Question about HP Compaq 6910p Notebook PC PC Notebook
Please I would like to be assisted on what to do to my hp compaq 6910p. When I connect it to power it fails to charge with the charge light indicator blinking, but when I disconnect from power the charge light indicator becomes stable. Thanks for your help.
  • 487 Answers
Hi, you could need a new battery, these to fail. Hope this helps
Posted on Jul 08, 2010
How do I enable the webcam and turn on wireless capability on HP compaq 6910p
above the function keys (F3,F4 or F5) you will see the wifi icon touch that icon and should light up. indicating wifi is on.
thanks
Apr 01, 2014 | HP Compaq 6910p Notebook PC PC Notebook
Blinking light
All the time, or only when in Sleep/Hibernate mode? Is the battery charging properly? A bit more info. Shut down Sleep and Hibernate to verify.
Jul 03, 2013 | HP Compaq 6910p Notebook PC PC Notebook
I have hp compaq 6910p laptop, which worked at its best for several weeks after it was bought. but few days back it started freezing, taking too much time in startup and to run programs aswel. I was t
Instructions
Plug one end of the VGA connection cable into the VGA port on the external display. Tighten the knobs on the VGA connector to secure the cable to the monitor.
Plug the other end of the VGA connection cable into the VGA port on the on your Compaq 6910P. The VGA port is located on the back of the device. Tighten the knobs on the VGA connector to secure the cable to the laptop.
Plug the external display's power cord into a wall outlet. Power on the device by clicking its "Power" button.
Boot your Compaq 6910P.
5
Click on the "Start" button in your task menu.
6
Select "Control Panel," then click "Appearance and Personalization."
7
Click "Personalization" in the window that appears.
8
Select "Display Settings."
9
Select "Mirrored" from the New Display Detected dialog box to have your displays mirror each other.
10
Select "Extended" from the New Display Detected dialog box to have your display function like one, large workspace.
11
Select "External Display Only" from the New Display Detected dialog box to use only your external monitor.
12
Click the "OK" button to keep the changes and exit the setup.
Jan 10, 2013 | HP Compaq 6910p Notebook PC PC Notebook
My hp compaq 6910p laptop not on adapter is ok **** i plug in laptop no power on no any light on
Unplug adapter using cheap multimeter, check for voltage on the Plug the goes to laptop.. the plug should be producing 13+ volts ( not sure exactly of Spec, but it is located on the power pack itself. )
Your problem sounds to me like your power supply is shorting out .
Alternative problem is the charge circuit on the mainboard may need to be serviced. ( commonly replacing mainboard- some facilites can repair )
Jan 12, 2012 | HP Compaq 6910p Notebook PC PC Notebook
On my hp compaq 6910p, my wireless switch will not turn on my wireless functionality, and neither will enabling the wireless connection. It tells me that the wireless switch is off and I have no way of...
So touching the touch sensitive button to the right of the power on button dont turn it on...you just touch the icon, between the other two icons next to the power button..and it should lite up blue.
Jul 27, 2011 | HP Compaq 6910p Notebook PC PC Notebook
Is buying this Hp Compaq 6910p Battery a wise decision?
I have bought a couple of batteries from them before. They work just make sure that the voltage of the battery. (10.8v) matches the voltage on your battery. Also make sure that the mah 6600mah is greater or the same as the battery that you have. The mah is the mili ampers per hour (in other words the fuel) the bigger the mah the longer your battery will run. I also find ebay a great place to buy hp batterys from. Just make sure that they are oem hp and not a generic knock off and you will be fine and use the same rules from above. and also make sure they will fit your model number. I hope this helps
thanks
Steven.
Apr 24, 2010 | HP Pavilion dv6000z Notebook
Problems with the ac smart adapter Hp Compaq 6910p
You could possibly have a loose dc jack.Being able to wiggle it around and getting it to work tells me that the jack is probally going out.That wiggling your doing can cause an arc on your system board,which can short out your board.Stop wiggling your power supply adapter in your dc jack and take your computer to certified repair shop and have your jack checked.Best to rule this out first ,so no damage is done to your board.If you jack test good ,then replace you power supply....Good luck
Apr 08, 2010 | HP Smart Buy- HP Compaq 6910p Notebook PC...
Not getting sound
check your sound drivers,and the sound mixer
Apr 02, 2010 | HP Compaq 6910p Notebook PC PC Notebook
HP Compaq 6910p Notebook PC PC Notebook Logo
218 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
