How do i demagnatise my color screen
Color all messed up by a magnet
  • kazdack Nov 13, 2008
    My son decided to place his magent onto our TV screen this morning and was amazed by all the pretty colours that it generated! He was so impressed he moved the magnet all over the screen!!!
    We're now left looking at purple people ........ can you help??
    Karen (London)
  • 975 Answers
HI ,you have to purchase a DEGAUSSING COIL , item can be found in one of the major AUCTION SITE , they can cost you around $20.00 / less or more . once you have item ,hopefully the instructions will be included , but basically what you do is to put the DEGAUSSING COIL in front of the screen and do circular motions where area affected and slowly move away from the screen until the spot disappears. hope it helps
Posted on Apr 19, 2008
What caused my TV to suddenly have pink and green areas on the screen?
Hello
For every standard televisions, there will have a degaussing posistor, to demagnatise the picture tube, each time it is switched ON. If thie degaussing posistor has damaged, there will be no degaussing action and color patches on screen will be the relsult.
Moreover, check whether there is any external speaker boxes have placed near the Tv. The magnetic effect from the magent of the speaker can also cause this.
Posistors sre of severel types, and the pictures of some of them are given here.
Feb 08, 2012 | Panasonic Televison & Video
Color problem
It sounds like the set has become magnetized. It could possibly be from an external speaker magnet or some other magnetic field (ie. a vacuum motor). It could also be a malfunction in the built in demagnetizer circuit. Color picture tubes are very sensitive to magnetism. Because of this there is a built in demagnetizer circuit. If this circuit malfunctions it can cause the same problem. Turn the set off and unplug it for 30 minutes or so. This will allow the circuit to cool off and reset. Turn the set back on and see if it returns to normal. Also, dropping the set or a heavy jar can warp the shadow mask inside the tube causing the same problem. If the unplugging method does not work, have a shop check it for you. Thanks for using fixya.
Mar 02, 2010 | Panasonic Televison & Video
The only issue with it is it has a double vision screen (The colors are kinda messed up)
JUST GET MAGNET AND TRY TO PASS IT BY THE SCREEN, OR GET IT CLOSE TO THE MESSED UP COLORS, I HOPE IT WILL HELP, LET ME KNOW IF IT WORKS
May 13, 2009 | Samsung PCH521R 52" Rear Projection...
Samsung 794mg --- problem in monitor screen --- uneven colour mix
sounds like the monitor experienced being close to a magnetic field.
if the monitor doesn't have a auto degaussing (demagnatise) function on start up, then try using the degaussing function on the monitor (in the menu somewhere).
if no good, then you can try moving/waving a magnet near the affected area. b careful! slowly wave the magnet from a distance 1st, until you have improvements. too close and it will change the colours further!
Feb 13, 2009 | Samsung 793DF 17" CRT Monitor
Pink tv screeen
if ur tv is CRT (picture tube) just power OFF it for 20-30 minutes and then power up again. problem will be solved.
Jun 14, 2008 | Bush 5693D 24" TV
Screen problems
you have to remove the back of the phone with a small tri screw driver. underneath the board in a corner there is a flat cable that connects the screens to the board. It came loose. press the flat cabe back into the the board chip. they will lock together. the screens will work.. I just did this with my sons phone.
Jan 03, 2008 | Kyocera Switchback KX21 Cellular Phone
Magnavox tv problem a green vertcal streak on rt side
Dickson do you have a speaker next to your tv anything magnet will change color it may need demagnatised
Maxol your tv more then likely has a bad picture tube or you have a shorted transistor for green output shorted on CRT board.
ThankYou for using FixYa. Have a Nice Day.
Dec 28, 2007 | Philips Magnavox 27MS343S 27" TV
My "42" inch sansui plasma monitor
You don't have any magnet anywhere near the TV do you ?
If not it sounds like something magnetic is interferring with the picture.
If not get the warranty out :D
Dec 16, 2007 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
No blue screen
what you are describing is a degaussing problem. It normally occurs if some Magnetic source has been brought close to your TV. Perhaps you have shifted your TV from part of the room to another? Or to another room? Did you or someone place a magnetic source (Speakers, Tape recorder, Walkie talkie, some toy of your children, etc near or on top of the TV? Just remove it. And wait for a few days. The problem will get automatically cleared up, as the TV set's Auto Degaussing circuits will clear the color patches.
Aug 18, 2007 | Samsung TSL2795HF 27" TV
Televison & Video Logo
394 people viewed this question
Top Televison & Video Experts
Electro Med Services...
