Question about Gateway GT5228 PC Desktop
Installed new hard drive (old one crashed) no sound now
Installed new hard drive (old one crashed) used restore cd, everything works, except i have no sound. volume control in control panel says "no device installed". device manager says drivers are ok, whats up?
Most likely this is caused by missing/wrong sound driver.
The Gateway site lists driver D00633-01-01 which installs the Realtek Sound Driver. This driver worked fine on my GT5228 under XP/Media Center. If re-install of Windows, (or in my case a restore from the Gateway restore disk) then you will also need the AMD chip drivers, and Mainboard Drivers to support all of the on-board components (nVIDIA Video, LAN Adapter, etc.)
Posted on Aug 10, 2010
    Problem Solver:
  • 5 Answers
You c'd be experiencing a bad hard drive and am only worried about your data. Learn to backup online. There are ton of options, you can try 5GB free trial on www.safecopybackup.com. Hope this works for you like it does for me.
Posted on Jul 17, 2010
  • 60 Answers
You need another sound system. If it's xp it is probably ac 97. However; go to windows update, make sure you have all of the updates. Then go to the control panel, device manager and look for a yellow question mark or a yellow exclamation mark, if there, right click and click update driver or click uninstall from the system, restart the computer and windows will look for the drivers, just follow on screen directions.
Posted on Jul 08, 2010
Tip
How to repair hard drive
<span>Instructions</span> Things You'll Need: <ul> <li> <span>Operating software installation or build CD</span> </li> <li> <span>Boot-up disc</span> </li> <li> <span>System restore CD</span> </li> <li> <span>Backup tape</span> </li></ul> <ol> <li> Look for tell-tale signs that your computer is about to crash or fail. Extreme slowness, repeated blue screen and noise or clicking are sometimes signs that your computer hard drive is about to crash. When you hear the sound of clicking, scraping or grinding, immediately turn off or shut down your computer. Doing so will prevent any loss of data.<br /> </li> <li> Power down and then power up. Sometimes, hard drive crashes can be easily recovered by doing a power shutdown of the computer. Then, after waiting for a couple of minutes, power it back up again. The initial hard drive crash may not be too serious, but if it happens often, start performing a full system backup, if you haven't been doing so, to be able to recover your data should the inevitable happen.<br /> </li> <li> <span> <a><img src="repair-hard-drive-crashes-1.3-120X120.jpg" /></a> jQuery(document).ready(function(){ jQuery('#jsArticleStep3 span.image a:first').attr('href','http://i.ehow.com/images/a04/8f/3a/repair-hard-drive-crashes-1.3-800X800.jpg'); }); PC cable or component connection </span> Ensure that your hard drive and other internal components are seated properly. If Steps 1 and 2 do not work, you may need to open your computer's CPU to check on some of the drive connections. Sometimes connections get dislodged, especially if you move your computer box often. The symptom will manifest as if the hard drive has crashed, giving you a "disk error" when you try to boot up your computer. First, turn off your computer and unplug it. Then remove the case of your computer box. Press on each connector to connect it properly. Put the cover back again, plug the computer and power it back up.<br /> </li> <li> <span> <a><img src="repair-hard-drive-crashes-1.4-120X120.jpg" /></a> jQuery(document).ready(function(){ jQuery('#jsArticleStep4 span.image a:first').attr('href','http://i.ehow.com/images/a04/8f/3a/repair-hard-drive-crashes-1.4-800X800.jpg'); }); Boot from CD drive with a boot disc </span> Insert your boot disc and try to boot up your computer using the disc. Once you are able to do so, you can reinstall your operating system. After installing your software, proceed to perform data recovery using your ghost CD or backup.<br /> </li> <li> Use an emergency repair disc to get your computer to work again. Then restore from the last known good configuration.<br /> </li> <li> Reinstall your operating system using the installation or system restore CD that came with your computer when you first purchased it. It will take you through a series of steps that include formatting your hard drive, which will then erase your data. Do this as a last resort.<br /> </li> <li> Recover your data by using a restore and recovery software or using your most recent backup after you have reinstalled the operating system in the previous step.<br /> </li> <li> Reinstall your applications that did not come with your computer when you bought it. Some examples would be Adobe Photoshop, anti-virus software and movie-making software.<br /> </li></ol> jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); <span>Tips & Warnings</span> <ul> <li> Call technical support if you are unsure of what to do. They can walk you through the important steps. You can also take your computer to a PC technician who, for a fee, will do a system restore and data recovery for you.</li> <li> Make it a habit, even if your computer is healthy, to do a complete backup so your important data will not be lost.</li> <li> Never attempt to open your computer without first powering it off to avoid being electrocuted.</li> <li> Do not open your hard drive case; the components are so sensitive that even a single speck of dust may erase your data.</li></ul>
on Dec 23, 2010 | Computers & Internet
My system crashed. Won't reinstall windows
Do you need anything that is stored on the crashed hard drive? If so, you need to get an adapter for the drive and connect it to a desktop pc as the 'd:' disk. then copy any files you can access that you need saved.
