Question about Meade 884 Tripod
Problem with the thumb screws on Meade 884 Tripod that tighten to hold each of the sliding legs in place. The brass thread inserts are pulling out of the black plastic body of the leg adjusters. How can they be repaired and if not where can I get new parts. I live in Sydney Australia.
  • adturner Jul 12, 2010
    Can't get brass insert fully out . When push back in glue pushes out and does not hold.
  • adturner Jul 13, 2010
    Thank You I will try Australian Distributor and if not able to fix will try other stated options.
    Brigadier General:
  • 4,090 Answers
Getting parts or after sales service from Mead is next to impossible. Their parts come from backyard manufacturers in Mexico. The forums that discuss this are full of negative comments about Mead after sales and lack of parts. the attitude is ..Buy another full product.. as we don't supply spares..
Your only real option is to truy and repair the threads by tapping them back in place and using A FIBERGLASS mixture to re bury them in the plastic .
The second option is to trry one of the local australian distributors for a repair. But don;t hold your breath about them being any more able to get parts, but if you don't ask you don't get the answer.
Posted on Jul 12, 2010
Adturner,
Did you solve this problem or manage to find parts? I have the exact same problem and tried glueing but this did not work. I am in Wollongong AU so would be interested in knowing more.
Posted on Jul 27, 2010
  • 10,865 Answers
Hi adturner. Get a tube of clear one minute epoxy. This wonderful adhesive will get you back up and running in no time. Just be prepared with a pair of pliers so that the moment you have applied the epoxy you can squeeze the brass insert back into the plastic body. J.
Posted on Jul 08, 2010
Can I get parts for a damaged tripod
Contact the importer or manufacturer, telling them the exact make and model number, plus a full description of the problem, with photos if possible. Alternatively, take it to a nearby camera shop or repair facility.
Jun 23, 2016 | Giottos Mtl9351b Mh5011 3-way Head Tripod...
Legs Locks Loose
Ross
-It is possible that you are overloading the tripod, thus causing this problem (check specs on tripod model)
HOWEVER IF YOU AREN'T....Giotto uses (2) different leg lock designs..., quick release (normally adjusted by a socket wrench) or rotary (screw locks)!
- If tripod uses screw locks, sometimes foreign material gets into the mechanism and either damages it or prohibits from tightening!!!!!
Note: rotary locks are easy to maintain & if you need parts..., they are user replaceable and usually inexpensive! (contact Giottos distributor in the country you live in)!!!
BUT FIRST!!!! (often problem is caused by dirty lock mechanism)
-carefully unscrew the leg lock (that is slipping) until it separates from the leg higher leg section & carefully pull out the lower tube (at the top of the lower tube will be 'shims' that are part of the lock mechanism).
-Look closely at existing 'shims' do they show signs of cracking, of a build up of dirt, etc. (if damaged they will need to be replaced)
-if shims are undamaged..., use rubbing alcohol & a clean cloth to clean shims and both the tube they sit on and the inside of the tube they slide into.
-once both sides of the tubes and both male & female threads of the locking mechanism are cleaned..., place a light coating of a light oil into the threads (sewing machine oil, bike chain oil, etc)...., do not get oil on the shims!!!!!
-replace locking shims back into position and carefully slide leg tube back into place..., then screw locking collar on (this should not take any force..., if while threading lock collar back on..., it seems tight..., back off collar and check positioning of shims). Repeat procedure!!!
TEST RESULTS!!!
Note: in most cases with rotary locks, problem is purely a maintenance issue, cleaning usually fixes the issue!!!
Peter
Nov 08, 2013 | Giottos (BL1150) Tripod
The screws on my tripod will not tightened
Take out the whole Camera Plate. there is a plastic cap on the top of the tripoid, right by the end of your tripod extender, that comes out with a little pulling it. Now, have a look at the end of the knob housing from which your screw accidentaly came out. You will see a perfect spot in wich you need to re- insert the nut that came out. Once you do it, all you need to do is to re- insert the knob back into place, and it will "bite" the nut again at the end of the housing. Re- install the whole plate back on top of your tripod. Finally, put the plastic cap back at the top. You might need to gently tap it in. Done deal . Problem resolved ! Enjoy your tripod !
Jan 21, 2012 | Zeikos ZETR57A Tripod
Need the plastic foot on the tripod leg.
Try going to the Meade website home page, find your Tripod parts section and see if you can order a rplacement foot for it. It should be fairly cheap.
or try this link:
http://www.shopzilla.com/+Meade+plastic+foot+on+the+tripod+leg/search
Aug 29, 2010 | Meade 884 Tripod
My oster 76 clippers will kick out the two screws that hold the blade holder on
do the screws undo or do the brass inserts pull out of the body housing which the retaining screws fit into.
if the screws undo put some thread lock on the threads.
if its the brass inserts you will need to replace the mainbody.
Jan 23, 2010 | Oster 76076-010 Hair Trimmer
Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
Dec 25, 2009 | Manfrotto 679B Monopod
I bought a used meade polaris 60az-m telescope and it is wobbly on the tripod. There is one screw coming from underneath the tripod into the telescope. I tightened the screw but when I move the telescope...
Here is the Meade manual web site. Find your telescope and see if a part is missing.
http://www.meade.com/manuals/index.html
and here is their customer service phone number:
http://www.meade.com/support/index.html
Aug 17, 2009 | Meade ETX-125PE (500 x 127mm) Telescope
Meade LX90 8" SCT I am having trouble getting a firm fixing of the scope to the tripod. I may have cross threaded the fixing. I notice that the fixing at the bottom of the yolk is secured by...
You may need to add one or two small washers to the central screw to tighten things up a bit. A "C" clip holds the big screw on the tripod. If you break it any hardware store can supply a replacement for less than $1.00.
Oct 31, 2008 | Meade 8" LX90 LNT Schmidt Cassegrain...
Can't figure out how to straighten and level the camera
if you have lost a srew or wing nut, it will be loose where there should be one. set it up and then try to raise or move it around in one spot. iof it moves than look for a screw hole. the handle itself sets the rotation try unloosing the handle..
Dec 31, 2007 | Quantaray QSX-DigiPro 8500 Tripod
Dead Legs on Tripod
I have no ideas, but if you buy another tripod, I owuld like to buy your old handles from your 8500.
Thanx
Rick
817.846.8464
Oct 02, 2006 | Quantaray QSX-DigiPro 8500 Tripod
Meade 884 Tripod Logo
82 people viewed this question
Top Meade Photography Experts
Tony
Are you a Meade Photography Expert? Answer questions, earn points and help others
