Question about Sharp AR-5316 Advanced Digital Imager Copier
The paper jam at the heat roller unit model sf-2118
Title: paper jam
i have been working on this machine some days now. The paper will transport from the cassette and immediately the paper pass the heat roller unit small that b4 it roll out completely the paper will stop and it will be showing paper jam.
    Problem Solver:
  • 5 Answers
Sounds like a timing jam, there will be an exit sensor (photo interrupter) check the paper is correctly triggering the sensor and it is correctly positioned.
http://www.onlineconnect.co.uk/
Posted on Jul 18, 2010
    Problem Solver:
  • 10 Answers
Have to be more clear
Posted on Jul 10, 2010
Sharp SF-1118 copying machine H 3 Error
This is a heating error for the fusing section, the lamps may be damaged or there could be a build up of dust and debris on the thermistors that monitor temperature. I would check the fusing section. THIS IS THE UNIT THAT HAS THE TWO ROLLERS THAT THE PAPER PASSES THROUGH AT THE END OF THE PAPER PATH. Check there is nothing jammed or damaged. you may need to replace unit.
Oct 18, 2015 | Sharp Office Equipment & Supplies
Our fax machine displays jam 0 samsung sf 5100
Open the door take the cartridge out clean the roller at the back with dishwasing liquit and see if there is no paper stuck in unit. put ther cartridge back and take the power out and hold the red stop button in and put power back.
Aug 19, 2011 | Samsung SF-5100 Plain Paper Laser Fax
How do you reset an H5-01 error code on Sharp Color MX2300 Copier.
Hello
Most error codes can be cleared by removing the paper jam and then rebooting the machine. When an error code occurs, make a note of the code and then follow the instructions on the control panel for clearing it.
Paper jams can be caused by a variety of issues in the copy machine, but jamming can commonly be caused by improperly loaded paper in the trays or dirty paper feed rollers.
If you get repeated paper jams, remove the paper from the trays and inspect the stack. Look for folded corners, especially on the bottom of the stack. Fan the paper thoroughly and then reload the stack into the tray. Check the paper guides to ensure they are not too tight or too loose. Both conditions can cause paper jams.
If you can see the paper transport rollers by opening the ordinary access covers and panels inside the machine, cleaning them might help reduce paper jams. Shut the machine off and unplug it, then take a soft, lint-free cloth dampened with water and wipe those rollers off. A buildup of toner and paper dust can cause them to slip while transporting the paper.
Oct 21, 2010 | Office Equipment & Supplies
Model No MFC7420 Paper gets stuck through heat roller - constantly opening up machine and pulling paper out. Very annoying. Can this be resolved? Or is it an expensive fix
normally if the paper is jam after the heat roller and before the exit part.. the cause of the problem is the wore out Paper Eject Roller.. it's not an expensive fix..the cost probably will between US20 to US30..
But if the paper get jam before the roller..you might need to check the heat roller finger...if that is damaged.. it would cause paper to jam as well...
Jun 27, 2010 | Brother DCP-7030 Digital All-in-One Laser...
Brother MFC 7420 - paper jams in fuser unit -
Its probably the pickup roller and/or separator pads. Another possibility is a tear in the fuser heat cover. IF you can manually rotate the fuser(when its cool) you can see if the fuser roller has any problems. Last thing is make sure its looking at the right paper size. Maybe reset all software settings and start over? If its looking for one size and seeing another, it may cry jam.
Feb 02, 2018 | Brother Office Equipment & Supplies
Sharp sf 2014 copier problem
clean the paper feed rollers with soap and water damp cloth take paper tray out use flashlight to locate rollers also clean registration roller under the drum check and see if u have any broken gear teeth on your fusing assemby also if after cleaning it works i recommend u replace feed rollers
Jun 04, 2009 | Sharp Office Equipment & Supplies
Kyocera Printer FS-1800 plus - paper jam Can't find the printer manual. Please provide steps to clear the paper jam and reset the printer.
Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
Nov 29, 2007 | Office Equipment & Supplies
Paper jam
Open the front cover and look at the white roller. Is there anything jamming that? Like, say, a broken clip that's meant to hold the front cover in place as I just found happened to our fax machine.
Apr 05, 2007 | Samsung SF-335T Plain Paper Inkjet Fax
Sharp AR-5316 Advanced Digital Imager Copier Logo
134 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