Re-install the drive into the laptop, use "FDISK /MBR" from a floppy drive or a USB drive set up as a boot disk to re-partition it, and install the master boot record, and then boot the CDrom to install your operating system afresh.
The error message you are getting is caused by the 'restore' program trying to use the C: disk programs, and they are not there. I think you may have a bad hard drive, as usually the programs will be found.
You need to find out if the disk is really really bad or just needs to be re-formatted. Follow the above steps to determine if you need a new drive or not.
tom
Jan 18, 2010 | Computers & Internet
My nc10 reported the 'operating system not found' a week or so ago. I've tried everything including trying to reload windows xp from a USB [as the netbook doesn't have a cd drive] At this point I just want...
Sound like your hard drive has crashed so bad that the notebook does not even know it is there. I would replace the hard drive and try to reinstall from external cd-rom . Make sure the external cd-rom is recognized in the bios settings Good Luck
Nov 23, 2009 | Samsung NC10-14GW Notebook
Computer crashed. Computer specialist restored drive. now cannot boot windows. Used restore disk. Did not work. computer boots dos screen then shuts down. boots again then shuts down.
Sounds like a Windows issue. Depending on how valuable it is to you to get your data off the drive, I would suggest buying a new hard drive (they are fairly cheap these days), installing Windows on that. Word of advice: Remove your old drive when doing the Windows install, so as not to accidentally select the hard drive your data is on. Once you have Windows installed, shut down your computer, remove the power cord, and install your old drive on a separate IDE channel or SATA connection. If your PC still tries to boot to the old drive, change the boot order in your PC's BIOS.
Aug 10, 2009 | E-Machines eMachines Desktop PC
Dvd stuck inside slot drive, system had crashed
hello..to get out you`re CD/DVD its very simple you need a small Pin like a paper clip then find the small hole the front side of DVD/CD player and push the hole using the paper clip..about this question kindly Verify>(plus i had already installed the new hard disk because the old one crashed)..what is it??...Thank you
May 08, 2009 | Dell XPS M1330 Notebook
System crashed , no restore partition, origionall had xpsp1, have Dell reinstall Cd with xp sp2....will it have to be re activated?
Yes, but it will erase any personal data you have. Let me know if there is data to save and I will give more suggestions.
Apr 13, 2009 | Dell Inspiron 600M Notebook
Cannot get Toshiba P@% S507 to see new hard drive.
you can't use a restore disk made for a specific hard drive with a much larger hard drive. This information is checked by the restore cd. You would need to contact toshiba and get a regular windows install cd.
Apr 01, 2009 | Toshiba Satellite P25-S507 Notebook
I was installing Turbo Tax 2008 and Windows XP crashed
Madam/Sir --
I none of the mode is working you need to boot from the cd to do any further steps.
inorder to boot from the cd you need to go to the bios and change the boot sequence to boot order.
It varies system to system once to you boot from the cd try to log on to recovery console and do a manual system restore by following the below steps - :
Step 1:
Boot with the windows XP CD
At "Welcome to setup screen" Press R
Select the appropriate path for windows and press enter
If it asks you for the administrator password, normaly there is not password but if you have a password type the administrator password and
press enter or just hit enter
We will now see the Prompt c:\windows>
Step 2:
cd system32\config
ren system system.old
ren software software.old
ren SAM SAM.old
ren security security.old
ren default default.old
Then type cd Type cd system~1\_resto~1 and press Enter
If you get "access denied" (Error) then
Restart the computer by type Exit and get back to recovery console
type cd \ and it will display C:\>
type cd system~1\_resto~1 and press Enter
Step 3:
Type dir
It will list you restore points
(e.g. RP1, RP2, RP3, RP4, etc...)
Select the one from the list except the last one
Say RP4
· type cd RP3 (or RP2 or RP1 or RPn) and enter
· type cd snapshot and enter
· type copy _registry_user_.default c:\windows\system32\config\default and enter
· type copy _registry_machine_security c:\windows\system32\config\security and
enter
· type copy _registry_machine_software c:\windows\system32\config\software and
enter
· type copy _registry_machine_system c:\windows\system32\config\system and enter
· type copy _registry_machine_sam c:\windows\system32\config\sam and enter
· type exit and enter
The computer restarts and the system will be
Successfully restored
Mar 20, 2009 | Microsoft Windows XP Home Edition
Winxp with serv pak 3 crashes when installing konica minolta pagepro 1350w
It must be because the software is not compatible with SP3; I've seen this a few times already. Does the Dell have SP3 installed? If not, I dare say that is the issue.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Konica Minolta PagePro 1350W Laser Printer
Gateway GT5228 PC Desktop Logo
114 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
