. If the partition tables corrupt then Windows will see the card but won't be able to read data on the card. You will need to format the card.
Jan 30, 2013 | Electronics - Others
Amilo pi1505 will only read sd card not sdhc
Correct. The PI1505 will work with SD cards but not with SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You can get a SDHC-compatible card reader which plugs into the USB port.
Dec 31, 2012 | Dell Inspiron E1505 Notebook
I have a vir-5850nr touchscreen and it won't read my sd card. It takes forever to load and then it just shows a
Hello there 1st thing u need to know about sd cards with this stereo is that u need to make sure that the sd card is not sdhc, the card has to say simply sd, check that 1st, more then likely thats ur issue, if any stereo says that it takes sd but not sdhc, then u simply need to get the appropiate card, they r 2 very different cards even though the size is the same
Apr 27, 2012 | Soundstream VIR-5850N Car Video Player
Why doesnt my sd card reader work? I put in my gateway laptop and it doesnt work nothing pops up??
You might just have a bad SD card. Also, if you bought a card that is 4gb or more then you need a SDHC card reader. The HC stands for High Capacity. Look at the card to see if it shows HC under the SD. If it does then you need to find out if your card reader can read SDHC. If it can't then you need to go buy a new card reader that can do SDHC.
Jan 28, 2011 | Computers & Internet
A memory card in a digital camera can be read in the camera but not in the computer
My guess is that you have an SDHC (Secure Digital High Capacity) card in the camera, but the card reader attached to your computer can read only the older SD cards. SD cards that are 4GB and larger are SDHC types, and should have SDHC prominently displayed on the label. The card reader on the other hand, was probably made before the SDHC type cards were ever made.
You can find a new card reader that support the high capacity cards for under $20 in many places. Unfortunately, the older card readers can not be upgraded to read the newer cards - but the SDHC readers can read the older SD types.
Sep 30, 2009 | Kodak EasyShare Z740 Digital Camera
Formatting troubles for a 8gb Sandisk Micro SDHC
Hi Tony,
Have your My Computer window open and re-insert the card into the reader. If it doesn't show immediately, then right click and choose refresh. It should show up then.
Rob
Feb 27, 2009 | SanDisk 8GB microSDHC Memory Card with...
Jazz HDV178 videos from SD card not acknowledged.
SDHC cards need a special reader. A standard SD reader won't read a SDHC
Dec 31, 2008 | Jazz DV-179 Digital Camera
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
Does HP2575 read SDHC SD cards
HP2575 doesn't read SDHC cards. You can only read SDHC cards in devices approved for SDHC use.
Aug 13, 2008 | HP Office Equipment & Supplies
Panasonic AG-HMC150 AVC Camcorder Logo
87 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
