Question about Car Audio & Video
I changing my car battery I put disstilled water ang I charge after 5 hours my baterry was same voltages when firts I cheked how know to if my baterry need to replace and how to know if my baterry are not charging.
  • 6,826 Answers
Voltage is 12 V or so, is an ok thing to measure.
But, it must be measured under load to determine if there are enough CCA or cold cranking amps to perform well in your vehicle's starting system.
Posted on Jul 08, 2010
ABS, BATTERY,GAZ LIGHTS WENT ON
no I am not there.. you need to put gas in.. charge the battery and try to start the car..after it charges a few hours..
Jan 02, 2014 | 1999 Chevrolet Venture
Sudden discharge of batteries
The icon may indicate the batteries are fully charged and your measurements would indicate this but I suspect the batteries are no good..
Nov 29, 2013 | Cameras
Baterry isnt charging it only works on AC power DELL PP22L
Press the function and F3 button. This will enable/disable charging. If that does not work, then you either have a power adapter that is not creating enough voltage to charge the battery or the battery has gone bad.
Oct 21, 2012 | Dell PP22L-XT279 Core 2 Duo 1.6g 1gb Ram...
I have a 87 honda prelude just changed the water pump, now car wont start.fjj1484@yahoo.com
THE WATER PUMP DOESNT HAVE NOTHING TO DO WITH THE CAR STARTING , CHECK BATTERY CONNECTIONS , POSIBLE BAD BATERRY , ALTERNATOR NOT CHARGING ECT ECT.
Nov 01, 2010 | 1987 Honda Prelude
Battery light comes on and off car dies with a quick boost it run again then dies battery good
this is caused by a failing alternator. Kragen auto and Autozone tests these for free.
Jun 03, 2010 | 1996 Mercury Sable
I am not getting any power to the laptop i have the battery disengage from the laptop with direct power it is still not comming on
you need to put the baterry back on if the battery is bad replace it, the charger is for the baterry. a laptop needs a battery to work, the power that is coming out of the charger only charges the battery it isnt going to power on the pc, it is for maintaning the proper voltage in the battery.
Jun 03, 2010 | E-Machines M2105 Notebook
The baterry dies in 10 minutes.the motorcycle has only 6700km.should i change baterry?so soon?
Yes the battery can die in as little as 12 months if it is not used often, vibration and rough roads can also shorten battery life.
Check it has water in it up to the lines.
Put a multimeter across the battery should be just over 12v with engine stopped, rise to 13-14v with engine running to check charging circuit. Riding when the battery completely dies can overload the charging circuit.
May 14, 2010 | 2008 Yamaha XT 660 Z Tenere
Won't start, baterrys fine
check your voltage in your battery and if it will jump start again check the voltage while running to see if the alternator is charging
Mar 23, 2009 | 2001 Jeep Grand Cherokee
Schumacker battery charger problem?
You are charging. The meter corresponds to the level of charge in the battery. Try setting to 10 A for 4 hours, battery should be half-way up. To determine if battery id dead.. leave battery off charger once it is fully charged...test with a voltmeter after 10 min.....battery should still be above 12v...after1 hour it should still be above 12v...if not battery is spent.
Mar 11, 2009 | Schumacher & Fast Charge Starter Charger
Battery dead , could be bigger than that?
it could be baterry,but usually you can check it your charging system if is working with avoltmeter
Jun 28, 2008 | 2000 Toyota Corolla
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
